library ieee; use ieee.std_logic_1164.all; entity DFF is generic(P_DELAY: time := 1 ns; SETUP : time := 1 ns); port(D, CLK, EN, RESET: in std_logic; Q, Q_INV : out std_logic); end DFF; architecture Verhalten1 of DFF is begin process(CLK, RESET) begin if RESET = '1' then Q <= '0'; Q_INV <= '1'; elsif rising_edge(CLK) and EN = '1' then Q <= D; Q_INV <= not D; end if; end process; end Verhalten1; ---------------------------------------------------------------- library ieee; use ieee.std_logic_1164.all; entity MUX2X1 is generic(P_DELAY: time := 2 ns); port(S, E1, E2: in std_logic; Y: out std_logic); end MUX2X1; architecture Verhalten2 of MUX2X1 is begin Y <= E1 when S = '1' else E2; end Verhalten2; ------------------------------------------------------------------- library ieee; use ieee.std_logic_1164.all; entity D_RIPPLE_REG is generic (P_DELAY: time := 8 ns; SETUP : time := 2 ns; SIZE : positive := 4); port (D: in std_logic_vector(size-1 downto 0); CLK, EN, RESET, RIPPLE, INPUT: in std_logic; Q : out std_logic_vector (size-1 downto 0); Q_INV : out std_logic_vector (size-1 downto 0); OUTPUT: out std_logic); end D_RIPPLE_REG; architecture Verhalten3 of D_RIPPLE_REG is COMPONENT DFF is generic (P_DELAY: time := 1 ns; SETUP : time := 1 ns); port (D, CLK, EN, RESET: in std_logic; Q, Q_INV : out std_logic); end component; COMPONENT MUX2X1 is generic (P_DELAY: time := 2 ns); port (S, E1, E2: in std_logic; Y: out std_logic); end component; SIGNAL Q_TEMP, Q_INV_TEMP, Y_TEMP: std_logic_vector(size-1 downto 0) := (others => '0'); begin gen1: for i in 0 to size - 1 generate mux: MUX2X1 port map ( S => RIPPLE, E1 => Q_TEMP(i), E2 => D(i), Y => Y_TEMP(i)); end generate; gen2: for i in 0 to size - 1 generate ffd: DFF port map ( D => Y_TEMP(i), CLK => CLK, EN => EN, RESET => RESET, Q => Q_TEMP(i), Q_INV => Q_INV_TEMP(i)); end generate; process (CLK) begin for i in 0 to size - 1 loop Q_INV_TEMP(i) <= not Q_TEMP(i); end loop; end process; end Verhalten3;
