#! /bin/sh
### BEGIN INIT INFO
# Provides:          httpd
# Required-Start:    $remote_fs $syslog
# Required-Stop:     $remote_fs $syslog
# Default-Start:     2 3 4 5
# Default-Stop:      0 1 6
# Short-Description: http-daemon (microversion written in python
# Description:       This file starts and stops the http-daemon
### END INIT INFO
# Author: Norbert.S <junky-zs@gmx.de>
# Please remove the "Author" lines above and replace them
# with your own name if you copy and modify this script.
# Do NOT "set -e"
# PATH should only include /usr/* if it runs after the mountnfs.sh script
PATH=/sbin:/usr/sbin:/bin:/usr/bin
DESC="This services start/stop mqtt_ht2hassio-daemon"
NAME=mqtt_ht2hassio.py
NAME_SCRIPT=mqtt_ht2hassio
USER="pi"
DAEMON=/home/$USER/HT3/sw/mqtt_ht2hassio.py
DAEMON_ARGS=""
PIDFILE=/home/$USER/HT3/sw/var/run/$NAME.pid
APPLICATION_FOLDER=/home/$USER/HT3/sw
SCRIPTNAME=/etc/init.d/$NAME_SCRIPT
# Exit if the package is not installed
[ -x "$DAEMON" ] || exit 0
# Read configuration variable file if it is present
[ -r /etc/default/$NAME ] && . /etc/default/$NAME
# Load the VERBOSE setting and other rcS variables
. /lib/init/vars.sh
# Define LSB log_* functions.
# Depend on lsb-base (>= 3.2-14) to ensure that this file is present
# and status_of_proc is working.
. /lib/lsb/init-functions
# Function that starts the daemon/service
do_start()
	# Return
	#   0 if daemon has been started
	#   1 if daemon was already running
	#   2 if daemon could not be started
	start-stop-daemon --chuid  $USER --user $USER --chdir $APPLICATION_FOLDER --start --quiet --pidfile $PIDFILE --background --exec $DAEMON $DAEMON_ARGS --test > /dev/null \
		|| return 1
	start-stop-daemon --chuid  $USER --user $USER --chdir $APPLICATION_FOLDER --start --quiet --pidfile $PIDFILE --make-pidfile --background --exec $DAEMON $DAEMON_ARGS \
		|| return 2
	# Add code here, if necessary, that waits for the process to be ready
	# to handle requests from services started subsequently which depend
	# on this one.  As a last resort, sleep for some time.
# Function that stops the daemon/service
do_stop()
	# Return
	#   0 if daemon has been stopped
	#   1 if daemon was already stopped
	#   2 if daemon could not be stopped
	#   other if a failure occurred
	start-stop-daemon --stop --user $USER --quiet --retry=TERM/10/KILL/5 --pidfile=$PIDFILE --name $NAME
	RETVAL="$?"
	[ "$RETVAL" = 2 ] && return 2
	# Wait for children to finish too if this is a daemon that forks
	# and if the daemon is only ever run from this initscript.
	# If the above conditions are not satisfied then add some other code
	# that waits for the process to drop all resources that could be
	# needed by services started subsequently.  A last resort is to
	# sleep for some time.
	start-stop-daemon --stop --user $USER --quiet --oknodo --retry=0/10/KILL/5 --pidfile=$PIDFILE --exec $DAEMON
	[ "$?" = 2 ] && return 2
	# Many daemons don't delete their pidfiles when they exit.
	rm -f $PIDFILE
	return "$RETVAL"
# Function that sends a SIGHUP to the daemon/service
do_reload() {
	# If the daemon can reload its configuration without
	# restarting (for example, when it is sent a SIGHUP),
	# then implement that here.
	start-stop-daemon --stop --signal 1 --quiet --pidfile $PIDFILE --name $NAME
	return 0
case "$1" in
  start)
	[ "$VERBOSE" != no ] && log_daemon_msg "Starting $DESC" "$NAME"
	do_start
	case "$?" in
		0|1) [ "$VERBOSE" != no ] && log_end_msg 0 ;;
		2) [ "$VERBOSE" != no ] && log_end_msg 1 ;;
	esac
  stop)
	[ "$VERBOSE" != no ] && log_daemon_msg "Stopping $DESC" "$NAME"
	do_stop
	case "$?" in
	esac
  status)
	status_of_proc "$DAEMON" "$NAME" && exit 0 || exit $?
  #reload|force-reload)
	# If do_reload() is not implemented then leave this commented out
	# and leave 'force-reload' as an alias for 'restart'.
	#log_daemon_msg "Reloading $DESC" "$NAME"
	#do_reload
	#log_end_msg $?
  restart|force-reload)
	# If the "reload" option is implemented then remove the
	# 'force-reload' alias
	log_daemon_msg "Restarting $DESC" "$NAME"
	do_stop
	case "$?" in
	  0|1)
		do_start
		case "$?" in
			0) log_end_msg 0 ;;
			1) log_end_msg 1 ;; # Old process is still running
			*) log_end_msg 1 ;; # Failed to start
		esac
		# Failed to stop
		log_end_msg 1
	esac
	#echo "Usage: $SCRIPTNAME {start|stop|restart|reload|force-reload}" >&2
	echo "Usage: $SCRIPTNAME {start|stop|status|restart|force-reload}" >&2
	exit 3
esac
