(footprint "B02B-PASK-1LFSN" (version 20210126) (generator pcbnew) (layer "F.Cu")
  (tedit 602FBC1C)
  (attr through_hole)
  (fp_text reference "REF**" (at -1 0) (layer "F.SilkS")
    (effects (font (size 1 1) (thickness 0.15)))
    (tstamp 31a88e8b-bccb-4888-915c-d6cddc2f9a7a)
  (fp_text value "CONN_B02B-PASK-1_JST" (at -1 0) (layer "F.SilkS")
    (tstamp 4e5812c7-a505-4e71-ada5-9c982158c9e7)
  (fp_text user "*" (at 0 0) (layer "F.SilkS")
    (tstamp 520e667a-e989-40fe-9f7c-ccfcf5f5f7a2)
  (fp_text user "Copyright 2016 Accelerated Designs. All rights reserved." (at 0 0) (layer "Cmts.User")
    (effects (font (size 0.127 0.127) (thickness 0.002)))
    (tstamp ca718a36-975c-4e51-9f86-fe1a4095c8d5)
  (fp_text user "*" (at 0 0) (layer "F.Fab")
    (tstamp 07738f41-29ef-41ac-8b4b-af49b8f8980f)
  (fp_circle (center 2.7592 0) (end 3.1402 0) (layer "B.SilkS") (width 0.1524) (fill none) (tstamp 9bc0437d-c7e2-48fd-8af7-e9becfc7e735))
  (fp_line (start -4.1242 -2.227) (end -4.1242 3.335599) (layer "F.SilkS") (width 0.1524) (tstamp 4e2da57e-b4bc-4ce1-88b4-0b32a43e6128))
  (fp_line (start -4.1242 3.335599) (end 2.1242 3.335599) (layer "F.SilkS") (width 0.1524) (tstamp 542d0df7-70da-4a2f-9923-96d061ae1fae))
  (fp_line (start 0.440153 -2.227) (end -4.1242 -2.227) (layer "F.SilkS") (width 0.1524) (tstamp b05794f7-af41-4d95-a7ab-277ebc581138))
  (fp_line (start 2.1242 3.335599) (end 2.1242 -0.694327) (layer "F.SilkS") (width 0.1524) (tstamp b555fe34-de8b-41d6-8bef-89cc56c0ac9b))
  (fp_circle (center 2.7592 0) (end 3.1402 0) (layer "F.SilkS") (width 0.1524) (fill none) (tstamp 80317749-26b9-4211-bdc7-649926c3fe7c))
  (fp_line (start 2.6049 -2.804899) (end -4.2512 -2.804899) (layer "F.CrtYd") (width 0.1524) (tstamp 054623eb-7f77-4e39-b004-2faa606d50e3))
  (fp_line (start -4.2512 -2.804899) (end -4.2512 3.462599) (layer "F.CrtYd") (width 0.1524) (tstamp 55e82259-d7a3-48ab-9961-ef9763f09d52))
  (fp_line (start 2.6049 3.462599) (end 2.6049 -2.804899) (layer "F.CrtYd") (width 0.1524) (tstamp 7c6ba36e-ab5f-4b4f-a8c9-0c94416cde71))
  (fp_line (start -4.2512 3.462599) (end 2.6049 3.462599) (layer "F.CrtYd") (width 0.1524) (tstamp c9d3bbc1-ece6-4663-bbb5-452c49744318))
  (fp_line (start 1.9972 3.208599) (end 1.9972 -2.1) (layer "F.Fab") (width 0.1524) (tstamp 2479062f-e1d4-4055-a6eb-da52fce09780))
  (fp_line (start -3.9972 3.208599) (end 1.9972 3.208599) (layer "F.Fab") (width 0.1524) (tstamp 7333f338-51ae-4300-8d28-dee4f3a1dcc9))
  (fp_line (start -3.9972 -2.1) (end -3.9972 3.208599) (layer "F.Fab") (width 0.1524) (tstamp 8ab02e19-7720-497b-85d8-7b39e522fa50))
  (fp_line (start 1.9972 -2.1) (end -3.9972 -2.1) (layer "F.Fab") (width 0.1524) (tstamp 92f11437-f68f-4725-abb6-8545d28a2b6a))
  (fp_circle (center 0 1.905) (end 0.381 1.905) (layer "F.Fab") (width 0.1524) (fill none) (tstamp e136573e-b4e7-4ffc-b8af-6766c4b43457))
  (pad "" np_thru_hole circle (at 1.5 -1.7) (locked) (size 1.1938 1.1938) (drill 1.1938) (layers F&B.Cu *.Mask) (tstamp 6353e3b4-549d-4581-87af-2a16899ccadc))
  (pad "1" thru_hole circle (at 0.000001 0) (locked) (size 1.3208 1.3208) (drill 0.8128) (layers *.Cu *.Mask) (tstamp afbcccfc-a842-4bf7-86a1-6a075a73a29f))
  (pad "2" thru_hole circle (at -2.000001 0) (locked) (size 1.3208 1.3208) (drill 0.8128) (layers *.Cu *.Mask) (tstamp 8c9fbfd2-bb54-4af4-95ef-654b0ee3e5c4))
