/* USER CODE BEGIN Header */
* @file stm32f0xx_it.c
* @brief Interrupt Service Routines.
* @attention
© Copyright (c) 2021 STMicroelectronics.
* All rights reserved.
* This software component is licensed by ST under Ultimate Liberty license
* SLA0044, the "License"; You may not use this file except in compliance with
* the License. You may obtain a copy of the License at:
* www.st.com/SLA0044
/* USER CODE END Header */
/* Includes ------------------------------------------------------------------*/
#include "main.h"
#include "stm32f0xx_it.h"
/* Private includes ----------------------------------------------------------*/
/* USER CODE BEGIN Includes */
/* USER CODE END Includes */
/* Private typedef -----------------------------------------------------------*/
/* USER CODE BEGIN TD */
/* USER CODE END TD */
/* Private define ------------------------------------------------------------*/
/* USER CODE BEGIN PD */
/* USER CODE END PD */
/* Private macro -------------------------------------------------------------*/
/* USER CODE BEGIN PM */
/* USER CODE END PM */
/* Private variables ---------------------------------------------------------*/
/* USER CODE BEGIN PV */
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
/* External variables --------------------------------------------------------*/
extern PCD_HandleTypeDef hpcd_USB_FS;
extern TIM_HandleTypeDef htim3;
/* USER CODE BEGIN EV */
/* USER CODE END EV */
/* Cortex-M0 Processor Interruption and Exception Handlers */
* @brief This function handles Non maskable interrupt.
void NMI_Handler(void)
/* USER CODE BEGIN NonMaskableInt_IRQn 0 */
/* USER CODE END NonMaskableInt_IRQn 0 */
/* USER CODE BEGIN NonMaskableInt_IRQn 1 */
while (1)
/* USER CODE END NonMaskableInt_IRQn 1 */
* @brief This function handles Hard fault interrupt.
void HardFault_Handler(void)
/* USER CODE BEGIN HardFault_IRQn 0 */
/* USER CODE END HardFault_IRQn 0 */
while (1)
/* USER CODE BEGIN W1_HardFault_IRQn 0 */
/* USER CODE END W1_HardFault_IRQn 0 */
* @brief This function handles System service call via SWI instruction.
void SVC_Handler(void)
/* USER CODE BEGIN SVC_IRQn 0 */
/* USER CODE END SVC_IRQn 0 */
/* USER CODE BEGIN SVC_IRQn 1 */
/* USER CODE END SVC_IRQn 1 */
* @brief This function handles Pendable request for system service.
void PendSV_Handler(void)
/* USER CODE BEGIN PendSV_IRQn 0 */
/* USER CODE END PendSV_IRQn 0 */
/* USER CODE BEGIN PendSV_IRQn 1 */
/* USER CODE END PendSV_IRQn 1 */
* @brief This function handles System tick timer.
void SysTick_Handler(void)
/* USER CODE BEGIN SysTick_IRQn 0 */
/* USER CODE END SysTick_IRQn 0 */
HAL_IncTick();
/* USER CODE BEGIN SysTick_IRQn 1 */
/* USER CODE END SysTick_IRQn 1 */
/* STM32F0xx Peripheral Interrupt Handlers */
/* Add here the Interrupt Handlers for the used peripherals. */
/* For the available peripheral interrupt handler names, */
/* please refer to the startup file (startup_stm32f0xx.s). */
* @brief This function handles TIM3 global interrupt.
void TIM3_IRQHandler(void)
/* USER CODE BEGIN TIM3_IRQn 0 */
/* USER CODE END TIM3_IRQn 0 */
HAL_TIM_IRQHandler(&htim3);
/* USER CODE BEGIN TIM3_IRQn 1 */
//ab hier selbst eingefügt
while (HAL_GPIO_ReadPin(GPIOA, GPIO_PIN_0) == 0)
//Zustand: schalter aus, knopf nicht gedrückt
i++;
//hier aktueller uhrzeit Systickcount ausgeben
if (i >= 2)
i = 0;
//set_blaueTaste(i);
tic = HAL_GetTick();
while (HAL_GPIO_ReadPin(GPIOA, GPIO_PIN_0) == 1)
//hier Knopf gedrückt
//bspw. Start und Pause
} // hier die zweite uhrzeit notieren
toc = HAL_GetTick();
uint32_t a = toc - tic;
if(a < 1200){
set_blaueTaste(i);
}else if (a >= 1200){
set_blaueTaste1(i);
}else {
HAL_GPIO_WritePin(GPIOA,GPIO_PIN_0,GPIO_PIN_RESET);
HAL_GPIO_WritePin(GPIOC,GPIO_PIN_6,GPIO_PIN_RESET);
HAL_GPIO_WritePin(GPIOC,GPIO_PIN_7,GPIO_PIN_RESET);
HAL_GPIO_WritePin(GPIOC,GPIO_PIN_8,GPIO_PIN_RESET);
HAL_GPIO_WritePin(GPIOC,GPIO_PIN_9,GPIO_PIN_RESET);
/* USER CODE END TIM3_IRQn 1 */
* @brief This function handles USB global interrupt / USB wake-up interrupt through EXTI line 18.
void USB_IRQHandler(void)
/* USER CODE BEGIN USB_IRQn 0 */
/* USER CODE END USB_IRQn 0 */
HAL_PCD_IRQHandler(&hpcd_USB_FS);
/* USER CODE BEGIN USB_IRQn 1 */
/* USER CODE END USB_IRQn 1 */
/* USER CODE BEGIN 1 */
/* USER CODE END 1 */
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
