/* USER CODE BEGIN Header */
* @file stm32f0xx_hal_msp.c
* @brief This file provides code for the MSP Initialization
* and de-Initialization codes.
* @attention
© Copyright (c) 2021 STMicroelectronics.
* All rights reserved.
* This software component is licensed by ST under Ultimate Liberty license
* SLA0044, the "License"; You may not use this file except in compliance with
* the License. You may obtain a copy of the License at:
* www.st.com/SLA0044
/* USER CODE END Header */
/* Includes ------------------------------------------------------------------*/
#include "main.h"
/* USER CODE BEGIN Includes */
/* USER CODE END Includes */
/* Private typedef -----------------------------------------------------------*/
/* USER CODE BEGIN TD */
/* USER CODE END TD */
/* Private define ------------------------------------------------------------*/
/* USER CODE BEGIN Define */
/* USER CODE END Define */
/* Private macro -------------------------------------------------------------*/
/* USER CODE BEGIN Macro */
/* USER CODE END Macro */
/* Private variables ---------------------------------------------------------*/
/* USER CODE BEGIN PV */
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* External functions --------------------------------------------------------*/
/* USER CODE BEGIN ExternalFunctions */
/* USER CODE END ExternalFunctions */
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
* Initializes the Global MSP.
void HAL_MspInit(void)
/* USER CODE BEGIN MspInit 0 */
/* USER CODE END MspInit 0 */
__HAL_RCC_SYSCFG_CLK_ENABLE();
__HAL_RCC_PWR_CLK_ENABLE();
/* System interrupt init*/
/* USER CODE BEGIN MspInit 1 */
/* USER CODE END MspInit 1 */
* @brief I2C MSP Initialization
* This function configures the hardware resources used in this example
* @param hi2c: I2C handle pointer
* @retval None
void HAL_I2C_MspInit(I2C_HandleTypeDef* hi2c)
GPIO_InitTypeDef GPIO_InitStruct = {0};
if(hi2c->Instance==I2C2)
/* USER CODE BEGIN I2C2_MspInit 0 */
/* USER CODE END I2C2_MspInit 0 */
__HAL_RCC_GPIOB_CLK_ENABLE();
/**I2C2 GPIO Configuration
PB10 ------> I2C2_SCL
PB11 ------> I2C2_SDA
GPIO_InitStruct.Pin = I2C2_SCL_Pin|I2C2_SDA_Pin;
GPIO_InitStruct.Mode = GPIO_MODE_AF_OD;
GPIO_InitStruct.Pull = GPIO_PULLUP;
GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
GPIO_InitStruct.Alternate = GPIO_AF1_I2C2;
HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
/* Peripheral clock enable */
__HAL_RCC_I2C2_CLK_ENABLE();
/* USER CODE BEGIN I2C2_MspInit 1 */
/* USER CODE END I2C2_MspInit 1 */
* @brief I2C MSP De-Initialization
* This function freeze the hardware resources used in this example
* @retval None
void HAL_I2C_MspDeInit(I2C_HandleTypeDef* hi2c)
/* USER CODE BEGIN I2C2_MspDeInit 0 */
/* USER CODE END I2C2_MspDeInit 0 */
/* Peripheral clock disable */
__HAL_RCC_I2C2_CLK_DISABLE();
HAL_GPIO_DeInit(I2C2_SCL_GPIO_Port, I2C2_SCL_Pin);
HAL_GPIO_DeInit(I2C2_SDA_GPIO_Port, I2C2_SDA_Pin);
/* USER CODE BEGIN I2C2_MspDeInit 1 */
/* USER CODE END I2C2_MspDeInit 1 */
* @brief SPI MSP Initialization
* @param hspi: SPI handle pointer
* @retval None
void HAL_SPI_MspInit(SPI_HandleTypeDef* hspi)
if(hspi->Instance==SPI2)
/* USER CODE BEGIN SPI2_MspInit 0 */
/* USER CODE END SPI2_MspInit 0 */
__HAL_RCC_SPI2_CLK_ENABLE();
/**SPI2 GPIO Configuration
PB13 ------> SPI2_SCK
PB14 ------> SPI2_MISO
PB15 ------> SPI2_MOSI
GPIO_InitStruct.Pin = SPI2_SCK_Pin|SPI2_MISO_Pin|SPI2_MOSI_Pin;
GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
GPIO_InitStruct.Pull = GPIO_NOPULL;
GPIO_InitStruct.Alternate = GPIO_AF0_SPI2;
/* USER CODE BEGIN SPI2_MspInit 1 */
/* USER CODE END SPI2_MspInit 1 */
* @brief SPI MSP De-Initialization
* @retval None
void HAL_SPI_MspDeInit(SPI_HandleTypeDef* hspi)
/* USER CODE BEGIN SPI2_MspDeInit 0 */
/* USER CODE END SPI2_MspDeInit 0 */
__HAL_RCC_SPI2_CLK_DISABLE();
HAL_GPIO_DeInit(GPIOB, SPI2_SCK_Pin|SPI2_MISO_Pin|SPI2_MOSI_Pin);
/* USER CODE BEGIN SPI2_MspDeInit 1 */
/* USER CODE END SPI2_MspDeInit 1 */
* @brief TIM_Base MSP Initialization
* @param htim_base: TIM_Base handle pointer
* @retval None
void HAL_TIM_Base_MspInit(TIM_HandleTypeDef* htim_base)
if(htim_base->Instance==TIM3)
/* USER CODE BEGIN TIM3_MspInit 0 */
/* USER CODE END TIM3_MspInit 0 */
__HAL_RCC_TIM3_CLK_ENABLE();
/* TIM3 interrupt Init */
HAL_NVIC_SetPriority(TIM3_IRQn, 0, 0);
HAL_NVIC_EnableIRQ(TIM3_IRQn);
/* USER CODE BEGIN TIM3_MspInit 1 */
/* USER CODE END TIM3_MspInit 1 */
* @brief TIM_Base MSP De-Initialization
* @retval None
void HAL_TIM_Base_MspDeInit(TIM_HandleTypeDef* htim_base)
/* USER CODE BEGIN TIM3_MspDeInit 0 */
/* USER CODE END TIM3_MspDeInit 0 */
__HAL_RCC_TIM3_CLK_DISABLE();
/* TIM3 interrupt DeInit */
HAL_NVIC_DisableIRQ(TIM3_IRQn);
/* USER CODE BEGIN TIM3_MspDeInit 1 */
/* USER CODE END TIM3_MspDeInit 1 */
* @brief TSC MSP Initialization
* @param htsc: TSC handle pointer
* @retval None
void HAL_TSC_MspInit(TSC_HandleTypeDef* htsc)
if(htsc->Instance==TSC)
/* USER CODE BEGIN TSC_MspInit 0 */
/* USER CODE END TSC_MspInit 0 */
__HAL_RCC_TSC_CLK_ENABLE();
__HAL_RCC_GPIOA_CLK_ENABLE();
/**TSC GPIO Configuration
PA2 ------> TSC_G1_IO3
PA3 ------> TSC_G1_IO4
PA6 ------> TSC_G2_IO3
PA7 ------> TSC_G2_IO4
PB0 ------> TSC_G3_IO2
PB1 ------> TSC_G3_IO3
GPIO_InitStruct.Pin = GPIO_PIN_2|GPIO_PIN_6;
GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
GPIO_InitStruct.Alternate = GPIO_AF3_TSC;
HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
GPIO_InitStruct.Pin = GPIO_PIN_3|GPIO_PIN_7;
GPIO_InitStruct.Pin = GPIO_PIN_0;
GPIO_InitStruct.Pin = GPIO_PIN_1;
/* USER CODE BEGIN TSC_MspInit 1 */
/* USER CODE END TSC_MspInit 1 */
* @brief TSC MSP De-Initialization
* @retval None
void HAL_TSC_MspDeInit(TSC_HandleTypeDef* htsc)
/* USER CODE BEGIN TSC_MspDeInit 0 */
/* USER CODE END TSC_MspDeInit 0 */
__HAL_RCC_TSC_CLK_DISABLE();
HAL_GPIO_DeInit(GPIOA, GPIO_PIN_2|GPIO_PIN_3|GPIO_PIN_6|GPIO_PIN_7);
HAL_GPIO_DeInit(GPIOB, GPIO_PIN_0|GPIO_PIN_1);
/* USER CODE BEGIN TSC_MspDeInit 1 */
/* USER CODE END TSC_MspDeInit 1 */
/* USER CODE BEGIN 1 */
/* USER CODE END 1 */
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
