* @file stm32f0xx_hal_conf.h
* @brief HAL configuration file.
* @attention
© Copyright (c) 2016 STMicroelectronics.
* All rights reserved.
* This software component is licensed by ST under BSD 3-Clause license,
* the "License"; You may not use this file except in compliance with the
* License. You may obtain a copy of the License at:
* opensource.org/licenses/BSD-3-Clause
/* Define to prevent recursive inclusion -------------------------------------*/
#ifndef __STM32F0xx_HAL_CONF_H
#define __STM32F0xx_HAL_CONF_H
#ifdef __cplusplus
extern "C" {
#endif
/* Exported types ------------------------------------------------------------*/
/* Exported constants --------------------------------------------------------*/
/* ########################## Module Selection ############################## */
* @brief This is the list of modules to be used in the HAL driver
#define HAL_MODULE_ENABLED
/*#define HAL_ADC_MODULE_ENABLED */
/*#define HAL_CRYP_MODULE_ENABLED */
/*#define HAL_CAN_MODULE_ENABLED */
/*#define HAL_CEC_MODULE_ENABLED */
/*#define HAL_COMP_MODULE_ENABLED */
/*#define HAL_CRC_MODULE_ENABLED */
#define HAL_TSC_MODULE_ENABLED
/*#define HAL_DAC_MODULE_ENABLED */
/*#define HAL_I2S_MODULE_ENABLED */
/*#define HAL_IWDG_MODULE_ENABLED */
/*#define HAL_LCD_MODULE_ENABLED */
/*#define HAL_LPTIM_MODULE_ENABLED */
/*#define HAL_RNG_MODULE_ENABLED */
/*#define HAL_RTC_MODULE_ENABLED */
#define HAL_SPI_MODULE_ENABLED
#define HAL_TIM_MODULE_ENABLED
/*#define HAL_UART_MODULE_ENABLED */
/*#define HAL_USART_MODULE_ENABLED */
/*#define HAL_IRDA_MODULE_ENABLED */
/*#define HAL_SMARTCARD_MODULE_ENABLED */
/*#define HAL_SMBUS_MODULE_ENABLED */
/*#define HAL_WWDG_MODULE_ENABLED */
#define HAL_PCD_MODULE_ENABLED
#define HAL_CORTEX_MODULE_ENABLED
#define HAL_DMA_MODULE_ENABLED
#define HAL_FLASH_MODULE_ENABLED
#define HAL_GPIO_MODULE_ENABLED
#define HAL_EXTI_MODULE_ENABLED
#define HAL_PWR_MODULE_ENABLED
#define HAL_RCC_MODULE_ENABLED
#define HAL_I2C_MODULE_ENABLED
/* ########################## HSE/HSI Values adaptation ##################### */
* @brief Adjust the value of External High Speed oscillator (HSE) used in your application.
* This value is used by the RCC HAL module to compute the system frequency
* (when HSE is used as system clock source, directly or through the PLL).
#if !defined (HSE_VALUE)
#define HSE_VALUE ((uint32_t)8000000) /*!< Value of the External oscillator in Hz */
#endif /* HSE_VALUE */
* @brief In the following line adjust the External High Speed oscillator (HSE) Startup
* Timeout value
#if !defined (HSE_STARTUP_TIMEOUT)
#define HSE_STARTUP_TIMEOUT ((uint32_t)100) /*!< Time out for HSE start up, in ms */
#endif /* HSE_STARTUP_TIMEOUT */
* @brief Internal High Speed oscillator (HSI) value.
* (when HSI is used as system clock source, directly or through the PLL).
#if !defined (HSI_VALUE)
#define HSI_VALUE ((uint32_t)8000000) /*!< Value of the Internal oscillator in Hz*/
#endif /* HSI_VALUE */
* @brief In the following line adjust the Internal High Speed oscillator (HSI) Startup
* Timeout value
#if !defined (HSI_STARTUP_TIMEOUT)
#define HSI_STARTUP_TIMEOUT ((uint32_t)5000) /*!< Time out for HSI start up */
#endif /* HSI_STARTUP_TIMEOUT */
* @brief Internal High Speed oscillator for ADC (HSI14) value.
#if !defined (HSI14_VALUE)
#define HSI14_VALUE ((uint32_t)14000000) /*!< Value of the Internal High Speed oscillator for ADC in Hz.
The real value may vary depending on the variations
in voltage and temperature. */
#endif /* HSI14_VALUE */
* @brief Internal High Speed oscillator for USB (HSI48) value.
#if !defined (HSI48_VALUE)
#define HSI48_VALUE ((uint32_t)48000000) /*!< Value of the Internal High Speed oscillator for USB in Hz.
#endif /* HSI48_VALUE */
* @brief Internal Low Speed oscillator (LSI) value.
#if !defined (LSI_VALUE)
#define LSI_VALUE ((uint32_t)40000)
#endif /* LSI_VALUE */ /*!< Value of the Internal Low Speed oscillator in Hz
* @brief External Low Speed oscillator (LSI) value.
#if !defined (LSE_VALUE)
#define LSE_VALUE ((uint32_t)32768) /*!< Value of the External Low Speed oscillator in Hz */
#endif /* LSE_VALUE */
* @brief Time out for LSE start up value in ms.
#if !defined (LSE_STARTUP_TIMEOUT)
#define LSE_STARTUP_TIMEOUT ((uint32_t)5000) /*!< Time out for LSE start up, in ms */
#endif /* LSE_STARTUP_TIMEOUT */
/* Tip: To avoid modifying this file each time you need to use different HSE,
=== you can define the HSE value in your toolchain compiler preprocessor. */
/* ########################### System Configuration ######################### */
* @brief This is the HAL system configuration section
#define VDD_VALUE ((uint32_t)3300) /*!< Value of VDD in mv */
#define TICK_INT_PRIORITY ((uint32_t)0) /*!< tick interrupt priority (lowest by default) */
/* Warning: Must be set to higher priority for HAL_Delay() */
/* and HAL_GetTick() usage under interrupt context */
#define USE_RTOS 0
#define PREFETCH_ENABLE 1
#define INSTRUCTION_CACHE_ENABLE 0
#define DATA_CACHE_ENABLE 0
#define USE_SPI_CRC 0U
#define USE_HAL_ADC_REGISTER_CALLBACKS 0U /* ADC register callback disabled */
#define USE_HAL_CAN_REGISTER_CALLBACKS 0U /* CAN register callback disabled */
#define USE_HAL_COMP_REGISTER_CALLBACKS 0U /* COMP register callback disabled */
#define USE_HAL_CEC_REGISTER_CALLBACKS 0U /* CEC register callback disabled */
#define USE_HAL_DAC_REGISTER_CALLBACKS 0U /* DAC register callback disabled */
#define USE_HAL_I2C_REGISTER_CALLBACKS 0U /* I2C register callback disabled */
#define USE_HAL_SMBUS_REGISTER_CALLBACKS 0U /* SMBUS register callback disabled */
#define USE_HAL_UART_REGISTER_CALLBACKS 0U /* UART register callback disabled */
#define USE_HAL_USART_REGISTER_CALLBACKS 0U /* USART register callback disabled */
#define USE_HAL_IRDA_REGISTER_CALLBACKS 0U /* IRDA register callback disabled */
#define USE_HAL_SMARTCARD_REGISTER_CALLBACKS 0U /* SMARTCARD register callback disabled */
#define USE_HAL_WWDG_REGISTER_CALLBACKS 0U /* WWDG register callback disabled */
#define USE_HAL_RTC_REGISTER_CALLBACKS 0U /* RTC register callback disabled */
#define USE_HAL_SPI_REGISTER_CALLBACKS 0U /* SPI register callback disabled */
#define USE_HAL_I2S_REGISTER_CALLBACKS 0U /* I2S register callback disabled */
#define USE_HAL_TIM_REGISTER_CALLBACKS 0U /* TIM register callback disabled */
#define USE_HAL_TSC_REGISTER_CALLBACKS 0U /* TSC register callback disabled */
#define USE_HAL_PCD_REGISTER_CALLBACKS 0U /* PCD register callback disabled */
/* ########################## Assert Selection ############################## */
* @brief Uncomment the line below to expanse the "assert_param" macro in the
* HAL drivers code
/* #define USE_FULL_ASSERT 1U */
/* Includes ------------------------------------------------------------------*/
* @brief Include module's header file
#ifdef HAL_RCC_MODULE_ENABLED
#include "stm32f0xx_hal_rcc.h"
#endif /* HAL_RCC_MODULE_ENABLED */
#ifdef HAL_GPIO_MODULE_ENABLED
#include "stm32f0xx_hal_gpio.h"
#endif /* HAL_GPIO_MODULE_ENABLED */
#ifdef HAL_EXTI_MODULE_ENABLED
#include "stm32f0xx_hal_exti.h"
#endif /* HAL_EXTI_MODULE_ENABLED */
#ifdef HAL_DMA_MODULE_ENABLED
#include "stm32f0xx_hal_dma.h"
#endif /* HAL_DMA_MODULE_ENABLED */
#ifdef HAL_CORTEX_MODULE_ENABLED
#include "stm32f0xx_hal_cortex.h"
#endif /* HAL_CORTEX_MODULE_ENABLED */
#ifdef HAL_ADC_MODULE_ENABLED
#include "stm32f0xx_hal_adc.h"
#endif /* HAL_ADC_MODULE_ENABLED */
#ifdef HAL_CAN_MODULE_ENABLED
#include "stm32f0xx_hal_can.h"
#endif /* HAL_CAN_MODULE_ENABLED */
#ifdef HAL_CEC_MODULE_ENABLED
#include "stm32f0xx_hal_cec.h"
#endif /* HAL_CEC_MODULE_ENABLED */
#ifdef HAL_COMP_MODULE_ENABLED
#include "stm32f0xx_hal_comp.h"
#endif /* HAL_COMP_MODULE_ENABLED */
#ifdef HAL_CRC_MODULE_ENABLED
#include "stm32f0xx_hal_crc.h"
#endif /* HAL_CRC_MODULE_ENABLED */
#ifdef HAL_DAC_MODULE_ENABLED
#include "stm32f0xx_hal_dac.h"
#endif /* HAL_DAC_MODULE_ENABLED */
#ifdef HAL_FLASH_MODULE_ENABLED
#include "stm32f0xx_hal_flash.h"
#endif /* HAL_FLASH_MODULE_ENABLED */
#ifdef HAL_I2C_MODULE_ENABLED
#include "stm32f0xx_hal_i2c.h"
#endif /* HAL_I2C_MODULE_ENABLED */
#ifdef HAL_I2S_MODULE_ENABLED
#include "stm32f0xx_hal_i2s.h"
#endif /* HAL_I2S_MODULE_ENABLED */
#ifdef HAL_IRDA_MODULE_ENABLED
#include "stm32f0xx_hal_irda.h"
#endif /* HAL_IRDA_MODULE_ENABLED */
#ifdef HAL_IWDG_MODULE_ENABLED
#include "stm32f0xx_hal_iwdg.h"
#endif /* HAL_IWDG_MODULE_ENABLED */
#ifdef HAL_PCD_MODULE_ENABLED
#include "stm32f0xx_hal_pcd.h"
#endif /* HAL_PCD_MODULE_ENABLED */
#ifdef HAL_PWR_MODULE_ENABLED
#include "stm32f0xx_hal_pwr.h"
#endif /* HAL_PWR_MODULE_ENABLED */
#ifdef HAL_RTC_MODULE_ENABLED
#include "stm32f0xx_hal_rtc.h"
#endif /* HAL_RTC_MODULE_ENABLED */
#ifdef HAL_SMARTCARD_MODULE_ENABLED
#include "stm32f0xx_hal_smartcard.h"
#endif /* HAL_SMARTCARD_MODULE_ENABLED */
#ifdef HAL_SMBUS_MODULE_ENABLED
#include "stm32f0xx_hal_smbus.h"
#endif /* HAL_SMBUS_MODULE_ENABLED */
#ifdef HAL_SPI_MODULE_ENABLED
#include "stm32f0xx_hal_spi.h"
#endif /* HAL_SPI_MODULE_ENABLED */
#ifdef HAL_TIM_MODULE_ENABLED
#include "stm32f0xx_hal_tim.h"
#endif /* HAL_TIM_MODULE_ENABLED */
#ifdef HAL_TSC_MODULE_ENABLED
#include "stm32f0xx_hal_tsc.h"
#endif /* HAL_TSC_MODULE_ENABLED */
#ifdef HAL_UART_MODULE_ENABLED
#include "stm32f0xx_hal_uart.h"
#endif /* HAL_UART_MODULE_ENABLED */
#ifdef HAL_USART_MODULE_ENABLED
#include "stm32f0xx_hal_usart.h"
#endif /* HAL_USART_MODULE_ENABLED */
#ifdef HAL_WWDG_MODULE_ENABLED
#include "stm32f0xx_hal_wwdg.h"
#endif /* HAL_WWDG_MODULE_ENABLED */
/* Exported macro ------------------------------------------------------------*/
#ifdef USE_FULL_ASSERT
* @brief The assert_param macro is used for function's parameters check.
* @param expr If expr is false, it calls assert_failed function
* which reports the name of the source file and the source
* line number of the call that failed.
* If expr is true, it returns no value.
* @retval None
#define assert_param(expr) ((expr) ? (void)0U : assert_failed((uint8_t *)__FILE__, __LINE__))
/* Exported functions ------------------------------------------------------- */
void assert_failed(uint8_t* file, uint32_t line);
#else
#define assert_param(expr) ((void)0U)
#endif /* USE_FULL_ASSERT */
#ifdef __cplusplus
#endif
#endif /* __STM32F0xx_HAL_CONF_H */
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
