/* USER CODE BEGIN Header */ /** ****************************************************************************** * @file stm32h7xx_hal_msp.c * @brief This file provides code for the MSP Initialization * and de-Initialization codes. ****************************************************************************** * @attention * *
© Copyright (c) 2021 STMicroelectronics. * All rights reserved.
* * This software component is licensed by ST under BSD 3-Clause license, * the "License"; You may not use this file except in compliance with the * License. You may obtain a copy of the License at: * opensource.org/licenses/BSD-3-Clause * ****************************************************************************** */ /* USER CODE END Header */ /* Includes ------------------------------------------------------------------*/ #include "main.h" /* USER CODE BEGIN Includes */ /* USER CODE END Includes */ extern DMA_HandleTypeDef hdma_spi1_tx; extern DMA_HandleTypeDef hdma_spi1_rx; /* Private typedef -----------------------------------------------------------*/ /* USER CODE BEGIN TD */ /* USER CODE END TD */ /* Private define ------------------------------------------------------------*/ /* USER CODE BEGIN Define */ /* USER CODE END Define */ /* Private macro -------------------------------------------------------------*/ /* USER CODE BEGIN Macro */ /* USER CODE END Macro */ /* Private variables ---------------------------------------------------------*/ /* USER CODE BEGIN PV */ /* USER CODE END PV */ /* Private function prototypes -----------------------------------------------*/ /* USER CODE BEGIN PFP */ /* USER CODE END PFP */ /* External functions --------------------------------------------------------*/ /* USER CODE BEGIN ExternalFunctions */ /* USER CODE END ExternalFunctions */ /* USER CODE BEGIN 0 */ /* USER CODE END 0 */ /** * Initializes the Global MSP. */ void HAL_MspInit(void) { /* USER CODE BEGIN MspInit 0 */ /* USER CODE END MspInit 0 */ __HAL_RCC_SYSCFG_CLK_ENABLE(); /* System interrupt init*/ /* USER CODE BEGIN MspInit 1 */ HAL_NVIC_SetPriorityGrouping(NVIC_PRIORITYGROUP_0); /* USER CODE END MspInit 1 */ } /** * @brief I2S MSP Initialization * This function configures the hardware resources used in this example * @param hi2s: I2S handle pointer * @retval None */ void HAL_I2S_MspInit(I2S_HandleTypeDef* hi2s) { GPIO_InitTypeDef GPIO_InitStruct = {0}; if(hi2s->Instance==SPI1) { /* USER CODE BEGIN SPI1_MspInit 0 */ /* USER CODE END SPI1_MspInit 0 */ /* Peripheral clock enable */ __HAL_RCC_SPI1_CLK_ENABLE(); /* Hinzugefügt, unklar ob notwendig */ __HAL_RCC_DMA1_CLK_ENABLE(); __HAL_RCC_GPIOA_CLK_ENABLE(); __HAL_RCC_GPIOC_CLK_ENABLE(); /**I2S1 GPIO Configuration PA4 ------> I2S1_WS PA5 ------> I2S1_CK PA6 ------> I2S1_SDI PA7 ------> I2S1_SDO PC4 ------> I2S1_MCK */ GPIO_InitStruct.Pin = GPIO_PIN_4|GPIO_PIN_5|GPIO_PIN_6|GPIO_PIN_7; GPIO_InitStruct.Mode = GPIO_MODE_AF_PP; GPIO_InitStruct.Pull = GPIO_NOPULL; GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW; GPIO_InitStruct.Alternate = GPIO_AF5_SPI1; HAL_GPIO_Init(GPIOA, &GPIO_InitStruct); GPIO_InitStruct.Pin = GPIO_PIN_4; GPIO_InitStruct.Mode = GPIO_MODE_AF_PP; GPIO_InitStruct.Pull = GPIO_NOPULL; GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW; GPIO_InitStruct.Alternate = GPIO_AF5_SPI1; HAL_GPIO_Init(GPIOC, &GPIO_InitStruct); /* I2S1 DMA Init */ /* SPI1_TX Init */ hdma_spi1_tx.Instance = DMA1_Stream1; hdma_spi1_tx.Init.Request = DMA_REQUEST_SPI1_TX; hdma_spi1_tx.Init.Direction = DMA_MEMORY_TO_PERIPH; hdma_spi1_tx.Init.PeriphInc = DMA_PINC_DISABLE; hdma_spi1_tx.Init.MemInc = DMA_MINC_ENABLE; hdma_spi1_tx.Init.PeriphDataAlignment = DMA_PDATAALIGN_HALFWORD; hdma_spi1_tx.Init.MemDataAlignment = DMA_MDATAALIGN_HALFWORD; hdma_spi1_tx.Init.Mode = DMA_CIRCULAR; hdma_spi1_tx.Init.Priority = DMA_PRIORITY_HIGH; hdma_spi1_tx.Init.FIFOMode = DMA_FIFOMODE_DISABLE; if (HAL_DMA_Init(&hdma_spi1_tx) != HAL_OK) { Error_Handler(); } __HAL_LINKDMA(hi2s,hdmatx,hdma_spi1_tx); /* Deinitialize & Initialize the DMA for new transfer */ HAL_DMA_DeInit(&hdma_spi1_tx); HAL_DMA_Init(&hdma_spi1_tx); /* SPI1_RX Init */ hdma_spi1_rx.Instance = DMA1_Stream0; hdma_spi1_rx.Init.Request = DMA_REQUEST_SPI1_RX; hdma_spi1_rx.Init.Direction = DMA_PERIPH_TO_MEMORY; hdma_spi1_rx.Init.PeriphInc = DMA_PINC_DISABLE; hdma_spi1_rx.Init.MemInc = DMA_MINC_ENABLE; hdma_spi1_rx.Init.PeriphDataAlignment = DMA_PDATAALIGN_HALFWORD; hdma_spi1_rx.Init.MemDataAlignment = DMA_MDATAALIGN_HALFWORD; hdma_spi1_rx.Init.Mode = DMA_CIRCULAR; hdma_spi1_rx.Init.Priority = DMA_PRIORITY_HIGH; hdma_spi1_rx.Init.FIFOMode = DMA_FIFOMODE_DISABLE; if (HAL_DMA_Init(&hdma_spi1_rx) != HAL_OK) { Error_Handler(); } __HAL_LINKDMA(hi2s,hdmarx,hdma_spi1_rx); /* Deinitialize & Initialize the DMA for new transfer */ HAL_DMA_DeInit(&hdma_spi1_rx); HAL_DMA_Init(&hdma_spi1_rx); /* USER CODE BEGIN SPI1_MspInit 1 */ /* USER CODE END SPI1_MspInit 1 */ } } /** * @brief I2S MSP De-Initialization * This function freeze the hardware resources used in this example * @param hi2s: I2S handle pointer * @retval None */ void HAL_I2S_MspDeInit(I2S_HandleTypeDef* hi2s) { if(hi2s->Instance==SPI1) { /* USER CODE BEGIN SPI1_MspDeInit 0 */ /* USER CODE END SPI1_MspDeInit 0 */ /* Peripheral clock disable */ __HAL_RCC_SPI1_CLK_DISABLE(); /**I2S1 GPIO Configuration PA4 ------> I2S1_WS PA5 ------> I2S1_CK PA6 ------> I2S1_SDI PA7 ------> I2S1_SDO PC4 ------> I2S1_MCK */ HAL_GPIO_DeInit(GPIOA, GPIO_PIN_4|GPIO_PIN_5|GPIO_PIN_6|GPIO_PIN_7); HAL_GPIO_DeInit(GPIOC, GPIO_PIN_4); /* I2S1 DMA DeInit */ HAL_DMA_DeInit(hi2s->hdmatx); HAL_DMA_DeInit(hi2s->hdmarx); /* USER CODE BEGIN SPI1_MspDeInit 1 */ /* USER CODE END SPI1_MspDeInit 1 */ } } /* USER CODE BEGIN 1 */ /* USER CODE END 1 */ /************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
