int A0_wert; float Spannung_Solar; float Batterie_Kapazitaet; void setup() { Serial.begin(115200); } void loop() { A0_wert = analogRead(A0); Spannung_Solar = ((A0_wert / 1024.0) * 5) ; Batterie_Kapazitaet = map(Spannung_Solar , 4.2 , 3 , 100 , 0 ); Serial.print(" VA = "); Serial.println(Spannung_Solar); Serial.print(" % "); Serial.println(Batterie_Kapazitaet); delay(1000); }
