/* originally based on W.S. VCP implenentation while it should be still compatible with the original one found at http://stefanfrings.de/stm32/STM32F103_usb_test.zip Several changes are made to be more flexible Tested on various BluePill boards with STM and WCH controllers (F103XXX) Changes - put all cfg options at the beginning - make them available as config menu in keil - indroduced two header files for the specs - introduceed IAD which is supported since XP SP3 todo: - use bidirectional EPs - init bulk & interrupt Eps after SetConfiguration(1) - disable bulk & interrupt Eps after SetConfiguration(0) - prepare for more than one VCP port */ #include "usb.h" #include "usb11.h" //usb1.1 spec #include "usbcdc12.h" //cdc1.2 spec /* the following comment has to be within the first 100 lines to activate the config wizard in keil */ // <<< Use Configuration Wizard in Context Menu >>> /* Config params to setup by user 1. CORE params UMEMSHIFT <0|1> activate for devices that dont have continious usb memory USB_IRQ_NUMBER <0..31> check the datasheet for the correct value ENABLE_TRACING <0|1> activate to allow trace messages via SWO 2. USB params USB_VID VendorId for this device USB_PID ProductId for this device BCD_DEVICE Firmware Version 0x0100 -> v1.00 USB_SERIAL_NO <0|1> activate to use the 12 byte UID from the chip 3. VCP params VCP_NUM_PORTS <1..4> not yet implemmented -> EP1..EP4 */ // Configuration for STM bare metal VCP // CORE params // UMEMSHIFT <0=> off // <1=> on // Off for devices with 2 x 16 bits / uint16_t access schema // e.g. STM32L0x2, STM32L0x3, STM32F0x2, STM32F303xD and xE // On for devices with 1 x 16 bits / uint16_t access schema // e.g. STM32F103, STM32F302, STM32F303xB and xC // ********************************************************* #define UMEM_SHIFT 1 // ********************************************************* // USB_IRQ_NUMBER <0-31> // Take this number from the reference manual for your controller // ********************************************************* #define USB_IRQ_NUMBER 20 // ********************************************************* // ENABLE_TRACING <0=> false // <0=> true // Allow trace messages for debug via SWO // ********************************************************* #define ENABLE_TRACING 0 // ********************************************************* // // USB params // USB_VID <0-0xFFFF> // USB Vendor ID // ********************************************************* #define USB_VID 0x0416 // ********************************************************* // USB_PID <0-0xFFFF> // USB Prodct ID // ********************************************************* #define USB_PID 0x5011 // ********************************************************* // BCD_DEVICE <0-0xFFFF> // set the reported device revision 0x0100 -> 1.0 // ********************************************************* #define BCD_DEVICE 0x0100 // ********************************************************* // USB_SERIAL_NO <0=> none // <1=> use chip UID // activate if you want a USB serial number // ********************************************************* #define USB_SERIAL_NO 1 // ********************************************************* #define VCP_IN_EP 0x81 #define VCP_OUT_EP 0x02 #define VCP_STAT_EP 0x83 //for now just use this // // VCP params // VCP_NUM_PORTS <1-4> // ********************************************************* #define VCP_NUM_PORTS 1 //only 1 is supported at this time // ********************************************************* // <<< end of configuration section >>> // create some names later used by the usb firmware // set UMEM_FAKEWIDTH acorting to UMEM_SHIFT #if UMEM_SHIFT #define UMEM_FAKEWIDTH uint32_t #else #define UMEM_FAKEWIDTH uint16_t #endif // each port needs 2 interfaces #define MAX_INTERFACES (2*VCP_NUM_PORTS) // put the interrupt EP behind //#define VCP_STAT_EP (HOST_ | VCP_NUM_PORTS+1) /* The name of the IRQ handler must match startup_stm32.s */ #define NAME_OF_USB_IRQ_HANDLER USB_LP_CAN_RX0_IRQHandler #if ENABLE_TRACING #include #define ITM_PORT0_8 (*(volatile char *)(0xE0000000UL)) #define ITM_PORT0_32 (*(volatile unsigned long *)(0xE0000000UL)) #define ITM_TER (*(volatile unsigned long *)(0xE0000E00UL)) #define ITM_TCR (*(volatile unsigned long *)(0xE0000E80UL)) static void trace(char *ptr) { while (*ptr) { if (((ITM_TCR & 1UL) != 0UL) && // ITM enabled ((ITM_TER & 1UL) != 0UL)) // ITM and port 0 enabled { while (ITM_PORT0_32 == 0UL) { asm volatile("NOP"); } ITM_PORT0_8 = *ptr; } ptr++; } } #else #define trace(msg) // nothing #endif #if USB_SERIAL_NO #define U_ID_SIZE 12 // in bytes #define U_ID (*(volatile uint8_t *)( 0x1FFFF7E8UL)) uint8_t SerialString[U_ID_SIZE * 2 * sizeof(uint16_t) +2]; uint8_t toAscii (uint8_t digit) { digit &= 0x0F; return ((digit < 10) ? digit + '0' : digit +('A'- 10)); } void InitSerial(void) { uint8_t *s = &SerialString[0]; uint8_t b; int i; for (i=0; i < sizeof(SerialString); i++) SerialString[i]=0; //memset *s++ = U_ID_SIZE *2 * sizeof(uint16_t) +2; *s++ = 0x03; i = U_ID_SIZE-1; //0..11 while(i > -1) //rückwärts lesen { b = U_ID + i; *s = toAscii(b); s += 2; *s = toAscii(b >> 4); s += 2; i--; } } #else #define InitSerial() // nothing #endif /* Example trace messages with Linux: [12:38:53:344] setup [12:38:53:345] InitEndpoints [12:38:53:347] setAddr adr=0 connect USB cable [12:38:57:446] RESET [12:38:57:447] InitEndpoints [12:38:57:449] setAddr adr=0 [12:38:57:831] SUSP [12:38:57:831] RESET [12:38:57:834] InitEndpoints [12:38:57:834] setAddr adr=0 [12:38:57:900] CTR out [12:38:57:903] logEpCtrl [12:38:57:903] SETUP [12:38:57:903] rdCtrlBlock maxlen=8, count=8 [12:38:57:907] clrBuf logEpNum=0 [12:38:57:907] isStandardRequest [12:38:57:910] GET_DESCRIPTOR [12:38:57:910] doGetDescr type 0001 [12:38:57:913] descDevice [12:38:57:913] wrCtrlBlock count=18 [12:38:57:916] validateBuf logEpNum=0 [12:38:57:916] CTR in [12:38:57:916] logEpCtrl [12:38:57:919] IsStandardRequest [12:38:57:919] GET_DESCRIPTOR [12:38:57:922] CTR out [12:38:57:922] logEpCtrl [12:38:57:922] EpCtrlOut [12:38:57:925] IsStandardRequest [12:38:57:925] rdCtrlBlock maxlen=64, count=0 [12:38:57:929] clrBuf logEpNum=0 [12:38:57:929] RESET [12:38:57:929] InitEndpoints [12:38:57:932] setAddr adr=0 [12:38:57:996] CTR out [12:38:58:002] logEpCtrl [12:38:58:002] SETUP [12:38:58:002] rdCtrlBlock maxlen=8, count=8 [12:38:58:002] clrBuf logEpNum=0 [12:38:58:009] isStandardRequest [12:38:58:009] SET_ADDRESS [12:38:58:009] wrCtrlBlock count=0 [12:38:58:009] validateBuf logEpNum=0 [12:38:58:009] setAddr adr=37 [12:38:58:017] CTR in [12:38:58:017] logEpCtrl [12:38:58:017] IsStandardRequest [12:38:58:017] default [12:38:58:017] wrCtrlBlock count=0 [12:38:58:017] validateBuf logEpNum=0 [12:38:58:031] CTR out [12:38:58:031] logEpCtrl [12:38:58:031] SETUP [12:38:58:031] rdCtrlBlock maxlen=8, count=8 [12:38:58:038] clrBuf logEpNum=0 [12:38:58:038] isStandardRequest [12:38:58:038] GET_DESCRIPTOR [12:38:58:038] doGetDescr type 0001 [12:38:58:045] descDevice [12:38:58:045] wrCtrlBlock count=18 [12:38:58:045] validateBuf logEpNum=0 [12:38:58:045] CTR in [12:38:58:045] logEpCtrl [12:38:58:049] IsStandardRequest [12:38:58:049] GET_DESCRIPTOR [12:38:58:049] CTR out [12:38:58:049] logEpCtrl [12:38:58:049] EpCtrlOut [12:38:58:053] IsStandardRequest [12:38:58:053] rdCtrlBlock maxlen=64, count=0 [12:38:58:057] clrBuf logEpNum=0 */ /* die Transfer-Puffer für zeichenweises In und Out über den USB */ #define txLen 256 volatile char UsbTxBuf[txLen]; volatile int txr, txw; #define rxLen 256 volatile char UsbRxBuf[rxLen]; volatile int rxr, rxw; volatile bool receiving = false; volatile bool transmitting = false; /*************************** Konstanten ********************************/ /* Cortex-M NVIC Register */ #define NVIC_ISER (*(volatile uint32_t (*) [16])(0xE000E100)) #define NVIC_ICER (*(volatile uint32_t (*) [16])(0xE000E180)) /* Alle USB-Register sind 16 Bit breit, müssen aber 32 bittig gelesen und geschrieben werden Auch der USB-RAM von 512 Bytes ist 16 oder 32 bittig zu behandeln (aber mit Vorsicht!) */ /* USB device (base address 0x4000 5C00) */ #define USB_BASE 0x40005C00 #define USB_EpRegs(x) (*(volatile uint32_t *)(0x40005C00 + 4*(x))) #define USB_EP0R (*(volatile uint32_t *)(0x40005C00)) #define USB_EP1R (*(volatile uint32_t *)(0x40005C04)) #define USB_EP2R (*(volatile uint32_t *)(0x40005C08)) #define USB_EP3R (*(volatile uint32_t *)(0x40005C0C)) #define USB_EP4R (*(volatile uint32_t *)(0x40005C10)) #define USB_EP5R (*(volatile uint32_t *)(0x40005C14)) #define USB_EP6R (*(volatile uint32_t *)(0x40005C18)) #define USB_EP7R (*(volatile uint32_t *)(0x40005C1C)) #define USB_CNTR (*(volatile uint32_t *)(0x40005C40)) #define USB_ISTR (*(volatile uint32_t *)(0x40005C44)) #define USB_FNR (*(volatile uint32_t *)(0x40005C48)) #define USB_DADDR (*(volatile uint32_t *)(0x40005C4C)) #define USB_BTABLE (*(volatile uint32_t *)(0x40005C50)) /* Bits in USB_CNTR */ #define FRES (1<<0) #define PDWN (1<<1) #define LP_MODE (1<<2) #define FSUSP (1<<3) #define RESUME (1<<4) #define ESOFM (1<<8) #define SOFM (1<<9) #define RESETM (1<<10) #define SUSPM (1<<11) #define WKUPM (1<<12) #define ERRM (1<<13) #define PMAOVRM (1<<14) #define CTRM (1<<15) /* Bits in USB_ISTR */ #define DIR (1<<4) #define ESOF (1<<8) #define SOF (1<<9) #define RESET (1<<10) #define SUSP (1<<11) #define WKUP (1<<12) #define ERR (1<<13) #define PMAOVR (1<<14) #define CTR (1<<15) /* Bits in den USB_EPnR */ #define CTR_RX (1<<15) #define DTOG_RX (1<<14) #define STAT_RX (3<<12) #define SETUP (1<<11) #define EP_TYPE (3<<9) #define EP_KIND (1<<8) #define CTR_TX (1<<7) #define DTOG_TX (1<<6) #define STAT_TX (3<<4) #define MASK_EA (15) /* EndPoint Register Mask (No Toggle Fields) */ #define EP_NoToggleBits (CTR_RX|SETUP|EP_TYPE|EP_KIND|CTR_TX|MASK_EA) /******* Zuordnung physischer Endpunkte 0..7 ********************/ #define logEpCtrl 0 #define logEpBulkIn 1 #define logEpBulkOut 2 #define logEpInt 3 /* für Stall, Unstall usw. */ #define phys_In 0x80 #define physEpCtrlIn (0 + 0x80) #define physEpCtrlOut 0 #define physEpBulkIn (1 + 0x80) #define physEpBulkOut 2 #define physEpIntIn (3 + 0x80) #define physEpIntOut 3 /* Achtung: Die folgende Sonderlocke bezüglich der Speicher-Lücken gilt nicht für STM32F303xD and xE! Layout des USB RAM's (512 Bytes) ================================ Der RAM geht aus Sicht der CPU von 0x40006000 bis 0x400063FF, also 0x400 Bytes gleich 1024 Bytes und das Layout ist krütig, weil die Hälfte nicht implementiert ist und zu 0 gelesen wird! Er ist NUR 16 bitweise les- und schreibbar! NICHT byteweise und auch nicht wirklich 32 bitweise. Beispiel: Text sei "Hello-World" 0x40006000: 48 65 00 00 6C 6C 00 00 6F 2D 00 00 57 6F 00 00 72 6C 00 00 64 ... H e l l o - W o r l d ... ab Offset 0: Control_In 64 Bytes Control_Out 64 Bytes Bulk_In_A 64 Bytes (evtl. DoubleBuffered) Bulk_In_B 64 Bytes Bulk_Out_A 64 Bytes (evtl. DoubleBuffered) Bulk_Out_B 64 Bytes Int_In 8 Bytes (hier nicht benutzt) Int_Out 8 Bytes (hier nicht benutzt) ----------------------- macht 400 Bytes anschließend EpTable (USB_BTABLE zeigt drauf) mit 4 Einträgen (Control, BulkIn, BuklOut, Int) zu je 4 dwords also 4*4 dwords = 64 Bytes macht in Summe 464 Bytes */ #define USB_RAM 0x40006000 #define EpCtrlMaxLen 64 #define EpCtrlLenId ((1<<15)|(1<<10)) #define EpBulkMaxLen 64 #define EpBulkLenId ((1<<15)|(1<<10)) #define EpIntMaxLen 8 #define EpIntLenId (4<<10) /******* Pufferlängen und Längen-Codes *******/ /* EP0 = control */ #define Ep0TxOffset 0 /* 64 Bytes ab 0 */ #define Ep0RxOffset 64 /* 64 Bytes ab 64 */ /* EP1 = Bulk-IN */ #define Ep1TxAOffset 128 /* 64 Bytes ab 128 */ #define Ep1TxBOffset 192 /* 64 Bytes ab 192 */ /* EP2 = Bulk-OUT */ #define Ep2RxAOffset 256 /* 64 Bytes ab 256 */ #define Ep2RxBOffset 320 /* 64 Bytes ab 320 */ /* EP3 = Int (unbenutzt) */ #define Ep3TxOffset 384 /* 8 Bytes ab 384 */ #define Ep3RxOffset 292 /* 8 Bytes ab 392 */ /* EP-Tafel */ #define EpTableOffset 400 /* 64 Bytes ab 400 */ #define EPControlTxBuffer (USB_RAM + (Ep0TxOffset<>8, // usb 1.1 USB_CLASS_UNDEFINED, // no class or subclass USB_SUBCLASS_UNDEFINED, // its done at interface level USB_PROTOCOL_UNDEFINED, EpCtrlMaxLen, // can be 8 | 16 | 32 | 64 USB_VID & 0xFF, USB_VID >> 8, USB_PID & 0xFF, USB_PID >> 8, BCD_DEVICE & 0xFF, BCD_DEVICE >> 8, 0x01, // Vendor string 0x02, // Device string #if USB_SERIAL_NO 0x03, #else 0x00, #endif 0x01 /* bNumConfigurations */ }; const uint8_t ConfigDesc[0x43+8] = { sizeof(ConfigurationDescriptor), USB_CONFIGURATION_DESCRIPTOR, sizeof(ConfigDesc), // wTotalLength sizeof(ConfigDesc) >> 8, MAX_INTERFACES, 0x01, // bConfigurationValue USB_STRING_UNDEFINED, 0xC0, // bmAttributes 100/2, // 100mA low power device sizeof(IadDescriptor), USB_IAD_DESCRIPTOR, 0, // first interface = 0 2, // 2 interfaces USB_CLASS_CDC, CDC_SUBCLASS_ABSTRACT, CDC_PROTOCOL_V250, USB_STRING_UNDEFINED, /* INTERFACE descriptor */ sizeof(InterfaceDescriptor), USB_INTERFACE_DESCRIPTOR, 0x00, /* bInterfaceNumber */ 0x00, /* bAlternateSetting */ 0x01, /* bNumEndpoints */ USB_CLASS_CDC, CDC_SUBCLASS_ABSTRACT, CDC_PROTOCOL_V250, USB_STRING_UNDEFINED, /* Communication Class Specified INTERFACE descriptor */ 0x05, CDC_CS_INTERFACE, CDC_SUB_HEADER, BCD_CDC &0xFF,BCD_CDC >>8, /* Communication Class Specified INTERFACE descriptor */ 0x05, CDC_CS_INTERFACE, CDC_SUB_CALL_FUNCTION, 0x00, /* BIT0: Whether device handle call management itself. */ /* BIT1: Whether device can send/receive call */ /* management information over a Data Class Interface 0 */ 0x01, // Interface number of data class interface // Communication Class Specified INTERFACE descriptor 0x04, CDC_CS_INTERFACE, CDC_SUB_ABSTRACT_CTRL, 0x00, // bmCapabilities none // Communication Class Specified INTERFACE descriptor 0x05, CDC_CS_INTERFACE, CDC_SUB_UNION_FUNCTIONAL, 0x00, /* bMasterInterface */ 0x01, /* bSlaveInterface0 */ // ENDPOINT descriptor für Interrupt sizeof(EndpointDescriptor), USB_ENDPOINT_DESCRIPTOR, VCP_STAT_EP, EP_INTERRUPT, EpIntMaxLen, 0x00, 0x01, // INTERFACE descriptor for send & recive sizeof(InterfaceDescriptor), USB_INTERFACE_DESCRIPTOR, 0x01, // interface no 1 0x00, // no alternaze settings 0x02, // 2 Enpoints CDC_CLASS_DATA, // data interface CDC_SUBCLASS_RESERVED, // has no subclass or protocol CDC_PROTOCOL_UNDEFINED, CDC_PROTOCOL_UNDEFINED, /* ENDPOINT descriptor für Bulk IN */ sizeof(EndpointDescriptor), USB_ENDPOINT_DESCRIPTOR, VCP_IN_EP, EP_BULK, EpBulkMaxLen, 0x00, 0, /* ENDPOINT descriptor für Bulk OUT */ sizeof(EndpointDescriptor), USB_ENDPOINT_DESCRIPTOR, VCP_OUT_EP, EP_BULK, EpBulkMaxLen, 0x00, 0 }; const uint8_t LangString[4] = { 4, USB_STRING_DESCRIPTOR, 0x09, 0x04 /* Language ID: USA(0x0409) */ }; const uint8_t VendorString[16] = { sizeof(VendorString), USB_STRING_DESCRIPTOR, 'N', 0, 'u', 0, 'v', 0, 'o', 0, 't', 0, 'o', 0, 'n', 0 }; const uint8_t ProductString[32] = { sizeof(ProductString), USB_STRING_DESCRIPTOR, 'U', 0, 'S', 0, 'B', 0, ' ', 0, 'V', 0, 'i', 0, 'r', 0, 't', 0, 'u', 0, 'a', 0, 'l', 0, ' ', 0, 'C', 0, 'O', 0, 'M', 0 }; /* um Nullbyte oder ein leeres Paket senden zu können */ const uint8_t always0 = 0; /************ Hilfsroutinen ************************************************/ void EnableUsbIRQ (void) { NVIC_ISER[USB_IRQ_NUMBER/32] = ((uint32_t) 1) << (USB_IRQ_NUMBER % 32); } // Not used void DisableUsbIRQ (void) { NVIC_ICER[USB_IRQ_NUMBER/32] = ((uint32_t) 1) << (USB_IRQ_NUMBER % 32); } void StallLogEP(int logEpNum); void Stall(int physEpNum) { trace("stall\n"); uint32_t D, S, Maske; int logEpNum; logEpNum = physEpNum & 0x0F; if (logEpNum == physEpNum) { Maske = EP_NoToggleBits | STAT_RX; // ohne STAT_TX und ohne beide DTOG_x S = 1 << 12; } else { Maske = EP_NoToggleBits | STAT_TX; // ohne STAT_RX und ohne beide DTOG_x S = 1 << 4; } D = USB_EpRegs(logEpNum); USB_EpRegs(logEpNum) = (D ^ S) & Maske; } void UnStall_In(int physEpNum) { uint32_t reg; uint32_t mask; uint32_t status; mask = EP_NoToggleBits; status = (USB_EpRegs(physEpNum & 0x07) >> 4) & 0x03; if (status==1) //In stalled? { // toggle bit 5:4 01 -> 10 reg = USB_EpRegs(physEpNum & 0x07) & mask; USB_EpRegs(physEpNum & 0x07) = (reg | (3 << 4)); } } void UnStall_Out(int physEpNum) { uint32_t reg; uint32_t mask; uint32_t status; mask = EP_NoToggleBits; status = (USB_EpRegs(physEpNum & 0x07) >> 12) & 0x03; if (status==1) // Out stalled? { // toggle bit 13:12 01 -> 11 reg = USB_EpRegs(physEpNum & 0x07) & mask; USB_EpRegs(physEpNum & 0x07) = (reg | (2 << 12)); } } /** unstall a Endpoint Change only TX (for IN) or RX (for OUT) leave all other fields unchanged if the Endpoint is not stalled change nothing */ void UnStall(int physEpNum) { if (physEpNum & HOST_) // HOST_ bit set means In EPs { UnStall_In(physEpNum); } else // to it for Out EPs { UnStall_Out(physEpNum); } } void StallLogEP(int logEpNum) { Stall(logEpNum); Stall(logEpNum | phys_In); } /* void UnStallLogEP(int logEpNum) { UnStall(logEpNum); UnStall(logEpNum | phys_In); } */ /* Endpoint empfangsbereit machen, also STAT_RX auf 11 setzen per Toggle */ void ClearBuffer(int logEpNum) { #if ENABLE_TRACING char buf[30]; sprintf(buf,"clrBuf logEpNum=%i\n",logEpNum); trace(buf); #endif uint32_t D, Maske; Maske = EP_NoToggleBits | STAT_RX; /* ohne STAT_TX und ohne beide DTOG_x */ D = USB_EpRegs(logEpNum); USB_EpRegs(logEpNum) = (D ^ STAT_RX) & Maske; } /* Endpoint sendebereit machen, also STAT_TX auf 11 setzen per Toggle */ void ValidateBuffer(int logEpNum) { #if ENABLE_TRACING char buf[30]; sprintf(buf,"validateBuf logEpNum=%i\n",logEpNum); trace(buf); #endif uint32_t D, Maske; Maske = EP_NoToggleBits | STAT_TX; /* ohne STAT_RX und ohne beide DTOG_x */ D = USB_EpRegs(logEpNum); USB_EpRegs(logEpNum) = (D ^ STAT_TX) & Maske; } bool USB_SetAddress(uint8_t adr) { #if ENABLE_TRACING char buf[30]; sprintf(buf,"setAddr adr=%i\n",adr); trace(buf); #endif USB_DADDR = 0x80 | adr; return true; } bool USB_ConfigDevice(bool obConf) { return true; // nix bei diesem Core zu tun. } /* physische Endpunkte aufsetzen (bei Reset-Kommando usw.) */ void InitEndpoints(void) { trace("InitEndpoints\n"); USB_CNTR = 1; /* erstmal Reset und alle Ints aus */ CMD.Configuration = 0; /* vor "CONFIGURED" ist hier nix */ CMD.TransferLen = 0; /* es stehen ab hier auch */ CMD.PacketLen = 0; /* keine Transfers an */ CMD.TransferPtr = 0; USB_CNTR = 0; /* alle Ints aus */ suspended = false; configurationSet = false; transmitting = false; /* EP0 = Control, IN und OUT */ EpTable[0].TxOffset = Ep0TxOffset; EpTable[0].TxCount = 0; EpTable[0].RxOffset = Ep0RxOffset; EpTable[0].RxCount = EpCtrlLenId; /* EP1 = Bulk IN (nur IN) */ EpTable[1].TxOffset = Ep1TxAOffset; EpTable[1].TxCount = 0; EpTable[1].RxOffset = Ep1TxBOffset; /* hier 2. TxPuffer */ EpTable[1].RxCount = EpBulkLenId; /* erstmal.. */ /* EP2 = Bulk OUT (nur OUT) */ EpTable[2].TxOffset = Ep2RxAOffset; EpTable[2].TxCount = EpBulkLenId; EpTable[2].RxOffset = Ep2RxBOffset; EpTable[2].RxCount = EpBulkLenId; /* EP3 = Int, IN und OUT */ EpTable[3].TxOffset = Ep3TxOffset; EpTable[3].TxCount = EpIntLenId; EpTable[3].RxOffset = Ep3RxOffset; EpTable[3].RxCount = EpIntLenId; USB_BTABLE = EpTableOffset; USB_EP0R = (3 << 12) | /* STAT_RX = 3, also Empfang enabled */ (2 << 4) | /* STAT_TX = 2, also NAK erstmal */ (1 << 9) | /* EP_TYPE = 1, also Control */ logEpCtrl; USB_EP1R = (0 << 12) | /* STAT_RX = 0, also Empfang disabled */ (2 << 4) | /* STAT_TX = 2, also NAK erstmal */ (0 << 9) | /* EP_TYPE = 0, also Bulk */ logEpBulkIn; USB_EP2R = (3 << 12) | /* STAT_RX = 3, also Empfang enabled */ (0 << 4) | /* STAT_TX = 0, also Senden disabled */ (0 << 9) | /* EP_TYPE = 0, also Bulk */ logEpBulkOut; USB_EP3R = (3 << 12) | /* STAT_RX = 3, also Empfang enabled */ (2 << 4) | /* STAT_TX = 2, also NAK erstmal */ (3 << 9) | /* EP_TYPE = 0, also Bulk */ logEpInt; USB_ISTR = 0; /* pending Interrupts beseitigen */ USB_CNTR = CTRM | /* Int bei ACKed Paketen in oder out */ RESETM | /* Int bei Reset */ SUSPM | WKUPM | ESOFM | SOFM; /* Int bei 1 ms Frame */ USB_SetAddress(0); } void Nop(uint32_t count) { while (count) { asm volatile ("NOP"); count--; } } int ReadControlBlock(uint8_t* PBuffer, int maxlen) { int count, i, n; UMEM_FAKEWIDTH D; UMEM_FAKEWIDTH* P; count = EpTable[0].RxCount & 0x3FF; #if ENABLE_TRACING char buf[40]; sprintf(buf,"rdCtrlBlock maxlen=%i, count=%i\n",maxlen,count); trace(buf); #endif if (count > maxlen) count = maxlen; if (count) { P = (UMEM_FAKEWIDTH*) EPControlRxBuffer; n = 2; i = count; D = *P++; while (i > 0) { *PBuffer = D & 0xFF; D = D >> 8; --n; if (!n) { D = *P++; n = 2; } --i; ++PBuffer; } } ClearBuffer(logEpCtrl); return count; } int WriteControlBlock(uint8_t* PBuffer, int count) { #if ENABLE_TRACING char buf[30]; sprintf(buf,"wrCtrlBlock count=%i\n",count); trace(buf); #endif UMEM_FAKEWIDTH A, L; UMEM_FAKEWIDTH* P; int i, n; if (count > EpCtrlMaxLen) count = EpCtrlMaxLen; EpTable[0].TxCount = count; if (count) { A = 0; i = 0; n = 0; P = (UMEM_FAKEWIDTH*) EPControlTxBuffer; while (i < count) { L = *PBuffer++; A = A | (L << n); n += 8; if (n > 8) { n = 0; *P++ = A; A = 0; } ++i; } if (n) *P = A; } ValidateBuffer(logEpCtrl); // Nop(100); // Add extra delay if enumerations fails return count; } void ACK(void) { WriteControlBlock((uint8_t*) &always0, 0); } /* Request-Typ im Setup-Packet testen (Standard, Class, Vendor) */ bool IsStandardRequest(void) { return (CMD.SetupPacket.bmRequestType & 0x60) == 0; } bool IsClassRequest(void) { return (CMD.SetupPacket.bmRequestType & 0x60) == 0x20; } bool IsVendorRequest(void) { return (CMD.SetupPacket.bmRequestType & 0x60) == 0x40; } /******* anstehende Control-Transfers zum Host blockweise starten *******/ void DescriptorBlockwiseIn(void) { int i, j; uint8_t* Q; if ((CMD.SetupPacket.bmRequestType & 0x80) == 0) { trace("bmRequestType & 0x80 ==0\n"); return; } i = CMD.TransferLen; if (i > CMD.PacketLen) i = CMD.PacketLen; Q = CMD.TransferPtr; /* Quelle */ j = WriteControlBlock(Q, i); CMD.TransferPtr = Q + j; /* Zeiger auf evt. Rest merken */ CMD.TransferLen = CMD.TransferLen - j; /* restliche Anzahl Bytes */ if (CMD.TransferLen < 0) CMD.TransferLen = 0; } /**********************************************************************/ /************ Bearbeitung eingegangener Requests **********************/ /**********************************************************************/ /********** USB-Request "SET FEATURE" und "CLEAR FEATURE" behandeln ****/ void DoSetClearFeature(bool value) { int Feature; int FuerWen; int EP; Feature = CMD.SetupPacket.wValue; FuerWen = CMD.SetupPacket.bmRequestType; EP = CMD.SetupPacket.wIndex; #if ENABLE_TRACING char buf[30]; sprintf(buf,"doSetClearFeature for %02x\n",FuerWen); trace(buf); #endif switch (FuerWen) { case 0: /* für Device */ trace("forDevice\n"); if (Feature == 1) CMD.RemoteWakeup = value; break; case 1: /* für Interface */ trace("forInterface\n"); break; case 2: /* für einen Endpoint */ trace("forEndPoint\n"); if (Feature == 0) //Feature Stall { switch(EP) { case 0x81: //bulk in case 0x83: //int in case 0x02: //bulk out if (value) Stall (EP); else UnStall(EP); ACK(); break; default: StallLogEP(logEpCtrl); } } else StallLogEP(logEpCtrl); break; default: trace("forElse\n"); StallLogEP(logEpCtrl); } } /******** USB-Request "GET STATUS" behandeln ***************************/ void DoGetStatus(void) { uint8_t Buf[4]; int FuerWen; int EP; //uint32_t reg; FuerWen = CMD.SetupPacket.bmRequestType; EP = CMD.SetupPacket.wIndex; Buf[0] = 0; Buf[1] = 0; #if ENABLE_TRACING char buf[30]; sprintf(buf,"doGetStatus for %02x\n",FuerWen); trace(buf); #endif switch (FuerWen) { case 0x80: /* für Device */ trace("forDevice\n"); if (CMD.RemoteWakeup) Buf[0] |= 2; if (CMD.SelfPowered) Buf[0] |= 1; break; case 0x81: /* für Interface */ trace("forInterface\n"); break; case 0x82: /* für einen Endpoint */ switch (EP) { trace("forEndpoint\n"); /* nur für bulk + int eps notwendig case 0x80: //ctrl in case 0x00: //ctrl out */ case 0x02: //bulk out stall condition if (((USB_EpRegs(2) >> 12) & 0x03) ==1) Buf[0] = 1; break; case 0x81: //bulk in stall condition if (((USB_EpRegs(1) >> 4) & 0x03) ==1) Buf[0] = 1; break; case 0x83: //interrupt in stall condition if (((USB_EpRegs(3) >> 4) & 0x03) ==1) Buf[0] = 1; break; default: trace("unsuported ep for OnGetStatus\n"); StallLogEP(logEpCtrl); /* kennen wir nicht. Stall. */ return; } break; default: /* hier eigentlich NAK senden */ trace("forElse\n"); StallLogEP(logEpCtrl); return; } //Buf[1] = 0; CMD.PacketLen = EpCtrlMaxLen; CMD.TransferLen = 2; CMD.TransferPtr = Buf; DescriptorBlockwiseIn(); } /******** Descriptoren zum Host senden *********************************/ /** Send the first part and possibly the only part back to the host */ void DoGetDescriptor(void) { uint16_t Type, Index; int aLen; const uint8_t* P; Type = CMD.SetupPacket.wValue >> 8; Index = CMD.SetupPacket.wValue & 0xFF; aLen = -1; P = 0;//NULL; #if ENABLE_TRACING char buf[30]; sprintf(buf,"doGetDescr type %04x\n",Type); trace(buf); #endif switch (Type) { case USB_DEVICE_DESCRIPTOR: { trace("descDevice\n"); aLen = sizeof(DeviceDescriptor); P = DeviceDesc; } break; case USB_CONFIGURATION_DESCRIPTOR: { trace("descConfig\n"); aLen = ConfigDesc[3]; /* Total-Länge ist WORD */ aLen = (aLen << 8) | ConfigDesc[2]; P = ConfigDesc; } break; case USB_STRING_DESCRIPTOR: { trace("descString\n"); switch (Index) /* Get String Descriptor */ { case 0: aLen = 4; P = LangString; break; case 1: aLen = VendorString[0]; P = VendorString; break; case 2: aLen = ProductString[0]; P = ProductString; break; #if USB_SERIAL_NO case 3: aLen = SerialString[0]; P = SerialString; break; #endif default: StallLogEP(logEpCtrl); /* kennen wir nicht. Stall. */ aLen = -1; } } break; default: { trace("descElse\n"); StallLogEP(logEpCtrl); /* kennen wir nicht. Stall. */ aLen = -1; } } if (aLen < 0) return; /* nicht mehr senden wollen, als der Host haben will */ if (aLen > CMD.SetupPacket.wLength) aLen = CMD.SetupPacket.wLength; CMD.PacketLen = EpCtrlMaxLen; CMD.TransferLen = aLen; CMD.TransferPtr = (uint8_t*) P; DescriptorBlockwiseIn(); } /********** haben Adresse empfangen ***********************************/ void DoSetAddress(void) { ACK(); DeviceAddress=CMD.SetupPacket.wValue; } /*********** USB-Request "SET CONFIGURATION" behandeln *************/ void DoSetConfiguration(void) { bool haveConfig; haveConfig = Class_Compare(CMD.SetupPacket.wValue); if (CMD.SetupPacket.wValue == 0) { CMD.Configuration = CMD.SetupPacket.wValue & 0xFF; configurationSet = false; } else if (haveConfig) { USB_ConfigDevice(true); Class_Start(); CMD.Configuration = CMD.SetupPacket.wValue & 0xFF; configurationSet = true; ACK(); } else { CMD.Configuration = 0; configurationSet = false; Stall(0); } } /*************************** CDC Spezifisches **************************/ /************* "SET LINE CODING" behandeln *****************************/ void VCOM_SetLineCoding(void) { ACK(); /* Vorbereitung auf Empfang von genau 7 Bytes vom Host ???*/ } /* Datenausgabe für CDC-spezifischen USB-Request "SET LINE CODING" */ /* hier werden die empfangenen 7 Bytes aus dem USB-Puffer gelesen und im RAM gemerkt */ void SetLineCodingDataOut(void) { ReadControlBlock((uint8_t*) &LineCoding, 7); ACK(); } /* Zustand von DTR und RTS vom Host zum Gerät merken */ void VCOM_Read_DTR_RTS(void) { Dtr_Rts = CMD.SetupPacket.wValue >> 8; ACK(); } /* CDC-spezifischer USB-Request "GET LINE CODING" behandeln */ void VCOM_GetLineCoding(void) { CMD.PacketLen = EpCtrlMaxLen; CMD.TransferLen = 7; CMD.TransferPtr = (uint8_t*) &LineCoding; DescriptorBlockwiseIn(); /* hier werden die 7 Bytes zum Host geschickt */ } /************************** Setup-Event ***********************************/ /* Merke: 1. Paket abholen und dann ClearBuffer. 2. Bei Setup Paketen, bei denen.. - ..nix hinterher kommt, also wo es keine Datenphase gibt, beantwortet man mit Senden eines leeren Paketes (ist ACK) - ..anschließend etwas zum Host gesendet werden muß, sendet man dies direkt danach. Wenn das zu Sendende größer ist als die EpBuffer-Länge, dann nur ein Stück senden. Der Host holt es sich ab und der USB-Core gibt dann einen gewöhnlichen Int auf Control-In, wo man dann das nächste Stück senden kann. Wiederholt sich, bis man nix mehr zu senden hat. Ob man als Abschluß ein leeres Paket senden muß oder nicht, ist ungewiß. Wenn der Host zufrieden ist, sendet er ein leeres Paket als ACK. - ..man anschließend noch etwas vom Host bekommt, dann gibt es dafür ein anschließendes Int auf Control-Out. Man liest das Paket und sendet dann als ACK ein leeres Paket. */ void OnSetup(uint16_t EpCtrlStatus) { ReadControlBlock(&CMD.SetupPacket.bmRequestType, 8); if (IsStandardRequest()) /* wenn Type = Standard */ { trace("isStandardRequest\n"); switch (CMD.SetupPacket.bRequest) { case USB_SET_ADDRESS: trace("SET_ADDRESS\n"); DoSetAddress(); return; case USB_CLEAR_FEATURE: trace("CLEAR_FEATURE\n"); DoSetClearFeature(false); return; case USB_SET_FEATURE: trace("SET_FEATURE\n"); DoSetClearFeature(true); return; case USB_GET_CONFIGURATION: trace("GET_CONFIGURATION\n"); CMD.PacketLen = EpCtrlMaxLen; CMD.TransferLen = 1; CMD.TransferPtr = (uint8_t*) &CMD.Configuration; DescriptorBlockwiseIn(); return; case USB_GET_STATUS: trace("GET_STATUS\n"); DoGetStatus(); return; case USB_GET_INTERFACE: trace("GET_INTERFACE\n"); CMD.TransferLen = 1; CMD.TransferPtr = (uint8_t*) &always0; DescriptorBlockwiseIn(); return; case USB_SET_INTERFACE: trace("SET_INTERFACE\n"); //usb spec fordert dass alle DataToggles für Bulk und int //auf DATA0 zurückgesetzt werden if(USB_EpRegs(1) & DTOG_TX) USB_EpRegs(1) ^= DTOG_TX; if(USB_EpRegs(2) & DTOG_RX) USB_EpRegs(1) ^= DTOG_RX; if(USB_EpRegs(3) & DTOG_TX) USB_EpRegs(1) ^= DTOG_TX; Class_Start(); ACK(); return; case USB_GET_DESCRIPTOR: trace("GET_DESCRIPTOR\n"); DoGetDescriptor(); return; case USB_SET_CONFIGURATION: trace("SET_CONFIGURATION\n"); DoSetConfiguration(); return; } /* auf alles andere reagieren wir mit Stall. siehe unten. */ } if (IsClassRequest()) /* wenn Type = Class */ { trace("IsClassRequest\n"); switch (CMD.SetupPacket.bRequest) { case SET_LINE_CODE: trace("SET_LINE_CODE\n"); VCOM_SetLineCoding(); return; case GET_LINE_CODE: trace("GET_LINE_CODE\n"); VCOM_GetLineCoding(); return; case SET_CONTROL_LINE_STATE: trace("SET_CONTROL_LINE_STATE\n"); VCOM_Read_DTR_RTS(); return; /* falls es hier noch mehr Class-spezifische Requests geben sollte, dann Behandlung hier hinein. */ } } if (IsVendorRequest()) /* wenn Type = Vendor */ { trace("IsVendorRequest\n"); } /* wenn keiner zuständig war, dann Stall! */ trace("Stall\n"); Stall(0); //todo stall in out } /******* die diversen Endpoint-Interrupts ************************************/ void OnEpCtrlOut(uint16_t EpCtrlStatus) /* Control-EP OUT */ { uint8_t tbuf[EpCtrlMaxLen]; if (IsStandardRequest()) /* wenn Type = Standard */ { /* eigentlich nur leere Pakete, also ACK vom Host, aber möglich (nie gesehen) bRequest=7 = SET_DESCRIPTOR */ trace("IsStandardRequest\n"); ReadControlBlock(tbuf, EpCtrlMaxLen); return; } if (IsClassRequest()) /* wenn Type = Class */ { trace("IsClassRequest\n"); switch (CMD.SetupPacket.bRequest) { case SET_LINE_CODE: trace("SET_LINE_CODE\n"); SetLineCodingDataOut(); ACK(); return; default: trace("default\n"); ACK(); } return; } /* nach Vendor-Request fragen wir hier garnicht erst */ ACK(); } /** for InTransfers this would be a data stage transfer for OutTransfers this will be a status stage */ void OnEpCtrlIn(uint16_t EpCtrlStatus) /* Control-EP IN */ { if (IsStandardRequest()) /* wenn Type = Standard */ { trace("IsStandardRequest\n"); switch (CMD.SetupPacket.bRequest) { case USB_GET_DESCRIPTOR: trace("GET_DESCRIPTOR\n"); if (CMD.TransferLen > 0) DescriptorBlockwiseIn(); break; //todo here would be the right place to change the address case GET_LINE_CODE: //todo wrong place gets never executed trace("GET_LINE_CODE\n"); ACK(); break; default: trace("default\n"); ACK(); } return; } } /********* BULK IN und OUT Interrupts **********/ void EpBulkBeginTransmit (void) { int i, n; UMEM_FAKEWIDTH L, A; UMEM_FAKEWIDTH* P; P = (UMEM_FAKEWIDTH*) EP1TxABuffer; i = txw - txr; if (i < 0) { i += txLen; /* i = Anzahl zu sendender Bytes */ } if (i > EpBulkMaxLen) { i = EpBulkMaxLen; } A = 0; n = 0; EpTable[1].TxCount = (i & 0x3FF) | EpBulkLenId; transmitting = true; while (i) { L = UsbTxBuf[txr]; txr = (txr + 1) & (txLen - 1); A = A | (L << n); n += 8; if (n > 8) { *P++ = A; n = 0; A = 0; } --i; } if (n) { *P = A; /* ggf. restliche Bytes ausgeben */ } ValidateBuffer(logEpBulkIn); } void OnEpBulkIn(void) /* EP1 = Bulk-EP IN */ { if (txr == txw) { transmitting = false; } else { EpBulkBeginTransmit (); } } void OnEpBulkOut(void) /* EP2 = Bulk-EP OUT */ { int i, n, hdroom, avail; UMEM_FAKEWIDTH D; char c; UMEM_FAKEWIDTH* P; /* Bulk EP anwählen und Anzahl der Bytes ermittlen */ avail = EpTable[2].RxCount & 0x3FF; i = rxw - rxr; if (i < 0) i += rxLen; hdroom = rxLen - i; if (hdroom <= avail) { receiving = false; return; } P = (UMEM_FAKEWIDTH*) EP2RxBBuffer; n = 2; i = avail; D = *P++; /* 2 Byte laden */ while (i > 0) { c = D & 0xFF; /* LSB zuerst */ UsbRxBuf[rxw] = c; rxw = (rxw + 1) & (rxLen - 1); D = D >> 8; --n; if (!n) { D = *P++; n = 2; } --i; } if (hdroom - avail >= EpBulkMaxLen) { ClearBuffer(logEpBulkOut); /* wir haben's gelesen */ } else { receiving = false; } } void OnEpIntIn(void) /* Int-EP IN */ { /* erstmal nix */ } void OnEpIntOut(void) /* Int-EP IN */ { /* erstmal nix */ } /**************** USB-Interrupt-Handler **************************************/ void NAME_OF_USB_IRQ_HANDLER(void) { //trace("irq\n"); uint32_t I; int EpNum; uint16_t EpStatus; I = USB_ISTR; /* Interrupt-Status nach I */ if (I & PMAOVR) /* interner Timeout... */ { trace("PMAOVR\n"); USB_ISTR = ~PMAOVR; /* Int löschen */ } if (I & ERR) /* Datenfehler bei Transaction */ { trace("ERR\n"); USB_ISTR = ~ERR; /* Int löschen */ } if (I & WKUP) /* Suspend-->Resume */ { trace("WKUP\n"); USB_CNTR &= ~(FSUSP | LP_MODE); USB_ISTR = ~WKUP; /* Int löschen */ suspended = false; } if (I & SUSP) /* nach 3 ms Pause -->Suspend */ { trace("SUSP\n"); USB_ISTR = ~SUSP; /* Int löschen */ suspended = true; USB_CNTR |= (FSUSP | LP_MODE); } if (I & RESET) /* Bus Reset */ { trace("RESET\n"); CMD.Configuration = 0; configurationSet = false; InitEndpoints(); USB_ISTR = ~RESET; /* Int löschen */ return; } if (I & SOF) /* Start of Frame, alle 1 ms */ { //trace("SOF\n"); USB_ISTR = ~SOF; /* Int löschen */ suspended = false; } if (I & ESOF) /* Wenn ein SOF Paket fehlt */ { trace("ESOF\n"); USB_ISTR = ~ESOF; /* Int löschen */ suspended = true; } /* Endpoint Interrupts */ if (I & CTR) { trace("CTR "); USB_ISTR = ~CTR; /* Interruptbit löschen */ EpNum = I & MASK_EA; /* welcher EP? Todo mask 0x07 */ EpStatus = USB_EpRegs(EpNum); /* EP Status lesen */ if (I & DIR) /* OUT, also Paket wurde empfangen */ { trace("out\n"); USB_EpRegs(EpNum) = EpStatus & ~CTR_RX & EP_NoToggleBits; if (EpNum == logEpCtrl) { trace("logEpCtrl\n"); if (EpStatus & SETUP) { trace("SETUP\n"); OnSetup(EpStatus); /* Handle the Setup-Packet */ } else { trace("EpCtrlOut\n"); OnEpCtrlOut(EpStatus); /* eigentlich nur Class-spezifisches */ } } if (EpNum == logEpBulkOut) { trace("logEpBulkOut\n"); OnEpBulkOut(); } if (EpNum == logEpInt) { trace("logEpInt\n"); OnEpIntOut(); } } else /* IN, also Paket wurde gesendet */ { // Apply new device address if (DeviceAddress) { USB_SetAddress(DeviceAddress); DeviceAddress=0; } trace("in\n"); USB_EpRegs(EpNum) = EpStatus & ~CTR_TX & EP_NoToggleBits; if (EpNum == logEpCtrl) { trace("logEpCtrl\n"); OnEpCtrlIn(EpStatus); } if (EpNum == logEpBulkIn) { trace("logEpBulkIn\n"); OnEpBulkIn(); } if (EpNum == logEpInt) { trace("logEpInt\n"); OnEpIntIn(); } } } } /************ USB-Setup **********************************/ /* Clock muss bereits konfiguriert sein */ /**********************************************************/ uint16_t UsbSetup(void) { trace("setup\n"); uint32_t* P; P = (uint32_t*) USB_RAM; /* RAM ablöschen */ while ((uint32_t) P < (USB_RAM + 1024)) { *P++ = 0; } // usb serial number init InitSerial(); CMD.Configuration = 0; configurationSet = false; suspended = false; Class_Start(); /* LineCoding-Block aufsetzen mit unseren Defaultwerten */ USB_CNTR = 3; /* Powerdown+Reset */ Nop(100); /* warten */ USB_CNTR = 1; /* Reset */ USB_ISTR = 0; /* spurious Ints beseitigen */ Nop(1000); /* warten */ EnableUsbIRQ(); InitEndpoints(); return 0; } /********** zeichenweises I/O und Pufferung und Kommunikation ***************/ /* Diese Routinen werden von außerhalb im Usermode aufgerufen und haben mit dem interrupt-gesteuerten USB-Betrieb nichts zu tun. */ /* liefert true, wenn ein Zeichen abholbereit ist */ bool UsbRxAvail(void) { bool res = rxr != rxw; return res; } /* holt ein Zeichen vom USB ab */ /* Achtung: wenn nix abzuholen ist, wird 0 zurückgeliefert */ char UsbGetChar(void) { char c; c = 0; if (!configurationSet || suspended) { return -1; } if (rxr != rxw) { c = UsbRxBuf[rxr]; rxr = (rxr + 1) & (rxLen - 1); if (!receiving) { DisableUsbIRQ(); int i, hdroom; i = rxw - rxr; if (i < 0) { i += rxLen; } hdroom = rxLen - i; if (hdroom > EpBulkMaxLen) { receiving = true; ClearBuffer(logEpBulkOut); } EnableUsbIRQ(); } } return c; } /* true, wenn der Host per SET_CONFIGURATION eine Konfiguration aktiviert hat und das Gerät nicht im Suspend ist. Ansonsten ist keine VCP-Kommunikation möglich. */ bool UsbActive (void) { bool res = configurationSet && !suspended; return res; } /* liefert true, wenn noch ein Zeichen in den Tx-Buffer passt */ bool UsbTxReady(void) { bool res = configurationSet && !suspended && ((txw + 1) & (txLen - 1)) != txr; return res; } /* liefert true, wenn Tx-Buffer leer ist */ bool UsbTxEmpty(void) { bool res = (txw == txr); return res; } /* Anzahl freier Plätze im Tx-Buffer liefern */ int UsbTxFree(void) { int i; i = txw - txr; /* i = belegte Plätze */ if (i < 0) { i = i + txLen; } return txLen - i; } void UsbTxFlush (void) { if (!transmitting) { DisableUsbIRQ(); EpBulkBeginTransmit(); EnableUsbIRQ(); } } /* sendet ein Zeichen (d.h. schreibt es in den Tx-Buffer) */ bool UsbCharOut(char c) { while (true) { if (!configurationSet || suspended) { return false; } if (((txw + 1) & (txLen - 1)) != txr) break; __asm__ volatile ("wfi"); /* trampeln auf der Stelle!! */ } int i = (txw + 1) & (txLen - 1); UsbTxBuf[txw] = c; txw = i; // Die folgende Bedingung einkommentieren, um nur dann automatisch abzusenden, // wenn Sendepuffer voll. In diesem Fall kann über UsbTxFlush abgeschickt werden. // if (((txw + 1) & (txLen - 1)) == txr) { if (!transmitting) { DisableUsbIRQ(); EpBulkBeginTransmit(); EnableUsbIRQ(); } // } return true; } /* asciiz zum USB senden */ void UsbStrOut(char* S) { while (*S && UsbCharOut(*S++)); }
