=========================== USB Port1 =========================== Connection Status : Device is connected Port Chain : 1-1-1 Supported Protocols : 0x03 (1.1, 2.0) Properties : 0x01 IsUserConnectable : yes PortIsDebugCapable : no ======================== USB Device ======================== +++++++++++++++++ Device Information ++++++++++++++++++ Device Description : USB Composite Device Device ID : USB\VID_2E8A&PID_0005\000000000000 Driver KeyName : {36fc9e60-c465-11cf-8056-444553540000}\0061 Driver : C:\WINDOWS\System32\drivers\usbccgp.sys (Version: 6.3.9600.18814 Date: 2017-09-07) Legacy BusType : PNPBus Class : USB Service : usbccgp Enumerator : USB Location Info : Port_#0001.Hub_#0004 Location IDs : PCIROOT(0)#PCI(1A00)#USBROOT(0)#USB(1)#USB(1), ACPI(_SB_)#ACPI(PCI0)#ACPI(EHC2)#ACPI(HUBN)#ACPI(PR01)#ACPI(PR11) Container ID : {593b59ec-18b9-5eab-abb2-1319c33b4e6e} Manufacturer Info : (Standard USB Host Controller) Capabilities : Removable, UniqueID, SurpriseRemovalOK Address : 1 Problem Code : 0 Power State : D3 (supported: D0, D1, D2, D3, wake from D0, wake from D1, wake from D2) Child Device 1 : Board CDC Device ID : USB\VID_2E8A&PID_0005&MI_00\7&2088AAC2&0&0000 ---------------- Connection Information --------------- Connection Index : 0x01 Connection Status : 0x01 (DeviceConnected) Current Config Value : 0x01 Device Address : 0x02 Is Hub : 0x00 (no) Number Of Open Pipes : 0x03 (3) Device Bus Speed : 0x01 (Full-Speed) Pipe0ScheduleOffset : 0x00 (0) Pipe1ScheduleOffset : 0x00 (0) Pipe2ScheduleOffset : 0x00 (0) ------------- Device Qualifier Descriptor ------------- bLength : 0x12 (18 bytes) bDescriptorType : 0x01 (Device Qualifier Descriptor) bcdUSB : 0x200 (USB Version 2.00) bDeviceClass : 0xEF (Miscellaneous) bDeviceSubClass : 0x02 bDeviceProtocol : 0x01 bMaxPacketSize0 : 0x40 (64 bytes) idVendor : 0x2E8A idProduct : 0x0005 bcdDevice : 0x100 iManufacturer : 0x01 *!* string descriptors are not available because device is in low power state iProduct : 0x02 *!* string descriptors are not available because device is in low power state iSerialNumber : 0x03 *!* string descriptors are not available because device is in low power state bNumConfigurations : 0x01 -------------- Configuration Descriptor --------------- bLength : 0x09 (9 bytes) bDescriptorType : 0x02 (Configuration Descriptor) wTotalLength : 0x004B (75 bytes) bNumInterfaces : 0x02 bConfigurationValue : 0x01 iConfiguration : 0x00 bmAttributes : 0xA0 (Bus Powered, Remote Wakeup) MaxPower : 0x7D (250 mA) ------------------- IAD Descriptor -------------------- bLength : 0x08 (8 bytes) bDescriptorType : 0x0B bFirstInterface : 0x00 bInterfaceCount : 0x02 bFunctionClass : 0x02 (Communications and CDC Control) bFunctionSubClass : 0x02 bFunctionProtocol : 0x00 iFunction : 0x00 ---------------- Interface Descriptor ----------------- bLength : 0x09 (9 bytes) bDescriptorType : 0x04 (Interface Descriptor) bInterfaceNumber : 0x00 bAlternateSetting : 0x00 bNumEndpoints : 0x01 bInterfaceClass : 0x02 (Communications and CDC Control) bInterfaceSubClass : 0x02 bInterfaceProtocol : 0x00 iInterface : 0x04 *!* string descriptors are not available because device is in low power state -------------- CDC Interface Descriptor --------------- bFunctionLength : 0x05 (5 bytes) bDescriptorType : 0x24 (Interface) bDescriptorSubType : 0x00 (Header Functional Descriptor) bcdCDC : 0x120 (CDC Version 1.20) -------------- CDC Interface Descriptor --------------- bFunctionLength : 0x05 (5 bytes) bDescriptorType : 0x24 (Interface) bDescriptorSubType : 0x01 (Call Management Functional Descriptor) bmCapabilities : 0x00 bDataInterface : 0x01 -------------- CDC Interface Descriptor --------------- bFunctionLength : 0x04 (4 bytes) bDescriptorType : 0x24 (Interface) bDescriptorSubType : 0x02 (Abstract Control Management Functional Descriptor) bmCapabilities : 0x02 -------------- CDC Interface Descriptor --------------- bFunctionLength : 0x05 (5 bytes) bDescriptorType : 0x24 (Interface) bDescriptorSubType : 0x06 (Union Functional Descriptor) bControlInterface : 0x00 bSubordinateInterface[0] : 0x01 ----------------- Endpoint Descriptor ----------------- bLength : 0x07 (7 bytes) bDescriptorType : 0x05 (Endpoint Descriptor) bEndpointAddress : 0x81 (Direction=IN EndpointID=1) bmAttributes : 0x03 (TransferType=Interrupt) wMaxPacketSize : 0x08 (8 bytes) bInterval : 0x10 (16 ms) ---------------- Interface Descriptor ----------------- bLength : 0x09 (9 bytes) bDescriptorType : 0x04 (Interface Descriptor) bInterfaceNumber : 0x01 bAlternateSetting : 0x00 bNumEndpoints : 0x02 bInterfaceClass : 0x0A (CDC-Data) bInterfaceSubClass : 0x00 bInterfaceProtocol : 0x00 iInterface : 0x00 ----------------- Endpoint Descriptor ----------------- bLength : 0x07 (7 bytes) bDescriptorType : 0x05 (Endpoint Descriptor) bEndpointAddress : 0x02 (Direction=OUT EndpointID=2) bmAttributes : 0x02 (TransferType=Bulk) wMaxPacketSize : 0x40 (64 bytes) bInterval : 0x00 (ignored) ----------------- Endpoint Descriptor ----------------- bLength : 0x07 (7 bytes) bDescriptorType : 0x05 (Endpoint Descriptor) bEndpointAddress : 0x82 (Direction=IN EndpointID=2) bmAttributes : 0x02 (TransferType=Bulk) wMaxPacketSize : 0x40 (64 bytes) bInterval : 0x00 (ignored)
