(kicad_symbol_lib (version 20201005) (generator kicad_symbol_editor)
  (symbol "em20b:EM20B" (pin_names (offset 1.016) hide) (in_bom yes) (on_board yes)
    (property "Reference" "SW" (id 0) (at 0 10.16 0)
      (effects (font (size 1.27 1.27)))
    (property "Value" "EM20B" (id 1) (at 0 -10.16 0)
    (property "Footprint" "dp:EM20B" (id 2) (at 0 -12.7 0)
      (effects (font (size 1.27 1.27)) hide)
    (property "Datasheet" "https://www.mouser.de/datasheet/2/15/EM20B-587875.pdf" (id 3) (at 1.27 -16.51 0)
    (property "ki_keywords" "Magnetic Rotray encoder" (id 4) (at 0 0 0)
    (property "ki_description" "Magnetic Rotray encoder" (id 5) (at 0 0 0)
    (symbol "EM20B_0_1"
      (rectangle (start -5.08 8.89) (end 5.08 -8.89)
        (stroke (width 0.001)) (fill (type background))
      (polyline
        (pts
          (xy 4.318 -1.016)
          (xy 4.318 -2.54)
        (stroke (width 0)) (fill (type none))
      (polyline
        (pts
          (xy 5.08 -2.54)
          (xy 4.318 -2.54)
    (symbol "EM20B_1_1"
      (arc (start -0.381 -2.794) (end -0.381 2.667) (radius (at -0.381 -0.0508) (length 2.7432) (angles -89.9 89.9))
        (stroke (width 0.254)) (fill (type none))
      (circle (center -0.381 0) (radius 1.905) (stroke (width 0.254)) (fill (type none)))
      (circle (center 4.318 -1.016) (radius 0.127) (stroke (width 0.254)) (fill (type none)))
      (circle (center 4.318 1.016) (radius 0.127) (stroke (width 0.254)) (fill (type none)))
      (polyline
        (pts
          (xy -0.635 -1.778)
          (xy -0.635 1.778)
      (polyline
        (pts
          (xy -0.381 -1.778)
          (xy -0.381 1.778)
      (polyline
        (pts
          (xy -0.127 1.778)
          (xy -0.127 -1.778)
      (polyline
        (pts
          (xy 3.81 0)
          (xy 3.429 0)
      (polyline
        (pts
          (xy 3.81 1.016)
          (xy 3.81 -1.016)
      (polyline
        (pts
          (xy 0.254 -3.048)
          (xy -0.508 -2.794)
          (xy 0.127 -2.413)
      (polyline
        (pts
          (xy 0.254 2.921)
          (xy -0.508 2.667)
          (xy 0.127 2.286)
      (polyline
        (pts
          (xy 5.08 2.54)
          (xy 4.318 2.54)
          (xy 4.318 1.016)
      (pin passive line (at -7.62 1.27 0) (length 2.54)
        (name "A" (effects (font (size 1.27 1.27))))
        (number "A" (effects (font (size 1.27 1.27))))
      (pin passive line (at -7.62 -1.27 0) (length 2.54)
        (name "B" (effects (font (size 1.27 1.27))))
        (number "B" (effects (font (size 1.27 1.27))))
      (pin passive line (at -7.62 -5.08 0) (length 2.54)
        (name "GA" (effects (font (size 1.27 1.27))))
        (number "GA" (effects (font (size 1.27 1.27))))
      (pin passive line (at -7.62 -7.62 0) (length 2.54)
        (name "GB" (effects (font (size 1.27 1.27))))
        (number "GB" (effects (font (size 1.27 1.27))))
      (pin passive line (at 7.62 -7.62 180) (length 2.54)
        (name "M" (effects (font (size 1.27 1.27))))
        (number "M1" (effects (font (size 1.27 1.27))))
      (pin passive line (at 7.62 2.54 180) (length 2.54)
        (name "S1" (effects (font (size 1.27 1.27))))
        (number "S1" (effects (font (size 1.27 1.27))))
      (pin passive line (at 7.62 -2.54 180) (length 2.54)
        (name "S2" (effects (font (size 1.27 1.27))))
        (number "S2" (effects (font (size 1.27 1.27))))
      (pin passive line (at -7.62 7.62 0) (length 2.54)
        (name "VA" (effects (font (size 1.27 1.27))))
        (number "VA" (effects (font (size 1.27 1.27))))
      (pin passive line (at -7.62 5.08 0) (length 2.54)
        (name "VB" (effects (font (size 1.27 1.27))))
        (number "VB" (effects (font (size 1.27 1.27))))
  (symbol "em20b:EM20B_LedRing" (in_bom yes) (on_board yes)
    (property "Reference" "U" (id 0) (at 0 13.97 0)
    (property "Value" "EM20B_LedRing" (id 1) (at 0 11.43 0)
    (property "Footprint" "dp:EM20B_LedRing" (id 2) (at 0 -15.24 0)
    (property "Datasheet" "http://www.farnell.com/datasheets/1837003.pdf" (id 3) (at -1.27 -12.7 0)
    (property "ki_keywords" "EM20B LedRing" (id 4) (at 0 0 0)
    (property "ki_description" "EM20B LedRing" (id 5) (at 0 0 0)
    (property "ki_fp_filters" "HDSM?541B?HDSM?543B*" (id 6) (at 0 0 0)
    (symbol "EM20B_LedRing_0_1"
      (rectangle (start 6.35 -8.89) (end -6.35 8.89)
    (symbol "EM20B_LedRing_1_1"
      (pin passive line (at -8.89 -6.35 0) (length 2.54) hide
        (name "GND" (effects (font (size 1.27 1.27))))
        (number "1" (effects (font (size 1.27 1.27))))
      (pin bidirectional line (at 8.89 6.35 180) (length 2.54)
        (name "SDA3" (effects (font (size 1.27 1.27))))
        (number "10" (effects (font (size 1.27 1.27))))
      (pin input line (at 8.89 3.81 180) (length 2.54)
        (name "SCL3" (effects (font (size 1.27 1.27))))
        (number "11" (effects (font (size 1.27 1.27))))
        (number "12" (effects (font (size 1.27 1.27))))
      (pin bidirectional line (at 8.89 -3.81 180) (length 2.54)
        (name "SDA1" (effects (font (size 1.27 1.27))))
        (number "2" (effects (font (size 1.27 1.27))))
      (pin input line (at 8.89 -6.35 180) (length 2.54)
        (name "SCL1" (effects (font (size 1.27 1.27))))
        (number "3" (effects (font (size 1.27 1.27))))
      (pin bidirectional line (at 8.89 1.27 180) (length 2.54)
        (name "SDA2" (effects (font (size 1.27 1.27))))
        (number "4" (effects (font (size 1.27 1.27))))
      (pin input line (at 8.89 -1.27 180) (length 2.54)
        (name "SCL2" (effects (font (size 1.27 1.27))))
        (number "5" (effects (font (size 1.27 1.27))))
      (pin power_in line (at -8.89 6.35 0) (length 2.54)
        (name "VCC" (effects (font (size 1.27 1.27))))
        (number "8" (effects (font (size 1.27 1.27))))
      (pin power_in line (at -8.89 -6.35 0) (length 2.54)
        (number "9" (effects (font (size 1.27 1.27))))
