(footprint "EM20B" (version 20210108) (generator pcbnew) (layer "F.Cu")
  (tedit 600E059F)
  (attr through_hole)
  (fp_text reference "REF**" (at 0 1.2) (layer "F.SilkS")
    (effects (font (size 1 1) (thickness 0.15)))
    (tstamp cf66e291-9874-4470-b3b6-e04d02c72921)
  (fp_text value "EM20B" (at 0 -1) (layer "F.Fab")
    (tstamp da3016d7-f887-401c-b55b-88c830f3c59e)
  (fp_line (start 6 11) (end -6 11) (layer "F.SilkS") (width 0.12) (tstamp 486f48e1-6bf9-41d5-acba-11aa50e449be))
  (fp_line (start 6 -8) (end -6 -8) (layer "F.SilkS") (width 0.12) (tstamp 49304a89-47f2-4b81-bc3f-cd5a3054b841))
  (fp_line (start 6 11) (end 6 -8) (layer "F.SilkS") (width 0.12) (tstamp 62f15c2f-a179-400b-bc25-d39daf75c49e))
  (fp_line (start -6 11) (end -6 -8) (layer "F.SilkS") (width 0.12) (tstamp 8d48390a-0499-49f4-8b60-29c681e338e5))
  (fp_line (start -6 11) (end -6 -8) (layer "F.CrtYd") (width 0.05) (tstamp 4b1d9212-bd6b-483e-8c63-d71f54da1a13))
  (fp_line (start 6 11) (end -6 11) (layer "F.CrtYd") (width 0.05) (tstamp 86051af1-00f2-427d-a6ec-899a40515bc6))
  (fp_line (start 6 -8) (end -6 -8) (layer "F.CrtYd") (width 0.05) (tstamp b1e8a380-4a41-44be-8d1d-89c549281b54))
  (fp_line (start 6 11) (end 6 -8) (layer "F.CrtYd") (width 0.05) (tstamp fcf0192a-39af-4d08-8b19-a8988bedf0bf))
  (pad "A" thru_hole circle (at 1.3456 10.1904) (locked) (size 1 1) (drill 0.6) (layers *.Cu *.Mask) (tstamp 5848d99f-5097-4709-a465-716570a41a16))
  (pad "B" thru_hole circle (at -3.8043 9.5488) (locked) (size 1 1) (drill 0.6) (layers *.Cu *.Mask) (tstamp 862946a4-ef8f-43f2-a337-f2e683656168))
  (pad "GA" thru_hole circle (at 2.5754 9.8695) (locked) (size 1 1) (drill 0.6) (layers *.Cu *.Mask) (tstamp eaf43294-0b70-4a53-a42b-177956ddbd17))
  (pad "GB" thru_hole circle (at -2.5754 9.8695) (locked) (size 1 1) (drill 0.6) (layers *.Cu *.Mask) (tstamp 1fd565e4-cd76-4fc2-97e4-f783cfe679a7))
  (pad "M1" thru_hole oval (at -5 0) (size 2.4 3.2) (drill oval 1.8 2.6) (layers *.Cu *.Mask) (tstamp 2a9b33eb-2ed2-4310-95f1-360ae2d53478))
  (pad "M1" thru_hole oval (at 5 0) (size 2.4 3.2) (drill oval 1.8 2.6) (layers *.Cu *.Mask) (tstamp b60c9a17-6750-44e2-a062-f2b67f582872))
  (pad "S1" thru_hole circle (at -2.5 -7) (locked) (size 1.5 1.5) (drill 1) (layers *.Cu *.Mask) (tstamp 0c1c053e-83bd-4870-b0d8-6cf3bd91a437))
  (pad "S2" thru_hole circle (at 2.5 -7) (locked) (size 1.5 1.5) (drill 1) (layers *.Cu *.Mask) (tstamp 863b3103-0764-4626-9824-b30fde762bbf))
  (pad "VA" thru_hole circle (at 3.8043 9.5488) (locked) (size 1 1) (drill 0.6) (layers *.Cu *.Mask) (tstamp 5cb6088a-6cb6-48e4-8b8a-9135a02b3723))
  (pad "VB" thru_hole circle (at -1.3456 10.1904) (locked) (size 1 1) (drill 0.6) (layers *.Cu *.Mask) (tstamp dd0f9fae-084b-4794-9958-2495e5bcc231))
  (model ":dp:em20b4014000.step"
    (offset (xyz 0 0 12.5))
    (scale (xyz 1 1 1))
    (rotate (xyz 0 0 0))
