(footprint "EM20B_LedRing" (version 20210108) (generator pcbnew) (layer "F.Cu")
  (tedit 600F5747)
  (descr "EM20B_LedRing")
  (attr smd)
  (fp_text reference "REF**" (at 0 1) (layer "F.SilkS")
    (effects (font (size 1 1) (thickness 0.15)))
    (tstamp db63d355-6375-44fb-b620-50f3eb0eb56a)
  (fp_text value "EM20B_LedRing" (at 0 -1) (layer "F.SilkS")
    (tstamp da6039b6-2d35-4733-80e3-661d88bf5f69)
  (fp_text user "${REFERENCE}" (at 0 1) (layer "F.Fab")
    (tstamp b489239b-1666-4bfc-a583-9bad986c17c5)
  (fp_circle (center 0 0) (end 11 0) (layer "F.SilkS") (width 0.12) (fill none) (tstamp 3cefb3c6-0c0f-438c-966a-57c4b93b5a57))
  (fp_circle (center -5.6853 -4.0557) (end -5.6853 -4.0557) (layer "F.CrtYd") (width 0.12) (fill none) (tstamp 6cc4cbfe-3098-40cb-86e0-5635666c2f50))
  (fp_circle (center 0 0) (end 11.1 0) (layer "F.CrtYd") (width 0.05) (fill none) (tstamp eee89364-0221-4d28-8455-468e407e93b8))
  (pad "1" thru_hole circle (at -8.3147 -5.5557) (locked) (size 1.2 1.2) (drill 0.8) (layers *.Cu *.Mask) (tstamp 2d5d977f-b6b2-4ada-96f9-c50d229f31fc))
  (pad "2" thru_hole circle (at -8.3147 5.5557) (locked) (size 1.2 1.2) (drill 0.8) (layers *.Cu *.Mask) (tstamp 1efe2b83-425c-45e6-b2e3-12f39424517e))
  (pad "3" thru_hole circle (at -6.9151 7.2236) (locked) (size 1.2 1.2) (drill 0.8) (layers *.Cu *.Mask) (tstamp 6a8611da-828a-4b45-9539-1bba672f8b0a))
  (pad "4" thru_hole circle (at -5.1877 8.5491) (locked) (size 1.2 1.2) (drill 0.8) (layers *.Cu *.Mask) (tstamp 63f683fe-fb1c-4bc8-926b-d26990766650))
  (pad "5" thru_hole circle (at -3.2144 9.4693) (locked) (size 1.2 1.2) (drill 0.8) (layers *.Cu *.Mask) (tstamp 155fd408-cd04-41f8-b3ba-d3c732230cad))
  (pad "8" thru_hole circle (at 3.2144 9.4693) (locked) (size 1.2 1.2) (drill 0.8) (layers *.Cu *.Mask) (tstamp de4f7d54-9c6d-4530-93af-ec83a4d67d4e))
  (pad "9" thru_hole circle (at 5.1877 8.5491) (locked) (size 1.2 1.2) (drill 0.8) (layers *.Cu *.Mask) (tstamp e498e8d0-0bc3-4d36-a685-6790f24e07b6))
  (pad "10" thru_hole circle (at 6.9151 7.2237) (locked) (size 1.2 1.2) (drill 0.8) (layers *.Cu *.Mask) (tstamp 04f693b1-a0ff-4adf-9308-b9ef8960e1f0))
  (pad "11" thru_hole circle (at 8.3147 5.5557) (locked) (size 1.2 1.2) (drill 0.8) (layers *.Cu *.Mask) (tstamp 595ce5b1-ac41-40f6-a0ca-70bd8f8f7855))
  (pad "12" thru_hole circle (at 8.3147 -5.5557) (locked) (size 1.2 1.2) (drill 0.8) (layers *.Cu *.Mask) (tstamp 2f690c8e-c899-4724-b468-5641b4521d9d))
  (model ":dp:em20b_ledrring.step"
    (offset (xyz 0 0 16))
    (scale (xyz 1 1 1))
    (rotate (xyz 0 0 0))
