//Version: v0.11 // written by Florian Strunk // License: GPL #include "vc920_960.h" #include int digit(int x) { int dig1[10]={0x30,0x31,0x32,0x33,0x34,0x35, 0x36,0x37,0x38, 0x39}; int n; for(n=0;n<10;n++) if (x==dig1[n]) return n; return 0; } void setSTATE_ACDC(unsigned char byte7, struct dvm_data *pdvmdata) { switch (byte7) { case 0x00: strcpy((*pdvmdata).STATE_ACDC,"OFF"); break; case 0x01: strcpy((*pdvmdata).STATE_ACDC,"AC"); break; case 0x02: strcpy((*pdvmdata).STATE_ACDC,"DC"); break; case 0x03: strcpy((*pdvmdata).STATE_ACDC,"AC+DC");break; default: strcpy((*pdvmdata).STATE_ACDC,""); } } void setSTATE_AUTO(unsigned char byte8, struct dvm_data *pdvmdata) { byte8 = byte8 & 0x03; //Vorzeichen aus Byte entfernen switch (byte8) { case 0x00: strcpy((*pdvmdata).STATE_ACDC,"OFF"); break; case 0x01: strcpy((*pdvmdata).STATE_ACDC,"AUTO"); break; case 0x02: strcpy((*pdvmdata).STATE_ACDC,"Manual"); break; case 0x03: strcpy((*pdvmdata).STATE_ACDC,"AC+DC");break; default: strcpy((*pdvmdata).STATE_ACDC,""); } } int isOverload(unsigned char* in) { if ((in[0]==0x3a) && (in[1]==0x3a) && (in[2]==0x30) && (in[3]==0x3c) && (in[4]==0x3a)) { return 1; } return 0; } void dvm_unit(unsigned char byte5, unsigned char byte6, unsigned char byte8, struct dvm_data *pdvmdata) { char *prefix=""; char *unit=""; char *ext=""; char *ext1=""; char *sign=""; struct dvm_data *dvmdata = pdvmdata; //struct Tparameter_log para = *((struct Tparameter_log*) arg); //byte8 vorzeichen //2. Teil 0xxx -> +; 1xxx -> -; unsigned char tempsign = 0; tempsign = byte8 & 0x04; if (tempsign == 0x04) { strcpy((*dvmdata).sign,"-");} else { strcpy((*dvmdata).sign,"+");} switch (byte6){ // AC mV (2. Teil des Bytes = 0) case 0x30: { strcpy((*dvmdata).type,"AC_mV"); strcpy((*dvmdata).unit,"V"); strcpy((*dvmdata).prefix,"m"); (*dvmdata).divisor = 100; break; } // DCV case 0x31: { strcpy((*dvmdata).type,"DC_V"); strcpy((*dvmdata).unit,"V"); strcpy((*dvmdata).prefix,""); switch (byte5) { case 0x30:(*dvmdata).divisor = 100000; break; case 0x31: (*dvmdata).divisor = 10000; break; case 0x32: (*dvmdata).divisor = 1000; break; case 0x33: (*dvmdata).divisor = 100; break; case 0x34: (*dvmdata).divisor = 10; break; } break; } // ACV case 0x32: { strcpy((*dvmdata).type,"AC_V"); strcpy((*dvmdata).unit,"V"); strcpy((*dvmdata).prefix,""); switch (byte5) { case 0x30: (*dvmdata).divisor = 100000; break; case 0x31: (*dvmdata).divisor = 10000; break; case 0x32: (*dvmdata).divisor = 1000; break; case 0x33: (*dvmdata).divisor = 100; break; case 0x34: (*dvmdata).divisor = 10; break; } break; } // DCmV case 0x33: { strcpy((*dvmdata).type,"DC_mV"); strcpy((*dvmdata).unit, "V"); strcpy((*dvmdata).prefix, "m"); switch (byte5) { case 0x30: (*dvmdata).divisor = 100; break; } break; } // Ohm case 0x34: { strcpy((*dvmdata).type,"Ohm"); strcpy((*dvmdata).unit, "Ohm"); switch (byte5) { case 0x31: (*dvmdata).divisor = 100; strcpy((*dvmdata).prefix, ""); break; case 0x32: (*dvmdata).divisor = 10000; strcpy((*dvmdata).prefix, "k"); break; case 0x33: (*dvmdata).divisor = 1000; strcpy((*dvmdata).prefix, "k"); break; case 0x34: (*dvmdata).divisor = 100; strcpy((*dvmdata).prefix, "k"); break; case 0x35: (*dvmdata).divisor = 10000; strcpy((*dvmdata).prefix, "M"); break; case 0x36: (*dvmdata).divisor = 1000; strcpy((*dvmdata).prefix, "M"); break; } break; } // C case 0x35: { strcpy((*dvmdata).type,"C"); strcpy((*dvmdata).unit, "C"); switch (byte5) { case 0x31: (*dvmdata).divisor = 1000; strcpy((*dvmdata).prefix, "n"); break; case 0x32: (*dvmdata).divisor = 100; strcpy((*dvmdata).prefix, "n"); break; case 0x33: (*dvmdata).divisor = 10000; strcpy((*dvmdata).prefix, "n"); break; case 0x34: (*dvmdata).divisor = 1000; strcpy((*dvmdata).prefix, "u"); break; case 0x35: (*dvmdata).divisor = 100; strcpy((*dvmdata).prefix, "u"); break; case 0x36: (*dvmdata).divisor = 10000; strcpy((*dvmdata).prefix, "m"); break; case 0x37: (*dvmdata).divisor = 1000; strcpy((*dvmdata).prefix, "m"); break; } break; } // Temperatur Grad C case 0x36: { strcpy((*dvmdata).type,"Temperature"); strcpy((*dvmdata).unit, "°C"); switch (byte5) { case 0x30: (*dvmdata).divisor = 10; strcpy((*dvmdata).prefix, ""); break; } break; } // uA case 0x37: { strcpy((*dvmdata).type,"uA"); strcpy((*dvmdata).unit, "A"); switch (byte5) { case 0x30: (*dvmdata).divisor = 100; strcpy((*dvmdata).prefix, "u"); break; case 0x31: (*dvmdata).divisor = 10; strcpy((*dvmdata).prefix, "u"); break; } break; } // mA case 0x38: { strcpy((*dvmdata).type,"mA"); strcpy((*dvmdata).unit, "A"); switch (byte5) { case 0x30: (*dvmdata).divisor = 1000; strcpy((*dvmdata).prefix, "m"); break; case 0x31: (*dvmdata).divisor = 100; strcpy((*dvmdata).prefix, "m"); break; } break; } // A case 0x39: { strcpy((*dvmdata).type,"10A"); strcpy((*dvmdata).unit, "A"); switch (byte5) { case 0x30: (*dvmdata).divisor = 1000; strcpy((*dvmdata).prefix, ""); break; } break; } // Fm case 0x3A: { strcpy((*dvmdata).type,"Fm"); strcpy((*dvmdata).unit, "Fm"); switch (byte5) { case 0x30: (*dvmdata).divisor = 1; strcpy((*dvmdata).prefix, ""); break; } break; } // Diode case 0x3B: { strcpy((*dvmdata).type,"Diode"); strcpy((*dvmdata).unit, ""); switch (byte5) { case 0x30: (*dvmdata).divisor = 1; strcpy((*dvmdata).prefix, ""); break; } break; } // Hz case 0x3C: { strcpy((*dvmdata).type,"Hz"); strcpy((*dvmdata).unit, "Hz"); switch (byte5) { case 0x30: (*dvmdata).divisor = 1000; strcpy((*dvmdata).prefix, ""); break; case 0x31: (*dvmdata).divisor = 100; strcpy((*dvmdata).prefix, ""); break; case 0x32: (*dvmdata).divisor = 10000; strcpy((*dvmdata).prefix, "k"); break; case 0x33: (*dvmdata).divisor = 1000; strcpy((*dvmdata).prefix, "k"); break; case 0x34: (*dvmdata).divisor = 100; strcpy((*dvmdata).prefix, "k"); break; case 0x35: (*dvmdata).divisor = 10000; strcpy((*dvmdata).prefix, "M"); break; case 0x36: (*dvmdata).divisor = 1000; strcpy((*dvmdata).prefix, "M"); break; case 0x37: (*dvmdata).divisor = 100; strcpy((*dvmdata).prefix, "M"); break; } break; } // Temperatur Grad F case 0x3D: { strcpy((*dvmdata).type,"Temperature"); strcpy((*dvmdata).unit, "°F"); switch (byte5) { case 0x30: (*dvmdata).divisor = 10; strcpy((*dvmdata).prefix, ""); break; } break; } // Unspecified case 0x3E: { strcpy((*dvmdata).type,"Unspecified"); strcpy((*dvmdata).unit, ""); switch (byte5) { default: (*dvmdata).divisor = 1; strcpy((*dvmdata).prefix, ""); break; } break; } // case 0x3F: { strcpy((*dvmdata).type,"%(4-20mA)"); strcpy((*dvmdata).unit, "%"); switch (byte5) { case 0x30: (*dvmdata).divisor = 1; strcpy((*dvmdata).prefix, ""); break; } break; } } // Ende switch (byte6) //sprintf(s,"%s%s%s",sign,prefix, unit); } int parity(unsigned char byte) { int count =0; int i; for (i=0; i<8; i++) { count += byte % 2; byte = byte >> 1; } count = count % 2; return count; } void del_parity(unsigned char *byte) { unsigned char andbyte = 0x7F; *byte = *byte & andbyte; } int set_dvm_data(char *bytes_eleven,struct dvm_data *dvmdata) { int n = 0; if ((bytes_eleven!=0) && (dvmdata!=0)) { int temppar = 0; // check and del parity bit for (n=0; n<11; n++) { if (parity(bytes_eleven[n])==1) { temppar+=1; } del_parity(&(bytes_eleven[n])); } if (temppar==8) { (*dvmdata).parity=1; } else { (*dvmdata).parity=0; } // anhand von byte 5, 6 und 8 Einheit, Range und Vorzeichen herausfinden dvm_unit(bytes_eleven[5], bytes_eleven[6], bytes_eleven[8], dvmdata); setSTATE_AUTO(bytes_eleven[8], dvmdata); setSTATE_ACDC(bytes_eleven[7], dvmdata); (*dvmdata).overload = isOverload(bytes_eleven); if ((*dvmdata).overload==0) { (*dvmdata).digits=10000.0*digit(bytes_eleven[0])+1000.0*digit(bytes_eleven[1])+100.0*digit(bytes_eleven[2])+10.0*digit(bytes_eleven[3])+1*digit(bytes_eleven[4]); } else { (*dvmdata).digits=0.0; } return 1; } return 0; }
