library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.NUMERIC_STD.ALL; entity tb_PWM is end tb_PWM; architecture tb of tb_PWM is component PWM is Port( clock : in std_logic; schalter : in std_logic_vector(9 downto 0); PWM_0 : out std_logic; PWM_1 : out std_logic); end component; signal clock : std_logic:='0'; signal schalter : std_logic_vector(9 downto 0):=(others => '0'); signal PWM_0 : std_logic:='0'; signal PWM_1 : std_logic:='0'; signal breite_0 : integer range 0 to 31:=0; signal breite_1 : integer range 0 to 31:=0; begin clock <= not clock after 10 ns; schalter <= std_logic_vector(to_unsigned(breite_1,5)) & std_logic_vector(to_unsigned(breite_0,5)); process begin breite_0 <= 10; breite_1 <= 16; wait for 10 us; breite_0 <= 23; breite_1 <= 9; wait for 10 us; breite_0 <= 31; breite_1 <= 0; wait; end process; uut: PWM Port Map( clock => clock, schalter => schalter, PWM_0 => PWM_0, PWM_1 => PWM_1); end;
