library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.NUMERIC_STD.ALL; entity sync_upcounter_tb is end entity; architecture tb of sync_upcounter_tb is component SOURCE is Port( CLK : in STD_LOGIC; SOP : out STD_LOGIC; EOP : out STD_LOGIC; DATA_IN : in STD_LOGIC_VECTOR(7 downto 0); DATA_OUT : out STD_LOGIC_VECTOR(7 downto 0); SCHALTER : in STD_LOGIC_VECTOR(9 downto 0) ); end component; signal CLK : STD_LOGIC := '0'; signal RST : STD_LOGIC := '0'; signal SOP : STD_LOGIC := '0'; signal EOP : STD_LOGIC := '0'; signal DATA_TO_SOURCE : unsigned(7 downto 0):=(others => '0'); signal DATA_FROM_SOURCE : STD_LOGIC_VECTOR(7 downto 0):=(others => '0'); signal SCHALTER : STD_LOGIC_VECTOR(9 downto 0):=(others => '0'); signal paketlaenge : integer range 0 to 1023:=13; begin CLK <= not CLK after 10 ns; DATA_TO_SOURCE <= DATA_TO_SOURCE + 1 after 100 ns; SCHALTER <= STD_LOGIC_VECTOR(to_unsigned(paketlaenge,10)); uut: SOURCE port map( CLK => CLK, SOP => SOP, EOP => EOP, DATA_IN => STD_LOGIC_VECTOR(DATA_TO_SOURCE), DATA_OUT => DATA_FROM_SOURCE, SCHALTER => SCHALTER ); end;
