/************************************************************\ ** Copyright (c) 2011-2021 Anlogic, Inc. ** All Right Reserved. \************************************************************/ /************************************************************\ ** Log : This file is generated by Anlogic IP Generator. ** File : E:/LicheeTangFPGA/Projects/myterminal/LVDS_800x600_test2/al_ip/PLL_2.v ** Date : 2021 04 06 ** TD version : 5.0.25341 \************************************************************/ /////////////////////////////////////////////////////////////////////////////// // Input frequency: 40.000Mhz // Clock multiplication factor: 5 // Clock division factor: 2 // Clock information: // Clock name | Frequency | Phase shift // C0 | 100.000000MHZ | 0 DEG // C1 | 40.000000 MHZ | 0 DEG /////////////////////////////////////////////////////////////////////////////// `timescale 1 ns / 100 fs module PLL_2(refclk, reset, stdby, extlock, clk0_out, clk1_out); input refclk; input reset; input stdby; output extlock; output clk0_out; output clk1_out; wire clk0_buf; EG_LOGIC_BUFG bufg_feedback( .i(clk0_buf), .o(clk0_out) ); EG_PHY_PLL #(.DPHASE_SOURCE("DISABLE"), .DYNCFG("DISABLE"), .FIN("40.000"), .FEEDBK_MODE("NORMAL"), .FEEDBK_PATH("CLKC0_EXT"), .STDBY_ENABLE("ENABLE"), .PLLRST_ENA("ENABLE"), .SYNC_ENABLE("DISABLE"), .DERIVE_PLL_CLOCKS("DISABLE"), .GEN_BASIC_CLOCK("DISABLE"), .GMC_GAIN(2), .ICP_CURRENT(9), .KVCO(2), .LPF_CAPACITOR(1), .LPF_RESISTOR(8), .REFCLK_DIV(2), .FBCLK_DIV(5), .CLKC0_ENABLE("ENABLE"), .CLKC0_DIV(10), .CLKC0_CPHASE(9), .CLKC0_FPHASE(0), .CLKC1_ENABLE("ENABLE"), .CLKC1_DIV(25), .CLKC1_CPHASE(24), .CLKC1_FPHASE(0) ) pll_inst (.refclk(refclk), .reset(reset), .stdby(stdby), .extlock(extlock), .load_reg(1'b0), .psclk(1'b0), .psdown(1'b0), .psstep(1'b0), .psclksel(3'b000), .psdone(open), .dclk(1'b0), .dcs(1'b0), .dwe(1'b0), .di(8'b00000000), .daddr(6'b000000), .do({open, open, open, open, open, open, open, open}), .fbclk(clk0_out), .clkc({open, open, open, clk1_out, clk0_buf})); endmodule
