---------------------------------------------------------------------------------- -- Company: -- Engineer: -- -- Create Date: 20.03.2021 18:30:48 -- Design Name: -- Module Name: fsm - Behavioral -- Project Name: -- Target Devices: -- Tool Versions: -- Description: -- -- Dependencies: -- -- Revision: -- Revision 0.01 - File Created -- Additional Comments: -- ---------------------------------------------------------------------------------- library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.NUMERIC_STD.ALL; -- Uncomment the following library declaration if using -- arithmetic functions with Signed or Unsigned values --use IEEE.NUMERIC_STD.ALL; -- Uncomment the following library declaration if instantiating -- any Xilinx leaf cells in this code. --library UNISIM; --use UNISIM.VComponents.all; entity fsm is Port ( clk : in STD_LOGIC; reset : in STD_LOGIC; ain : in STD_LOGIC; count : out STD_LOGIC_VECTOR(3 downto 0); yout : out STD_LOGIC); end fsm; architecture Behavioral of fsm is type state_type is (S0,S1,S2); signal state : state_type; signal count_int : unsigned (3 downto 0) := "0000"; begin sync_proc : process(clk) begin if rising_edge(clk) then if (reset = '1') then state <= S0; yout <= '0'; else case(state) is when S0 => if ain = '1' then yout <= '1'; if count_int = "1111" then state <= state; count_int <= "0000"; else state <= S1; count_int <= count_int + 1; end if; else state <= state; count_int <= count_int; yout <= '0'; end if; when S1 => yout <= '0'; if ain = '1' then state <= S2; count_int <= count_int + 1; else state <= state; count_int <= count_int; end if; when S2 => yout <= '0'; if ain = '1' then state <= S0; count_int <= count_int + 1; else state <= state; count_int <= count_int; end if; when others => state <= S0; count_int <= "0000"; yout <= '0'; end case; end if; end if; end process; count <= std_logic_vector(count_int); end Behavioral;
