[code] Serial Monitor Dump 06:21:39.959 -> 0) 289037E40C000086: Res=11 Temp=20.25C 06:21:39.959 -> 1) 2846A8E50C0000A7: Res=11 Temp=20.38C 06:21:40.013 -> 2) 28E343E40C000035: Res=11 Temp=19.88C Min=19.88C Max=20.38C 06:21:51.952 -> 0) 289037E40C000086: Res=11 Temp=20.25C 06:21:51.952 -> 1) 2846A8E50C0000A7: Res=11 Temp=20.38C 06:21:51.999 -> 2) 28E343E40C000035: Res=11 Temp=19.88C Min=19.88C Max=20.38C 06:22:03.939 -> 0) 289037E40C000086: Res=11 Temp=20.25C 06:22:03.992 -> 1) 2846A8E50C0000A7: Res=11 Temp=20.25C 06:22:03.992 -> 2) 28E343E40C000035: Res=11 Temp=19.75C Min=19.75C Max=20.25C 06:22:33.265 -> 0) 289037E40C000086: Res=11 Temp=20.13C 06:22:33.265 -> 1) 2846A8E50C0000A7: Res=11 Temp=20.25C 06:22:33.265 -> 2) 28E343E40C000035: Res=11 Temp=19.75C Min=19.75C Max=20.25C 06:22:33.265 -> 0) 289037E40C000086: Res=11 Temp=20.25C 06:22:33.265 -> 1) 2846A8E50C0000A7: Res=11 Temp=20.38C 06:22:33.265 -> 2) 28E343E40C000035: Res=11 Temp=19.88C Min=19.88C Max=20.38C 06:22:39.956 -> 0) 289037E40C000086: Res=11 Temp=20.25C 06:22:39.956 -> 1) 2846A8E50C0000A7: Res=11 Temp=20.38C 06:22:40.009 -> 2) 28E343E40C000035: Res=11 Temp=20.00C Min=20.00C Max=20.38C 06:22:51.947 -> 0) 289037E40C000086: Res=11 Temp=20.25C 06:22:51.994 -> 1) 2846A8E50C0000A7: Res=11 Temp=20.38C 06:22:51.994 -> 2) 28E343E40C000035: Res=11 Temp=20.13C Min=20.13C Max=20.38C 06:23:03.934 -> 0) 289037E40C000086: Res=11 Temp=20.25C 06:23:03.987 -> 1) 2846A8E50C0000A7: Res=11 Temp=20.25C 06:23:03.987 -> 2) 28E343E40C000035: Res=11 Temp=20.13C Min=20.13C Max=20.25C 06:23:15.927 -> 0) 289037E40C000086: Res=11 Temp=20.13C 06:23:15.974 -> 1) 2846A8E50C0000A7: Res=11 Temp=20.25C 06:23:15.974 -> 2) 28E343E40C000035: Res=11 Temp=20.13C Min=20.13C Max=20.25C 06:23:27.962 -> 0) 289037E40C000086: Res=11 Temp=20.13C 06:23:27.962 -> 1) 2846A8E50C0000A7: Res=11 Temp=20.13C 06:23:28.009 -> 2) 28E343E40C000035: Res=11 Temp=20.13C Min=20.13C Max=20.13C 06:23:39.946 -> 0) 289037E40C000086: Res=11 Temp=20.13C 06:23:40.000 -> 1) 2846A8E50C0000A7: Res=11 Temp=20.13C 06:23:40.000 -> 2) 28E343E40C000035: Res=11 Temp=20.25C Min=20.13C Max=20.25C 06:23:51.987 -> 0) 289037E40C000086: Res=11 Temp=20.13C 06:23:51.987 -> 1) 2846A8E50C0000A7: Res=11 Temp=20.13C 06:23:52.040 -> 2) 28E343E40C000035: Res=11 Temp=20.25C Min=20.13C Max=20.25C 06:24:03.924 -> 0) 289037E40C000086: Res=11 Temp=20.13C 06:24:03.977 -> 1) 2846A8E50C0000A7: Res=11 Temp=20.13C 06:24:03.977 -> 2) 28E343E40C000035: Res=11 Temp=20.25C Min=20.13C Max=20.25C 06:24:15.963 -> 0) 289037E40C000086: Res=11 Temp=20.13C 06:24:15.963 -> 1) 2846A8E50C0000A7: Res=11 Temp=20.13C 06:24:16.016 -> 2) 28E343E40C000035: Res=11 Temp=20.25C Min=20.13C Max=20.25C 06:24:27.956 -> 0) 289037E40C000086: Res=11 Temp=20.00C 06:24:27.956 -> 1) 2846A8E50C0000A7: Res=11 Temp=20.13C 06:24:28.003 -> 2) 28E343E40C000035: Res=11 Temp=20.25C Min=20.00C Max=20.25C 06:24:38.893 -> [Echo]: jetzt wird ein Sensor oberhalb des Prozessors platziert 06:24:39.943 -> 0) 289037E40C000086: Res=11 Temp=20.00C 06:24:39.997 -> 1) 2846A8E50C0000A7: Res=11 Temp=20.13C 06:24:39.997 -> 2) 28E343E40C000035: Res=11 Temp=20.25C Min=20.00C Max=20.25C 06:24:51.937 -> 0) 289037E40C000086: Res=11 Temp=20.13C 06:24:51.984 -> 1) 2846A8E50C0000A7: Res=11 Temp=20.13C 06:24:51.984 -> 2) 28E343E40C000035: Res=11 Temp=20.50C Min=20.13C Max=20.50C 06:25:03.923 -> 0) 289037E40C000086: Res=11 Temp=20.13C 06:25:03.976 -> 1) 2846A8E50C0000A7: Res=11 Temp=20.25C 06:25:03.976 -> 2) 28E343E40C000035: Res=11 Temp=20.63C Min=20.13C Max=20.63C 06:25:15.962 -> 0) 289037E40C000086: Res=11 Temp=20.25C 06:25:15.962 -> 1) 2846A8E50C0000A7: Res=11 Temp=20.25C 06:25:16.015 -> 2) 28E343E40C000035: Res=11 Temp=21.25C Min=20.25C Max=21.25C 06:25:27.955 -> 0) 289037E40C000086: Res=11 Temp=20.25C 06:25:27.955 -> 1) 2846A8E50C0000A7: Res=11 Temp=20.25C 06:25:28.002 -> 2) 28E343E40C000035: Res=11 Temp=21.75C Min=20.25C Max=21.75C 06:25:39.943 -> 0) 289037E40C000086: Res=11 Temp=20.25C 06:25:39.996 -> 1) 2846A8E50C0000A7: Res=11 Temp=20.25C 06:25:39.996 -> 2) 28E343E40C000035: Res=11 Temp=22.13C Min=20.25C Max=22.13C 06:25:51.937 -> 0) 289037E40C000086: Res=11 Temp=20.25C 06:25:51.984 -> 1) 2846A8E50C0000A7: Res=11 Temp=20.25C 06:25:51.984 -> 2) 28E343E40C000035: Res=11 Temp=22.38C Min=20.25C Max=22.38C 06:26:03.922 -> 0) 289037E40C000086: Res=11 Temp=20.25C 06:26:03.975 -> 1) 2846A8E50C0000A7: Res=11 Temp=20.25C 06:26:03.975 -> 2) 28E343E40C000035: Res=11 Temp=22.63C Min=20.25C Max=22.63C 06:26:15.962 -> 0) 289037E40C000086: Res=11 Temp=20.25C 06:26:15.962 -> 1) 2846A8E50C0000A7: Res=11 Temp=20.25C 06:26:16.016 -> 2) 28E343E40C000035: Res=11 Temp=22.88C Min=20.25C Max=22.88C 06:26:27.958 -> 0) 289037E40C000086: Res=11 Temp=20.25C 06:26:27.958 -> 1) 2846A8E50C0000A7: Res=11 Temp=20.25C 06:26:28.004 -> 2) 28E343E40C000035: Res=11 Temp=23.00C Min=20.25C Max=23.00C 06:26:39.946 -> 0) 289037E40C000086: Res=11 Temp=20.25C 06:26:39.999 -> 1) 2846A8E50C0000A7: Res=11 Temp=20.38C 06:26:39.999 -> 2) 28E343E40C000035: Res=11 Temp=23.13C Min=20.25C Max=23.13C 06:26:51.941 -> 0) 289037E40C000086: Res=11 Temp=20.25C 06:26:51.988 -> 1) 2846A8E50C0000A7: Res=11 Temp=20.25C 06:26:51.988 -> 2) 28E343E40C000035: Res=11 Temp=23.25C Min=20.25C Max=23.25C 06:27:03.929 -> 0) 289037E40C000086: Res=11 Temp=20.25C 06:27:03.982 -> 1) 2846A8E50C0000A7: Res=11 Temp=20.25C 06:27:03.982 -> 2) 28E343E40C000035: Res=11 Temp=23.25C Min=20.25C Max=23.25C 06:27:15.924 -> 0) 289037E40C000086: Res=11 Temp=20.13C 06:27:15.971 -> 1) 2846A8E50C0000A7: Res=11 Temp=20.25C 06:27:16.024 -> 2) 28E343E40C000035: Res=11 Temp=23.38C Min=20.13C Max=23.38C 06:27:27.966 -> 0) 289037E40C000086: Res=11 Temp=20.38C 06:27:27.966 -> 1) 2846A8E50C0000A7: Res=11 Temp=20.38C 06:27:28.013 -> 2) 28E343E40C000035: Res=11 Temp=23.25C Min=20.38C Max=23.25C 06:27:39.954 -> 0) 289037E40C000086: Res=11 Temp=20.38C 06:27:39.954 -> 1) 2846A8E50C0000A7: Res=11 Temp=20.50C 06:27:40.008 -> 2) 28E343E40C000035: Res=11 Temp=23.13C Min=20.38C Max=23.13C 06:27:51.949 -> 0) 289037E40C000086: Res=11 Temp=20.50C 06:27:51.949 -> 1) 2846A8E50C0000A7: Res=11 Temp=20.63C 06:27:51.996 -> 2) 28E343E40C000035: Res=11 Temp=23.00C Min=20.50C Max=23.00C 06:27:58.572 -> [Echo]: jetzt nicht mehr oberhalb, sondern unterhalb des Prozessors 06:28:03.937 -> 0) 289037E40C000086: Res=11 Temp=20.63C 06:28:03.991 -> 1) 2846A8E50C0000A7: Res=11 Temp=20.63C 06:28:03.991 -> 2) 28E343E40C000035: Res=11 Temp=23.00C Min=20.63C Max=23.00C 06:28:15.932 -> 0) 289037E40C000086: Res=11 Temp=20.75C 06:28:15.979 -> 1) 2846A8E50C0000A7: Res=11 Temp=20.75C 06:28:15.979 -> 2) 28E343E40C000035: Res=11 Temp=22.88C Min=20.75C Max=22.88C 06:28:24.361 -> [Echo]: der Versuchsaufbau ist offen, ohne Gehuse, alle Sensoren gut belftet 06:28:27.973 -> 0) 289037E40C000086: Res=11 Temp=20.75C 06:28:27.973 -> 1) 2846A8E50C0000A7: Res=11 Temp=20.75C 06:28:27.973 -> 2) 28E343E40C000035: Res=11 Temp=22.75C Min=20.75C Max=22.75C 06:28:39.961 -> 0) 289037E40C000086: Res=11 Temp=20.75C 06:28:39.961 -> 1) 2846A8E50C0000A7: Res=11 Temp=20.88C 06:28:40.014 -> 2) 28E343E40C000035: Res=11 Temp=22.75C Min=20.75C Max=22.75C 06:28:51.955 -> 0) 289037E40C000086: Res=11 Temp=20.88C 06:28:51.955 -> 1) 2846A8E50C0000A7: Res=11 Temp=20.88C 06:28:52.002 -> 2) 28E343E40C000035: Res=11 Temp=22.63C Min=20.88C Max=22.63C 06:29:03.943 -> 0) 289037E40C000086: Res=11 Temp=20.88C 06:29:03.996 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.00C 06:29:03.996 -> 2) 28E343E40C000035: Res=11 Temp=22.63C Min=20.88C Max=22.63C 06:29:15.936 -> 0) 289037E40C000086: Res=11 Temp=21.00C 06:29:15.983 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.00C 06:29:15.983 -> 2) 28E343E40C000035: Res=11 Temp=22.63C Min=21.00C Max=22.63C 06:29:27.924 -> 0) 289037E40C000086: Res=11 Temp=21.00C 06:29:27.977 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.13C 06:29:27.977 -> 2) 28E343E40C000035: Res=11 Temp=22.63C Min=21.00C Max=22.63C 06:29:39.965 -> 0) 289037E40C000086: Res=11 Temp=21.13C 06:29:39.965 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.13C 06:29:40.019 -> 2) 28E343E40C000035: Res=11 Temp=22.50C Min=21.13C Max=22.50C 06:29:51.960 -> 0) 289037E40C000086: Res=11 Temp=21.13C 06:29:51.960 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.13C 06:29:52.007 -> 2) 28E343E40C000035: Res=11 Temp=22.50C Min=21.13C Max=22.50C 06:30:03.946 -> 0) 289037E40C000086: Res=11 Temp=21.13C 06:30:03.946 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.25C 06:30:04.000 -> 2) 28E343E40C000035: Res=11 Temp=22.50C Min=21.13C Max=22.50C 06:30:15.940 -> 0) 289037E40C000086: Res=11 Temp=21.13C 06:30:15.987 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.25C 06:30:15.987 -> 2) 28E343E40C000035: Res=11 Temp=22.50C Min=21.13C Max=22.50C 06:30:27.928 -> 0) 289037E40C000086: Res=11 Temp=21.25C 06:30:27.982 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.25C 06:30:27.982 -> 2) 28E343E40C000035: Res=11 Temp=22.50C Min=21.25C Max=22.50C 06:30:39.922 -> 0) 289037E40C000086: Res=11 Temp=21.25C 06:30:39.969 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.38C 06:30:40.023 -> 2) 28E343E40C000035: Res=11 Temp=22.50C Min=21.25C Max=22.50C 06:30:51.962 -> 0) 289037E40C000086: Res=11 Temp=21.25C 06:30:51.962 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.38C 06:30:52.009 -> 2) 28E343E40C000035: Res=11 Temp=22.50C Min=21.25C Max=22.50C 06:31:02.945 -> [Echo]: jetzt wird das LCD AUS-geschaltet 06:31:03.948 -> 0) 289037E40C000086: Res=11 Temp=21.25C 06:31:03.948 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.38C 06:31:04.002 -> 2) 28E343E40C000035: Res=11 Temp=22.50C Min=21.25C Max=22.50C 06:31:15.942 -> 0) 289037E40C000086: Res=11 Temp=21.38C 06:31:15.942 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.38C 06:31:15.989 -> 2) 28E343E40C000035: Res=11 Temp=22.50C Min=21.38C Max=22.50C 06:31:27.929 -> 0) 289037E40C000086: Res=11 Temp=21.25C 06:31:27.983 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.38C 06:31:27.983 -> 2) 28E343E40C000035: Res=11 Temp=22.50C Min=21.25C Max=22.50C 06:31:39.924 -> 0) 289037E40C000086: Res=11 Temp=21.38C 06:31:39.971 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.50C 06:31:39.971 -> 2) 28E343E40C000035: Res=11 Temp=22.50C Min=21.38C Max=22.50C 06:31:51.912 -> 0) 289037E40C000086: Res=11 Temp=21.38C 06:31:51.966 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.50C 06:31:51.966 -> 2) 28E343E40C000035: Res=11 Temp=22.50C Min=21.38C Max=22.50C 06:32:03.952 -> 0) 289037E40C000086: Res=11 Temp=21.38C 06:32:03.952 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.50C 06:32:04.006 -> 2) 28E343E40C000035: Res=11 Temp=22.50C Min=21.38C Max=22.50C 06:32:15.946 -> 0) 289037E40C000086: Res=11 Temp=21.38C 06:32:15.946 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.50C 06:32:15.993 -> 2) 28E343E40C000035: Res=11 Temp=22.50C Min=21.38C Max=22.50C 06:32:27.930 -> 0) 289037E40C000086: Res=11 Temp=21.38C 06:32:27.984 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.38C 06:32:27.984 -> 2) 28E343E40C000035: Res=11 Temp=22.50C Min=21.38C Max=22.50C 06:32:39.922 -> 0) 289037E40C000086: Res=11 Temp=21.38C 06:32:39.969 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.38C 06:32:39.969 -> 2) 28E343E40C000035: Res=11 Temp=22.50C Min=21.38C Max=22.50C 06:32:51.928 -> 0) 289037E40C000086: Res=11 Temp=21.38C 06:32:51.968 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.50C 06:32:51.968 -> 2) 28E343E40C000035: Res=11 Temp=22.50C Min=21.38C Max=22.50C 06:33:03.941 -> 0) 289037E40C000086: Res=11 Temp=21.38C 06:33:03.941 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.50C 06:33:03.994 -> 2) 28E343E40C000035: Res=11 Temp=22.50C Min=21.38C Max=22.50C 06:33:11.064 -> [Echo]: jetzt wird das WLAN/WiFi AUS-geschaltet 06:33:14.930 -> [Echo]: w0 06:33:15.933 -> 0) 289037E40C000086: Res=11 Temp=21.38C 06:33:15.933 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.50C 06:33:15.980 -> 2) 28E343E40C000035: Res=11 Temp=22.50C Min=21.38C Max=22.50C 06:33:27.923 -> 0) 289037E40C000086: Res=11 Temp=21.50C 06:33:27.976 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.50C 06:33:27.976 -> 2) 28E343E40C000035: Res=11 Temp=22.50C Min=21.50C Max=22.50C 06:33:39.919 -> 0) 289037E40C000086: Res=11 Temp=21.50C 06:33:39.965 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.50C 06:33:39.965 -> 2) 28E343E40C000035: Res=11 Temp=22.50C Min=21.50C Max=22.50C 06:33:51.907 -> 0) 289037E40C000086: Res=11 Temp=21.38C 06:33:51.960 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.50C 06:33:51.960 -> 2) 28E343E40C000035: Res=11 Temp=22.50C Min=21.38C Max=22.50C 06:34:03.949 -> 0) 289037E40C000086: Res=11 Temp=21.38C 06:34:03.949 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.50C 06:34:04.003 -> 2) 28E343E40C000035: Res=11 Temp=22.38C Min=21.38C Max=22.38C 06:34:15.945 -> 0) 289037E40C000086: Res=11 Temp=21.38C 06:34:15.945 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.50C 06:34:15.992 -> 2) 28E343E40C000035: Res=11 Temp=22.38C Min=21.38C Max=22.38C 06:34:27.934 -> 0) 289037E40C000086: Res=11 Temp=21.50C 06:34:27.934 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.50C 06:34:27.987 -> 2) 28E343E40C000035: Res=11 Temp=22.38C Min=21.50C Max=22.38C 06:34:39.929 -> 0) 289037E40C000086: Res=11 Temp=21.50C 06:34:39.976 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.50C 06:34:39.976 -> 2) 28E343E40C000035: Res=11 Temp=22.25C Min=21.50C Max=22.25C 06:34:51.918 -> 0) 289037E40C000086: Res=11 Temp=21.50C 06:34:51.972 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.63C 06:34:51.972 -> 2) 28E343E40C000035: Res=11 Temp=22.13C Min=21.50C Max=22.13C 06:35:03.913 -> 0) 289037E40C000086: Res=11 Temp=21.50C 06:35:03.960 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.63C 06:35:03.960 -> 2) 28E343E40C000035: Res=11 Temp=22.38C Min=21.50C Max=22.38C 06:35:15.200 -> [Echo]: jetzt wird der eine Sensor neben dem Prozessor platziert 06:35:15.956 -> 0) 289037E40C000086: Res=11 Temp=21.50C 06:35:15.956 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.63C 06:35:15.956 -> 2) 28E343E40C000035: Res=11 Temp=22.63C Min=21.50C Max=22.63C 06:35:27.945 -> 0) 289037E40C000086: Res=11 Temp=21.50C 06:35:27.945 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.63C 06:35:27.998 -> 2) 28E343E40C000035: Res=11 Temp=22.75C Min=21.50C Max=22.75C 06:35:39.940 -> 0) 289037E40C000086: Res=11 Temp=21.50C 06:35:39.940 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.63C 06:35:39.987 -> 2) 28E343E40C000035: Res=11 Temp=22.88C Min=21.50C Max=22.88C 06:35:51.929 -> 0) 289037E40C000086: Res=11 Temp=21.50C 06:35:51.929 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.63C 06:35:51.983 -> 2) 28E343E40C000035: Res=11 Temp=23.00C Min=21.50C Max=23.00C 06:36:03.924 -> 0) 289037E40C000086: Res=11 Temp=21.50C 06:36:03.971 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.63C 06:36:03.971 -> 2) 28E343E40C000035: Res=11 Temp=23.00C Min=21.50C Max=23.00C 06:36:15.913 -> 0) 289037E40C000086: Res=11 Temp=21.50C 06:36:15.966 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.63C 06:36:15.966 -> 2) 28E343E40C000035: Res=11 Temp=23.00C Min=21.50C Max=23.00C 06:36:27.908 -> 0) 289037E40C000086: Res=11 Temp=21.63C 06:36:27.955 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.63C 06:36:27.955 -> 2) 28E343E40C000035: Res=11 Temp=23.00C Min=21.63C Max=23.00C 06:36:39.951 -> 0) 289037E40C000086: Res=11 Temp=21.63C 06:36:39.951 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.75C 06:36:39.998 -> 2) 28E343E40C000035: Res=11 Temp=22.75C Min=21.63C Max=22.75C 06:36:51.939 -> 0) 289037E40C000086: Res=11 Temp=21.63C 06:36:51.939 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.88C 06:36:51.992 -> 2) 28E343E40C000035: Res=11 Temp=22.63C Min=21.63C Max=22.63C "06:36:56.809 -> [Echo]: jetzt wird der vermeintlich ""defekte"" Sensor neben den anderen beiden platziert 06:37:03.933 -> 0) 289037E40C000086: Res=11 Temp=21.63C 06:37:03.933 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.88C 06:37:03.980 -> 2) 28E343E40C000035: Res=11 Temp=22.63C Min=21.63C Max=22.63C 06:37:15.922 -> 0) 289037E40C000086: Res=11 Temp=21.50C 06:37:15.976 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.75C 06:37:15.976 -> 2) 28E343E40C000035: Res=11 Temp=22.50C Min=21.50C Max=22.50C 06:37:27.918 -> 0) 289037E40C000086: Res=11 Temp=21.50C 06:37:27.965 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.75C 06:37:27.965 -> 2) 28E343E40C000035: Res=11 Temp=22.38C Min=21.50C Max=22.38C 06:37:39.907 -> 0) 289037E40C000086: Res=11 Temp=21.50C 06:37:39.960 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.75C 06:37:39.960 -> 2) 28E343E40C000035: Res=11 Temp=22.25C Min=21.50C Max=22.25C 06:37:51.949 -> 0) 289037E40C000086: Res=11 Temp=21.50C 06:37:51.949 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.63C 06:37:52.002 -> 2) 28E343E40C000035: Res=11 Temp=22.25C Min=21.50C Max=22.25C 06:38:03.944 -> 0) 289037E40C000086: Res=11 Temp=21.50C 06:38:03.944 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.63C 06:38:03.991 -> 2) 28E343E40C000035: Res=11 Temp=22.13C Min=21.50C Max=22.13C 06:38:15.933 -> 0) 289037E40C000086: Res=11 Temp=21.50C 06:38:15.933 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.63C 06:38:15.986 -> 2) 28E343E40C000035: Res=11 Temp=22.00C Min=21.50C Max=22.00C 06:38:27.929 -> 0) 289037E40C000086: Res=11 Temp=21.50C 06:38:27.929 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.63C 06:38:27.975 -> 2) 28E343E40C000035: Res=11 Temp=22.00C Min=21.50C Max=22.00C 06:38:39.918 -> 0) 289037E40C000086: Res=11 Temp=21.50C 06:38:39.971 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.63C 06:38:39.971 -> 2) 28E343E40C000035: Res=11 Temp=21.88C Min=21.50C Max=21.88C 06:38:51.912 -> 0) 289037E40C000086: Res=11 Temp=21.50C 06:38:51.959 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.63C 06:38:51.959 -> 2) 28E343E40C000035: Res=11 Temp=21.88C Min=21.50C Max=21.88C 06:39:03.953 -> 0) 289037E40C000086: Res=11 Temp=21.50C 06:39:03.953 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.63C 06:39:03.953 -> 2) 28E343E40C000035: Res=11 Temp=21.75C Min=21.50C Max=21.75C 06:39:15.942 -> 0) 289037E40C000086: Res=11 Temp=21.50C 06:39:15.942 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.63C 06:39:15.995 -> 2) 28E343E40C000035: Res=11 Temp=21.75C Min=21.50C Max=21.75C 06:39:27.937 -> 0) 289037E40C000086: Res=11 Temp=21.50C 06:39:27.937 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.63C 06:39:27.984 -> 2) 28E343E40C000035: Res=11 Temp=21.75C Min=21.50C Max=21.75C 06:39:39.925 -> 0) 289037E40C000086: Res=11 Temp=21.50C 06:39:39.979 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.63C 06:39:39.979 -> 2) 28E343E40C000035: Res=11 Temp=21.63C Min=21.50C Max=21.63C 06:39:51.921 -> 0) 289037E40C000086: Res=11 Temp=21.63C 06:39:51.968 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.63C 06:39:51.968 -> 2) 28E343E40C000035: Res=11 Temp=21.63C Min=21.63C Max=21.63C 06:40:03.963 -> 0) 289037E40C000086: Res=11 Temp=21.63C 06:40:03.963 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.63C 06:40:04.010 -> 2) 28E343E40C000035: Res=11 Temp=21.75C Min=21.63C Max=21.75C 06:40:15.951 -> 0) 289037E40C000086: Res=11 Temp=21.63C 06:40:15.951 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.63C 06:40:16.005 -> 2) 28E343E40C000035: Res=11 Temp=21.63C Min=21.63C Max=21.63C 06:40:27.947 -> 0) 289037E40C000086: Res=11 Temp=21.50C 06:40:27.947 -> 1) 2846A8E50C0000A7: Res=11 Temp=21.63C 06:40:27.994 -> 2) 28E343E40C000035: Res=11 Temp=21.63C Min=21.50C Max=21.63C [/code]
