/*------------------------------------------------------------------------*/ /* STM32F100: MMCv3/SDv1/SDv2 (SPI mode) control module */ /*------------------------------------------------------------------------*/ /* / Copyright (C) 2014, ChaN, all right reserved. / / * This software is a free software and there is NO WARRANTY. / * No restriction on use. You can use, modify and redistribute it for / personal, non-profit or commercial products UNDER YOUR RESPONSIBILITY. / * Redistributions of source code must retain the above copyright notice. / /-------------------------------------------------------------------------*/ #include "stm32f10x_conf.h" #include "system_stm32f10x.h" /* -------------- C Standard Include Files --------------- */ #include #include #include #include #include "rtc_user.h" #include "diskio.h" #define _BV(bit) (1 << (bit)) /* PA4:MMC_CS, PA5:MMC_SCLK, PA6:MMC_DO, PA7:MMC_DI, PC4:MMC_CD */ #define CS_HIGH() GPIO_SetBits(GPIOA,GPIO_Pin_4) #define CS_LOW() GPIO_ResetBits(GPIOA,GPIO_Pin_4) #define MMC_CD 1 // !(GPIOC_IDR & _BV(4)) /* Card detect (yes:true, no:false, default:true) */ #define MMC_WP 0 /* Write protected (yes:true, no:false, default:false) */ /*-------------------------------------------------------------------------- Module Private Functions ---------------------------------------------------------------------------*/ static BYTE xchg_spi(BYTE); /* MMC/SD command */ #define CMD0 (0) /* GO_IDLE_STATE */ #define CMD1 (1) /* SEND_OP_COND (MMC) */ #define ACMD41 (0x80+41) /* SEND_OP_COND (SDC) */ #define CMD8 (8) /* SEND_IF_COND */ #define CMD9 (9) /* SEND_CSD */ #define CMD10 (10) /* SEND_CID */ #define CMD12 (12) /* STOP_TRANSMISSION */ #define ACMD13 (0x80+13) /* SD_STATUS (SDC) */ #define CMD16 (16) /* SET_BLOCKLEN */ #define CMD17 (17) /* READ_SINGLE_BLOCK */ #define CMD18 (18) /* READ_MULTIPLE_BLOCK */ #define CMD23 (23) /* SET_BLOCK_COUNT (MMC) */ #define ACMD23 (0x80+23) /* SET_WR_BLK_ERASE_COUNT (SDC) */ #define CMD24 (24) /* WRITE_BLOCK */ #define CMD25 (25) /* WRITE_MULTIPLE_BLOCK */ #define CMD32 (32) /* ERASE_ER_BLK_START */ #define CMD33 (33) /* ERASE_ER_BLK_END */ #define CMD38 (38) /* ERASE */ #define CMD55 (55) /* APP_CMD */ #define CMD58 (58) /* READ_OCR */ static volatile DSTATUS Stat = STA_NOINIT; /* Physical drive status */ static volatile uint32_t Timer1, Timer2; /* 1kHz decrement timer stopped at zero (disk_timerproc()) */ static uint8_t CardType; /* Card type flags */ /* Initialize MMC interface */ void init_spi() { GPIO_InitTypeDef GPIO_InitStructure; /* Clocks einschalten */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_AFIO, ENABLE); RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1, ENABLE); // Clock aufschalten /* Glitch vermeiden */ GPIO_SetBits(GPIOA,GPIO_Pin_4); /* MISO A6 MOSI A7 SCK A5 CS A4 */ /* Port A4 - SPI CS konfigurieren*/ GPIO_StructInit(&GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOA, &GPIO_InitStructure); /* A5 (SCK) / A7 (MOSI) auf AF konfigurieren*/ GPIO_StructInit(&GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_7; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOA, &GPIO_InitStructure); /* A6 (MISO) auf IN konfigurieren*/ GPIO_StructInit(&GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOA, &GPIO_InitStructure); /* Die SPI 1 einstellen */ SPI_InitTypeDef SPI_InitStruct; SPI_InitStruct.SPI_Direction = SPI_Direction_2Lines_FullDuplex; SPI_InitStruct.SPI_BaudRatePrescaler = 64; SPI_InitStruct.SPI_Mode = SPI_Mode_Master; SPI_InitStruct.SPI_DataSize = SPI_DataSize_8b; SPI_InitStruct.SPI_CPOL = SPI_CPOL_Low; SPI_InitStruct.SPI_CPHA = SPI_CPHA_1Edge; SPI_InitStruct.SPI_NSS = SPI_NSS_Soft; // Slave Select by Software SPI_InitStruct.SPI_FirstBit = SPI_FirstBit_MSB; SPI_Init(SPI1, &SPI_InitStruct); SPI_Cmd(SPI1, ENABLE); CS_HIGH(); DWT_Delay_ms(10); } /*---------------------------------------------------------*/ /* User provided RTC function for FatFs module */ /*---------------------------------------------------------*/ /* This is a real time clock service to be called back */ /* from FatFs module. */ #if !FF_FS_NORTC && !FF_FS_READONLY uint32_t get_fattime (void) { RTCTIME rtc; /* Get local time */ if (!rtc_gettime(&rtc)) return 0; /* Pack date and time into a uint32_t variable */ return ((uint32_t)(rtc.year - 1980) << 25) | ((uint32_t)rtc.month << 21) | ((uint32_t)rtc.mday << 16) | ((uint32_t)rtc.hour << 11) | ((uint32_t)rtc.min << 5) | ((uint32_t)rtc.sec >> 1); } #endif /*-----------------------------------------------------------------------*/ /* SPI controls (Platform dependent) */ /*-----------------------------------------------------------------------*/ void init_spi(); /* Initialize SPI */ #define FCLK_SLOW() { SPI1->CR1 = (SPI1->CR1 & ~0x38) | SPI_BaudRatePrescaler_64; } /* Set SCLK = PCLK / 64 */ #define FCLK_FAST() { SPI1->CR1 = (SPI1->CR1 & ~0x38) | SPI_BaudRatePrescaler_4; } /* Set SCLK = PCLK / 8 */ /* --------- Wechselt auf den 16 Bit Mode -------- */ __attribute__((always_inline)) inline void SPI_16Bit() { /* SPI abschalten */ SPI_Cmd(SPI1, DISABLE); /* Setze Bit für 16 Bit Worte */ SPI1->CR1 |= SPI_CR1_DFF; /* SPI wieder einschalten */ SPI_Cmd(SPI1, ENABLE); } /* --------- Wechselt auf den 8 Bit Mode ---------- */ __attribute__((always_inline)) inline void SPI_8Bit() { /* SPI abschalten */ SPI_Cmd(SPI1, DISABLE); /* 16 Bit auf 8 Bit setzen */ SPI1->CR1 &= ~SPI_CR1_DFF; /* SPI wieder einschalten */ SPI_Cmd(SPI1, ENABLE); } /* TXE Bit: 1 = TX Register ist frei, 0 = Übertragung läuft Wird von Hardware automatisch gesetzt und gelöscht RXE Bit: 1 = Neues Byte im Empfangspuffer angekommen, Übertragung ist beendet 0 = Empfang läuft noch Bit wird duch Lesen von DR Register gelöscht Neue Übertragung möglich wenn TXE = 0 */ /* Exchange a byte */ __attribute__((always_inline)) inline static BYTE xchg_spi (BYTE dat) { SetLED(GELB,ENABLE); /* Warte bis TXE frei ist */ while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET); /* Daten senden */ SPI_I2S_SendData(SPI1,dat); /* Warte bis Byte empfangen wurde */ while (!(SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == SET)); SetLED(GELB,DISABLE); return ((BYTE)SPI_I2S_ReceiveData(SPI1)); /* Return received byte */ } /* Receive multiple byte */ static void rcvr_spi_multi ( BYTE *buff, /* Pointer to data buffer */ UINT btr /* Number of bytes to receive (even number) */ ) { WORD d; SetLED(GELB,ENABLE); SPI_16Bit(); while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET); /* Warte bis TX Register frei */ SPI1->DR = 0xFFFF; /* Start the first SPI transaction */ btr -= 2; do { /* Receive the data block into buffer */ while (!(SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == SET)); /* Warte bis Byte empfangen wurde */ d = SPI_I2S_ReceiveData(SPI1); /* Byte abholen */ while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET); /* Warte bis TX Register frei */ SPI_I2S_SendData(SPI1,0xffff); /* Starte nächste übertragung */ buff[1] = d; buff[0] = d >> 8; buff += 2; } while (btr -= 2); /* Warte bis letztes Byte empfangen wurde */ while (!(SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == SET)); d = SPI_I2S_ReceiveData(SPI1); buff[1] = d; buff[0] = d >> 8; /* Store it */ SPI_8Bit(); SetLED(GELB,DISABLE); } #if FF_FS_READONLY == 0 /* Send multiple byte */ static void xmit_spi_multi ( const BYTE *buff, /* Pointer to the data */ UINT btx /* Number of bytes to send (even number) */ ) { WORD d; SetLED(GELB,ENABLE); SPI_16Bit(); d = buff[0] << 8 | buff[1]; buff += 2; /* Warte bis TX Register frei */ while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET); /* Sende Byte */ SPI_I2S_SendData(SPI1,d); btx -= 2; do { d = buff[0] << 8 | buff[1]; buff += 2; /* Word to send next */ /* Warte bis letztes Byte empfangen wurde */ while (!(SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == SET)); SPI_I2S_ReceiveData(SPI1); /* Discard received word */ while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET); SPI_I2S_SendData(SPI1,d); /* Start next transaction */ } while (btx -= 2); while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == RESET); SPI_I2S_ReceiveData(SPI1); /* Discard received word */ SPI_8Bit(); SetLED(GELB,DISABLE); } #endif /*-----------------------------------------------------------------------*/ /* Wait for card ready */ /*-----------------------------------------------------------------------*/ /* 1:Ready, 0:Timeout */ static int wait_ready ( uint32_t wt) /* Timeout [ms] */ { uint8_t d; Timer2 = wt; do { d = xchg_spi(0xFF); /* This loop takes a time. Insert rot_rdq() here for multitask envilonment. */ } while (d != 0xFF && Timer2); /* Wait for card goes ready or timeout */ return (d == 0xFF) ? 1 : 0; } /*-----------------------------------------------------------------------*/ /* Deselectsd card and release SPI */ /*-----------------------------------------------------------------------*/ static void deselect (void) { DWT_Delay_ms(1); CS_HIGH(); /* Set CS# high */ xchg_spi(0xFF); /* Dummy clock (force DO hi-z for multiple slave SPI) */ } /*-----------------------------------------------------------------------*/ /* Select card and wait for ready */ /*-----------------------------------------------------------------------*/ static int selectsd (void) /* 1:OK, 0:Timeout */ { CS_LOW(); /* Set CS# low */ xchg_spi(0xFF); /* Dummy clock (force DO enabled) */ if (wait_ready(500)) return 1; /* Wait for card ready */ deselect(); return 0; /* Timeout */ } /*-----------------------------------------------------------------------*/ /* Receive a data packet from the MMC */ /*-----------------------------------------------------------------------*/ static int rcvr_datablock ( /* 1:OK, 0:Error */ BYTE *buff, /* Data buffer */ UINT btr /* Data block length (byte) */ ) { BYTE token; Timer1 = 200; do { /* Wait for DataStart token in timeout of 200ms */ token = xchg_spi(0xFF); /* This loop will take a time. Insert rot_rdq() here for multitask envilonment. */ } while ((token == 0xFF) && Timer1); if(token != 0xFE) return 0; /* Function fails if invalid DataStart token or timeout */ rcvr_spi_multi(buff, btr); /* Store trailing data to the buffer */ xchg_spi(0xFF); xchg_spi(0xFF); /* Discard CRC */ return 1; /* Function succeeded */ } /*-----------------------------------------------------------------------*/ /* Send a data packet to the MMC */ /*-----------------------------------------------------------------------*/ #if FF_FS_READONLY == 0 static int xmit_datablock ( /* 1:OK, 0:Failed */ const BYTE *buff, /* Ponter to 512 byte data to be sent */ BYTE token /* Token */ ) { BYTE resp; if (!wait_ready(500)) return 0; /* Wait for card ready */ xchg_spi(token); /* Send token */ if (token != 0xFD) { /* Send data if token is other than StopTran */ xmit_spi_multi(buff, 512); /* Data */ xchg_spi(0xFF); xchg_spi(0xFF); /* Dummy CRC */ resp = xchg_spi(0xFF); /* Receive data resp */ if ((resp & 0x1F) != 0x05) return 0; /* Function fails if the data packet was not accepted */ } return 1; } #endif static BYTE send_cmd ( /* Return value: R1 resp (bit7==1:Failed to send) */ BYTE cmd, /* Command index */ DWORD arg /* Argument */ ) { BYTE n, res; if (cmd & 0x80) { /* Send a CMD55 prior to ACMD */ cmd &= 0x7F; res = send_cmd(CMD55, 0); if (res > 1) return res; } /* Select the card and wait for ready except to stop multiple block read */ if (cmd != CMD12) { deselect(); if (!selectsd()) return 0xFF; } /* Send command packet */ xchg_spi(0x40 | cmd); /* Start + command index */ xchg_spi((BYTE)(arg >> 24)); /* Argument[31..24] */ xchg_spi((BYTE)(arg >> 16)); /* Argument[23..16] */ xchg_spi((BYTE)(arg >> 8)); /* Argument[15..8] */ xchg_spi((BYTE)arg); /* Argument[7..0] */ n = 0x01; /* Dummy CRC + Stop */ if (cmd == CMD0) n = 0x95; /* Valid CRC for CMD0(0) */ if (cmd == CMD8) n = 0x87; /* Valid CRC for CMD8(0x1AA) */ xchg_spi(n); /* Receive command resp */ if (cmd == CMD12) xchg_spi(0xFF); /* Diacard following one byte when CMD12 */ n = 10; /* Wait for response (10 bytes max) */ do { res = xchg_spi(0xFF); } while ((res & 0x80) && --n); return res; /* Return received response */ } /*-------------------------------------------------------------------------- Public Functions ---------------------------------------------------------------------------*/ /*-----------------------------------------------------------------------*/ /* Initialize disk drive */ /*-----------------------------------------------------------------------*/ DSTATUS disk_initialize ( BYTE drv /* Physical drive number (0) */ ) { BYTE n, cmd, ty, ocr[4]; if (drv) return STA_NOINIT; /* Supports only drive 0 */ init_spi(); /* Initialize SPI */ if (Stat & STA_NODISK) return Stat; /* Is card existing in the soket? */ FCLK_SLOW(); for (n = 10; n; n--) xchg_spi(0xFF); /* Send 80 dummy clocks */ ty = 0; if (send_cmd(CMD0, 0) == 1) { /* Put the card SPI/Idle state */ Timer1 = 1000; /* Initialization timeout = 1 sec */ if (send_cmd(CMD8, 0x1AA) == 1) { /* SDv2? */ for (n = 0; n < 4; n++) ocr[n] = xchg_spi(0xFF); /* Get 32 bit return value of R7 resp */ if (ocr[2] == 0x01 && ocr[3] == 0xAA) { /* Is the card supports vcc of 2.7-3.6V? */ while (Timer1 && send_cmd(ACMD41, 1UL << 30)) ; /* Wait for end of initialization with ACMD41(HCS) */ if (Timer1 && send_cmd(CMD58, 0) == 0) { /* Check CCS bit in the OCR */ for (n = 0; n < 4; n++) ocr[n] = xchg_spi(0xFF); ty = (ocr[0] & 0x40) ? CT_SDC2 | CT_BLOCK : CT_SDC2; /* Card id SDv2 */ } } } else { /* Not SDv2 card */ if (send_cmd(ACMD41, 0) <= 1) { /* SDv1 or MMC? */ ty = CT_SDC1; cmd = ACMD41; /* SDv1 (ACMD41(0)) */ } else { ty = CT_MMC3; cmd = CMD1; /* MMCv3 (CMD1(0)) */ } while (Timer1 && send_cmd(cmd, 0)) ; /* Wait for end of initialization */ if (!Timer1 || send_cmd(CMD16, 512) != 0) /* Set block length: 512 */ ty = 0; } } CardType = ty; /* Card type */ deselect(); if (ty) { /* OK */ FCLK_FAST(); /* Set fast clock */ Stat &= ~STA_NOINIT; /* Clear STA_NOINIT flag */ } else { /* Failed */ Stat = STA_NOINIT; } return Stat; } /*-----------------------------------------------------------------------*/ /* Get disk status */ /*-----------------------------------------------------------------------*/ DSTATUS disk_status (uint8_t drv /* Physical drive number (0) */) { if (drv) return STA_NOINIT; /* Supports only drive 0 */ return Stat; /* Return disk status */ } /*-----------------------------------------------------------------------*/ /* Read sector(s) */ /*-----------------------------------------------------------------------*/ DRESULT disk_read ( uint8_t drv, /* Physical drive number (0) */ uint8_t *buff, /* Pointer to the data buffer to store read data */ uint32_t sector, /* Start sector number (LBA) */ uint32_t count /* Number of sectors to read (1..128) */ ) { if (drv || !count) return RES_PARERR; /* Check parameter */ if (Stat & STA_NOINIT) return RES_NOTRDY; /* Check if drive is ready */ if (!(CardType & CT_BLOCK)) sector *= 512; /* LBA ot BA conversion (byte addressing cards) */ if (count == 1) { /* Single sector read */ if ((send_cmd(CMD17, sector) == 0) /* READ_SINGLE_BLOCK */ && rcvr_datablock(buff, 512)) { count = 0; } } else { /* Multiple sector read */ if (send_cmd(CMD18, sector) == 0) { /* READ_MULTIPLE_BLOCK */ do { if (!rcvr_datablock(buff, 512)) break; buff += 512; } while (--count); send_cmd(CMD12, 0); /* STOP_TRANSMISSION */ } } deselect(); return count ? RES_ERROR : RES_OK; /* Return result */ } /*-----------------------------------------------------------------------*/ /* Write sector(s) */ /*-----------------------------------------------------------------------*/ #if FF_FS_READONLY == 0 DRESULT disk_write ( BYTE drv, /* Physical drive number (0) */ const BYTE *buff, /* Ponter to the data to write */ LBA_t sector, /* Start sector number (LBA) */ UINT count /* Number of sectors to write (1..128) */ ) { DWORD sect = (DWORD)sector; if (drv || !count) return RES_PARERR; /* Check parameter */ if (Stat & STA_NOINIT) return RES_NOTRDY; /* Check drive status */ if (Stat & STA_PROTECT) return RES_WRPRT; /* Check write protect */ if (!(CardType & CT_BLOCK)) sect *= 512; /* LBA ==> BA conversion (byte addressing cards) */ if (count == 1) { /* Single sector write */ if ((send_cmd(CMD24, sect) == 0) /* WRITE_BLOCK */ && xmit_datablock(buff, 0xFE)) { count = 0; } } else { /* Multiple sector write */ if (CardType & CT_SDC) send_cmd(ACMD23, count); /* Predefine number of sectors */ if (send_cmd(CMD25, sect) == 0) { /* WRITE_MULTIPLE_BLOCK */ do { if (!xmit_datablock(buff, 0xFC)) break; buff += 512; } while (--count); if (!xmit_datablock(0, 0xFD)) count = 1; /* STOP_TRAN token */ } } deselect(); return count ? RES_ERROR : RES_OK; /* Return result */ } #endif /*-----------------------------------------------------------------------*/ /* Miscellaneous drive controls other than data read/write */ /*-----------------------------------------------------------------------*/ DRESULT disk_ioctl ( BYTE drv, /* Physical drive number (0) */ BYTE cmd, /* Control command code */ void *buff /* Pointer to the conrtol data */ ) { DRESULT res; BYTE n, csd[16]; DWORD st, ed, csize; LBA_t *dp; if (drv) return RES_PARERR; /* Check parameter */ if (Stat & STA_NOINIT) return RES_NOTRDY; /* Check if drive is ready */ res = RES_ERROR; switch (cmd) { case CTRL_SYNC : /* Wait for end of internal write process of the drive */ if (selectsd()) res = RES_OK; break; case GET_SECTOR_COUNT : /* Get drive capacity in unit of sector (DWORD) */ if ((send_cmd(CMD9, 0) == 0) && rcvr_datablock(csd, 16)) { if ((csd[0] >> 6) == 1) { /* SDC CSD ver 2 */ csize = csd[9] + ((WORD)csd[8] << 8) + ((DWORD)(csd[7] & 63) << 16) + 1; *(LBA_t*)buff = csize << 10; } else { /* SDC CSD ver 1 or MMC */ n = (csd[5] & 15) + ((csd[10] & 128) >> 7) + ((csd[9] & 3) << 1) + 2; csize = (csd[8] >> 6) + ((WORD)csd[7] << 2) + ((WORD)(csd[6] & 3) << 10) + 1; *(LBA_t*)buff = csize << (n - 9); } res = RES_OK; } break; case GET_BLOCK_SIZE : /* Get erase block size in unit of sector (DWORD) */ if (CardType & CT_SDC2) { /* SDC ver 2+ */ if (send_cmd(ACMD13, 0) == 0) { /* Read SD status */ xchg_spi(0xFF); if (rcvr_datablock(csd, 16)) { /* Read partial block */ for (n = 64 - 16; n; n--) xchg_spi(0xFF); /* Purge trailing data */ *(DWORD*)buff = 16UL << (csd[10] >> 4); res = RES_OK; } } } else { /* SDC ver 1 or MMC */ if ((send_cmd(CMD9, 0) == 0) && rcvr_datablock(csd, 16)) { /* Read CSD */ if (CardType & CT_SDC1) { /* SDC ver 1.XX */ *(DWORD*)buff = (((csd[10] & 63) << 1) + ((WORD)(csd[11] & 128) >> 7) + 1) << ((csd[13] >> 6) - 1); } else { /* MMC */ *(DWORD*)buff = ((WORD)((csd[10] & 124) >> 2) + 1) * (((csd[11] & 3) << 3) + ((csd[11] & 224) >> 5) + 1); } res = RES_OK; } } break; case CTRL_TRIM : /* Erase a block of sectors (used when _USE_ERASE == 1) */ if (!(CardType & CT_SDC)) break; /* Check if the card is SDC */ if (disk_ioctl(drv, MMC_GET_CSD, csd)) break; /* Get CSD */ if (!(csd[10] & 0x40)) break; /* Check if ERASE_BLK_EN = 1 */ dp = buff; st = (DWORD)dp[0]; ed = (DWORD)dp[1]; /* Load sector block */ if (!(CardType & CT_BLOCK)) { st *= 512; ed *= 512; } if (send_cmd(CMD32, st) == 0 && send_cmd(CMD33, ed) == 0 && send_cmd(CMD38, 0) == 0 && wait_ready(30000)) { /* Erase sector block */ res = RES_OK; /* FatFs does not check result of this command */ } break; /* Following commands are never used by FatFs module */ case MMC_GET_TYPE: /* Get MMC/SDC type (BYTE) */ *(BYTE*)buff = CardType; res = RES_OK; break; case MMC_GET_CSD: /* Read CSD (16 bytes) */ if (send_cmd(CMD9, 0) == 0 && rcvr_datablock((BYTE*)buff, 16)) { /* READ_CSD */ res = RES_OK; } break; case MMC_GET_CID: /* Read CID (16 bytes) */ if (send_cmd(CMD10, 0) == 0 && rcvr_datablock((BYTE*)buff, 16)) { /* READ_CID */ res = RES_OK; } break; case MMC_GET_OCR: /* Read OCR (4 bytes) */ if (send_cmd(CMD58, 0) == 0) { /* READ_OCR */ for (n = 0; n < 4; n++) *(((BYTE*)buff) + n) = xchg_spi(0xFF); res = RES_OK; } break; case MMC_GET_SDSTAT: /* Read SD status (64 bytes) */ if (send_cmd(ACMD13, 0) == 0) { /* SD_STATUS */ xchg_spi(0xFF); if (rcvr_datablock((BYTE*)buff, 64)) res = RES_OK; } break; default: res = RES_PARERR; } deselect(); return res; } /*-----------------------------------------------------------------------*/ /* Device timer function */ /*-----------------------------------------------------------------------*/ /* This function must be called from timer interrupt routine in period / of 1 ms to generate card control timing. */ void disk_timerproc (void) { WORD n; BYTE s; n = Timer1; /* 1kHz decrement timer stopped at 0 */ if (n) Timer1 = --n; n = Timer2; if (n) Timer2 = --n; s = Stat; if (MMC_WP) { /* Write protected */ s |= STA_PROTECT; } else { /* Write enabled */ s &= ~STA_PROTECT; } if (MMC_CD) { /* Card is in socket */ s &= ~STA_NODISK; } else { /* Socket empty */ s |= (STA_NODISK | STA_NOINIT); } Stat = s; }
