/* ---------------------------------------------------------------------------- */ /* Em::Blocks embedded development Support */ /* ---------------------------------------------------------------------------- */ /* Copyright (c) 2014, EmBlocks */ /* */ /* All rights reserved. */ /* */ /* Redistribution and use in source and binary forms, with or without */ /* modification, are permitted provided that the following condition is met: */ /* */ /* - Redistributions of source code must retain the above copyright notice, */ /* this list of conditions and the disclaimer below. */ /* */ /* EmBlocks's name may not be used to endorse or promote products derived from */ /* this software without specific prior written permission. */ /* */ /* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY EBLOCKS "AS IS" AND ANY EXPRESS OR */ /* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */ /* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */ /* DISCLAIMED. IN NO EVENT SHALL EMBLOCKS BE LIABLE FOR ANY DIRECT, INDIRECT, */ /* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */ /* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */ /* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */ /* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */ /* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */ /* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */ /* ---------------------------------------------------------------------------- */ /*------------------------------------------------------------------------------ * Linker script for running in internal FLASH on the STM32F401CC *----------------------------------------------------------------------------*/ OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") OUTPUT_ARCH(arm) SEARCH_DIR(.) /* Memory Spaces Definitions */ MEMORY { ROM (rx) : ORIGIN = 0x08000000, LENGTH = 256K RAM (rwx) : ORIGIN = 0x20000000, LENGTH = 64K } /* Linker script to place sections and symbol values. Should be used together * with other linker script that defines memory regions FLASH and RAM. * It references following symbols, which must be defined in code: * Reset_Handler : Entry of reset handler * * It defines following symbols, which code can use without definition: * __exidx_start * __exidx_end * __etext * __data_start__ * __preinit_array_start * __preinit_array_end * __init_array_start * __init_array_end * __fini_array_start * __fini_array_end * __data_end__ * __bss_start__ * __bss_end__ * __end__ * end * __HeapLimit * __StackLimit * __StackTop * __stack */ SECTIONS { .text : { KEEP(*(.isr_vector)) *(.text*) KEEP(*(.init)) KEEP(*(.fini)) /* .ctors */ *crtbegin.o(.ctors) *crtbegin?.o(.ctors) *(EXCLUDE_FILE(*crtend?.o *crtend.o) .ctors) *(SORT(.ctors.*)) *(.ctors) /* .dtors */ *crtbegin.o(.dtors) *crtbegin?.o(.dtors) *(EXCLUDE_FILE(*crtend?.o *crtend.o) .dtors) *(SORT(.dtors.*)) *(.dtors) *(.rodata*) KEEP(*(.eh_frame*)) } > ROM .ARM.extab : { *(.ARM.extab* .gnu.linkonce.armextab.*) } > ROM __exidx_start = .; .ARM.exidx : { *(.ARM.exidx* .gnu.linkonce.armexidx.*) } > ROM __exidx_end = .; __etext = .; .data : AT (__etext) { __data_start__ = .; *(vtable) *(.data*) . = ALIGN(4); /* preinit data */ PROVIDE_HIDDEN (__preinit_array_start = .); KEEP(*(.preinit_array)) PROVIDE_HIDDEN (__preinit_array_end = .); . = ALIGN(4); /* init data */ PROVIDE_HIDDEN (__init_array_start = .); KEEP(*(SORT(.init_array.*))) KEEP(*(.init_array)) PROVIDE_HIDDEN (__init_array_end = .); . = ALIGN(4); /* finit data */ PROVIDE_HIDDEN (__fini_array_start = .); KEEP(*(SORT(.fini_array.*))) KEEP(*(.fini_array)) PROVIDE_HIDDEN (__fini_array_end = .); . = ALIGN(4); /* All data end */ __data_end__ = .; } > RAM .bss (NOLOAD): { __bss_start__ = .; *(.bss*) *(COMMON) __bss_end__ = .; } > RAM .heap (NOLOAD): { __end__ = .; end = __end__; *(.heap*) __HeapLimit = .; } > RAM /* .stack_dummy section doesn't contains any symbols. It is only * used for linker to calculate size of stack sections, and assign * values to stack symbols later */ .stack_dummy (NOLOAD): { *(.stack) } > RAM /* Set stack top to end of RAM, and stack limit move down by * size of stack_dummy section */ __StackTop = ORIGIN(RAM) + LENGTH(RAM); __StackLimit = __StackTop - SIZEOF(.stack_dummy); PROVIDE(__stack = __StackTop); /* Check if data + heap + stack exceeds RAM limit */ ASSERT(__StackLimit >= __HeapLimit, "region RAM overflowed with stack") }
