* @file system_stm32f4xx.c
* @author MCD Application Team
* @version V1.2.0RC2
* @date 20-February-2013
* @brief CMSIS Cortex-M4 Device Peripheral Access Layer System Source File.
* This file contains the system clock configuration for STM32F4xx devices,
* and is generated by the clock configuration tool
* stm32f4xx_Clock_Configuration_V1.1.0.xls
* 1. This file provides two functions and one global variable to be called from
* user application:
* - SystemInit(): Setups the system clock (System clock source, PLL Multiplier
* and Divider factors, AHB/APBx prescalers and Flash settings),
* depending on the configuration made in the clock xls tool.
* This function is called at startup just after reset and
* before branch to main program. This call is made inside
* the "startup_stm32f4xx.s" file.
* - SystemCoreClock variable: Contains the core clock (HCLK), it can be used
* by the user application to setup the SysTick
* timer or configure other parameters.
* - SystemCoreClockUpdate(): Updates the variable SystemCoreClock and must
* be called whenever the core clock is changed
* during program execution.
* 2. After each device reset the HSI (16 MHz) is used as system clock source.
* Then SystemInit() function is called, in "startup_stm32f4xx.s" file, to
* configure the system clock before to branch to main program.
* 3. If the system clock source selected by user fails to startup, the SystemInit()
* function will do nothing and HSI still used as system clock source. User can
* add some code to deal with this issue inside the SetSysClock() function.
* 4. The default value of HSE crystal is set to 25MHz, refer to "HSE_VALUE" define
* in "stm32f4xx.h" file. When HSE is used as system clock source, directly or
* through PLL, and you are using different crystal you have to adapt the HSE
* value to your own configuration.
* 5. This file configures the system clock as follows:
* Supported STM32F40xx/41xx/427x/437x/429x/439x devices
* System Clock source | PLL (HSE)
* SYSCLK(Hz) | 168000000
* HCLK(Hz) | 168000000
* AHB Prescaler | 1
* APB1 Prescaler | 4
* APB2 Prescaler | 2
* HSE Frequency(Hz) | 8000000 (fm: see HSE_VALUE)
* PLL_M | 8
* PLL_N | 336
* PLL_P | 2
* PLL_Q | 7
* PLLI2S_N | NA
* PLLI2S_R | NA
* I2S input clock | NA
* VDD(V) | 3.3
* Main regulator output voltage | Scale1 mode
* Flash Latency(WS) | 5
* Prefetch Buffer | ON
* Instruction cache | ON
* Data cache | ON
* Require 48MHz for USB OTG FS, | Disabled
* SDIO and RNG clock |
* @attention
© COPYRIGHT 2013 STMicroelectronics
* Licensed under MCD-ST Liberty SW License Agreement V2, (the "License");
* You may not use this file except in compliance with the License.
* You may obtain a copy of the License at:
* http://www.st.com/software_license_agreement_liberty_v2
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an "AS IS" BASIS,
* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
* See the License for the specific language governing permissions and
* limitations under the License.
/** @addtogroup CMSIS
/** @addtogroup stm32f4xx_system
/** @addtogroup STM32F4xx_System_Private_Includes
#include "stm32f4xx.h"
/** @addtogroup STM32F4xx_System_Private_TypesDefinitions
/** @addtogroup STM32F4xx_System_Private_Defines
/************************* Miscellaneous Configuration ************************/
/*!< Uncomment the following line if you need to use external SRAM or SDRAM mounted
on STM324xG_EVAL/STM324x7I_EVAL/STM324x9I_EVAL boards as data memory */
/* #define DATA_IN_ExtSRAM */
/* #define DATA_IN_ExtSDRAM */
/*!< Uncomment the following line if you need to relocate your vector Table in
Internal SRAM. */
/* #define VECT_TAB_SRAM */
#define VECT_TAB_OFFSET 0x00 /*!< Vector Table base offset field.
This value must be a multiple of 0x200. */
/************************* PLL Parameters *************************************/
/* PLL_VCO = (HSE_VALUE or HSI_VALUE / PLL_M) * PLL_N */
/* SYSCLK = PLL_VCO / PLL_P */
/* USB OTG FS, SDIO and RNG Clock = PLL_VCO / PLLQ */
* STM32F401RE Nucleo Board with 8 MHz crystal (84 MHz):
* Input frequency 8MHz
* PLL M 4
* PLL N 84
* PLL P 2
* AHB prescaler 1
* APB1 prescaler 2
* APB2 prescaler 1
* SYSCLK = ((HSE_VALUE / PLL_M) * PLL_N) / PLL_N = ((8000000 / 4) * 84) / 2 = 84000000
* STM32F401CC WeAct Black Pill with 25 MHz crystal (84 MHz):
* STM32F401CE WeAct Black Pill with 25 MHz crystal (84 MHz):
* Input frequency 25MHz
* PLL M 25
* PLL N 336
* PLL P 4
* AHB prescaler 1
* APB1 prescaler 2
* APB2 prescaler 1
* SYSCLK = ((HSE_VALUE / PLL_M) * PLL_N) / PLL_N = ((25000000 / 25) * 336) / 4 = 84000000
#if defined (STM32F401)
#if HSE_VALUE == 8000000 // input frequency 8 MHz
#define HCLK 84 // 84 MHz
#define PLL_M 4
#define PLL_N 84
#define PLL_P 2
#define AHB_PRESCALER RCC_CFGR_HPRE_DIV1 // 84 MHz
#define APB1_PRESCALER RCC_CFGR_PPRE1_DIV2 // 42 MHz
#define APB2_PRESCALER RCC_CFGR_PPRE2_DIV1 // 84 MHz
#elif HSE_VALUE == 25000000 // input frequency 25 MHz
#define PLL_M 25
#define PLL_N 336
#define PLL_P 4
#else
#error STM32F401: invalid HSE_VALUE
#endif
* STM32F411RE Nucleo Board with 8 MHz crystal (100 MHz)
* PLL M 4
* PLL N 100
* PLL P 2
* AHB prescaler 1
* APB1 prescaler 2
* APB2 prescaler 1
* SYSCLK = ((HSE_VALUE / PLL_M) * PLL_N) / PLL_N = ((8000000 / 4) * 100) / 2 = 100000000
* STM32F411CE WeAct Black Pill with 25 MHz crystal (100 MHz):
* PLL M 25
* PLL N 200
* PLL P 2
* AHB prescaler 1
* APB1 prescaler 2
* APB2 prescaler 1
* SYSCLK = ((HSE_VALUE / PLL_M) * PLL_N) / PLL_N = ((25000000 / 25) * 200) / 2 = 100000000
#elif defined (STM32F411)
#define HCLK 100 // 100 MHz
#define PLL_M 4
#define PLL_N 100
#define PLL_P 2
#define AHB_PRESCALER RCC_CFGR_HPRE_DIV1 // 100 MHz
#define APB1_PRESCALER RCC_CFGR_PPRE1_DIV2 // 50 MHz
#define APB2_PRESCALER RCC_CFGR_PPRE2_DIV1 // 100 MHz
#define PLL_M 25
#define PLL_N 200
#define PLL_P 2
#else
#error STM32F411: invalid HSE_VALUE
#endif
* STM32F446RE Nucleo Board with 8 MHz crystal (180 MHz)
* PLL M 4
* PLL N 180
* PLL P 2
* AHB prescaler 1
* APB1 prescaler 4
* APB2 prescaler 2
* SYSCLK = ((HSE_VALUE / PLL_M) * PLL_N) / PLL_N = ((8000000 / 4) * 180) / 2 = 180000000
#elif defined (STM32F446)
#define HCLK 180 // 180 MHz
#define PLL_M 4
#define PLL_N 180
#define PLL_P 2
#define AHB_PRESCALER RCC_CFGR_HPRE_DIV1 // 180 MHz
#define APB1_PRESCALER RCC_CFGR_PPRE1_DIV4 // 45 MHz
#define APB2_PRESCALER RCC_CFGR_PPRE2_DIV2 // 90 MHz
#else
#error STM32F446: invalid HSE_VALUE
#endif
* STM32F407VG Discovery Board with 8 MHz crystal (168 MHz)
* STM32F407VE Black Board with 8 MHz crystal (168 MHz)
* PLL M 4
* PLL N 168
* PLL P 2
* AHB prescaler 1
* APB1 prescaler 4
* APB2 prescaler 2
* SYSCLK = ((HSE_VALUE / PLL_M) * PLL_N) / PLL_N = ((8000000 / 4) * 168) / 2 = 168000000
#elif defined (STM32F407)
#define HCLK 168 // 168 MHz
#define PLL_M 4
#define PLL_N 168
#define PLL_P 2
#define AHB_PRESCALER RCC_CFGR_HPRE_DIV1 // 168 MHz
#define APB1_PRESCALER RCC_CFGR_PPRE1_DIV4 // 42 MHz
#define APB2_PRESCALER RCC_CFGR_PPRE2_DIV2 // 84 MHz
#else
#error STM32F407: invalid HSE_VALUE
#endif
#else
#error unknown STM32
#endif
#define PLL_Q 7 // not used yet (no USB)
* STM32Fxx wait states
* 2.7V - 3.6V 2.4V - 2.7V 2.1V - 2.4V 1.8V - 2.1V WS
* HCLK 0 .. 30 MHz 0 ... 24 0 ... 22 0 ... 20 0 WS
* HCLK 30 .. 60 MHz 24 ... 48 22 ... 44 20 ... 40 1 WS
* HCLK 60 .. 90 MHz 48 ... 72 44 ... 66 40 ... 60 2 WS
* HCLK 90 .. 120 MHz 72 ... 96 66 ... 88 60 ... 80 3 WS
* HCLK 120 .. 150 MHz 96 ... 120 88 ... 110 80 ... 100 4 WS
* HCLK 150 .. 180 MHz 120 ... 144 110 ... 132 100 ... 120 5 WS
* HCLK 144 ... 168 132 ... 154 120 ... 140 6 WS
* HCLK 168 ... 180 154 ... 176 140 ... 160 7 WS
* HCLK 176 ... 180 160 ... 168 8 WS
* Here we use the values at 3.3V
#if HCLK <= 30
#define WAIT_STATES FLASH_ACR_LATENCY_0WS
#elif HCLK <= 60
#define WAIT_STATES FLASH_ACR_LATENCY_1WS
#elif HCLK <= 90
#define WAIT_STATES FLASH_ACR_LATENCY_2WS
#elif HCLK <= 120
#define WAIT_STATES FLASH_ACR_LATENCY_3WS
#elif HCLK <= 150
#define WAIT_STATES FLASH_ACR_LATENCY_4WS
#elif HCLK <= 180
#define WAIT_STATES FLASH_ACR_LATENCY_5WS
#else
#error HCLK out of range
#endif
/** @addtogroup STM32F4xx_System_Private_Macros
/** @addtogroup STM32F4xx_System_Private_Variables
uint32_t SystemCoreClock = 168000000;
__I uint8_t AHBPrescTable[16] = {0, 0, 0, 0, 0, 0, 0, 0, 1, 2, 3, 4, 6, 7, 8, 9};
/** @addtogroup STM32F4xx_System_Private_FunctionPrototypes
static void SetSysClock(void);
#if defined (DATA_IN_ExtSRAM) || defined (DATA_IN_ExtSDRAM)
static void SystemInit_ExtMemCtl(void);
#endif /* DATA_IN_ExtSRAM || DATA_IN_ExtSDRAM */
/** @addtogroup STM32F4xx_System_Private_Functions
* @brief Setup the microcontroller system
* Initialize the Embedded Flash Interface, the PLL and update the
* SystemFrequency variable.
* @param None
* @retval None
void SystemInit(void)
/* FPU settings ------------------------------------------------------------*/
#if (__FPU_PRESENT == 1) && (__FPU_USED == 1)
SCB->CPACR |= ((3UL << 10*2)|(3UL << 11*2)); /* set CP10 and CP11 Full Access */
#endif
/* Reset the RCC clock configuration to the default reset state ------------*/
/* Set HSION bit */
RCC->CR |= (uint32_t)0x00000001;
/* Reset CFGR register */
RCC->CFGR = 0x00000000;
/* Reset HSEON, CSSON and PLLON bits */
RCC->CR &= (uint32_t)0xFEF6FFFF;
/* Reset PLLCFGR register */
RCC->PLLCFGR = 0x24003010;
/* Reset HSEBYP bit */
RCC->CR &= (uint32_t)0xFFFBFFFF;
/* Disable all interrupts */
RCC->CIR = 0x00000000;
SystemInit_ExtMemCtl();
/* Configure the System clock source, PLL Multiplier and Divider factors,
AHB/APBx prescalers and Flash settings ----------------------------------*/
SetSysClock();
/* Configure the Vector Table location add offset address ------------------*/
#ifdef VECT_TAB_SRAM
SCB->VTOR = SRAM_BASE | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal SRAM */
#else
SCB->VTOR = FLASH_BASE | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal FLASH */
#endif
* @brief Update SystemCoreClock variable according to Clock Register Values.
* The SystemCoreClock variable contains the core clock (HCLK), it can
* be used by the user application to setup the SysTick timer or configure
* other parameters.
* @note Each time the core clock (HCLK) changes, this function must be called
* to update SystemCoreClock variable value. Otherwise, any configuration
* based on this variable will be incorrect.
* @note - The system frequency computed by this function is not the real
* frequency in the chip. It is calculated based on the predefined
* constant and the selected clock source:
* - If SYSCLK source is HSI, SystemCoreClock will contain the HSI_VALUE(*)
* - If SYSCLK source is HSE, SystemCoreClock will contain the HSE_VALUE(**)
* - If SYSCLK source is PLL, SystemCoreClock will contain the HSE_VALUE(**)
* or HSI_VALUE(*) multiplied/divided by the PLL factors.
* (*) HSI_VALUE is a constant defined in stm32f4xx.h file (default value
* 16 MHz) but the real value may vary depending on the variations
* in voltage and temperature.
* (**) HSE_VALUE is a constant defined in stm32f4xx.h file (default value
* 25 MHz), user has to ensure that HSE_VALUE is same as the real
* frequency of the crystal used. Otherwise, this function may
* have wrong result.
* - The result of this function could be not correct when using fractional
* value for HSE crystal.
* @param None
* @retval None
void SystemCoreClockUpdate(void)
uint32_t tmp = 0, pllvco = 0, pllp = 2, pllsource = 0, pllm = 2;
/* Get SYSCLK source -------------------------------------------------------*/
tmp = RCC->CFGR & RCC_CFGR_SWS;
switch (tmp)
case 0x00: /* HSI used as system clock source */
SystemCoreClock = HSI_VALUE;
break;
case 0x04: /* HSE used as system clock source */
SystemCoreClock = HSE_VALUE;
break;
case 0x08: /* PLL used as system clock source */
pllsource = (RCC->PLLCFGR & RCC_PLLCFGR_PLLSRC) >> 22;
pllm = RCC->PLLCFGR & RCC_PLLCFGR_PLLM;
if (pllsource != 0)
/* HSE used as PLL clock source */
pllvco = (HSE_VALUE / pllm) * ((RCC->PLLCFGR & RCC_PLLCFGR_PLLN) >> 6);
else
/* HSI used as PLL clock source */
pllvco = (HSI_VALUE / pllm) * ((RCC->PLLCFGR & RCC_PLLCFGR_PLLN) >> 6);
pllp = (((RCC->PLLCFGR & RCC_PLLCFGR_PLLP) >>16) + 1 ) *2;
SystemCoreClock = pllvco/pllp;
break;
default:
break;
/* Compute HCLK frequency --------------------------------------------------*/
/* Get HCLK prescaler */
tmp = AHBPrescTable[((RCC->CFGR & RCC_CFGR_HPRE) >> 4)];
/* HCLK frequency */
SystemCoreClock >>= tmp;
* @brief Configures the System clock source, PLL Multiplier and Divider factors,
* AHB/APBx prescalers and Flash settings
* @Note This function should be called only once the RCC clock configuration
* is reset to the default reset state (done in SystemInit() function).
* @param None
* @retval None
/* PLL (clocked by HSE) used as System clock source */
__IO uint32_t StartUpCounter = 0, HSEStatus = 0;
RCC->CR |= ((uint32_t)RCC_CR_HSEON); // Enable HSE
do // Wait until HSE is ready, if timeout is reached exit
HSEStatus = RCC->CR & RCC_CR_HSERDY;
StartUpCounter++;
} while((HSEStatus == 0) && (StartUpCounter != HSE_STARTUP_TIMEOUT));
if ((RCC->CR & RCC_CR_HSERDY) != RESET)
HSEStatus = (uint32_t)0x01;
else
HSEStatus = (uint32_t)0x00;
if (HSEStatus == (uint32_t)0x01)
/* Select regulator voltage output Scale 1 mode, System frequency up to 168 MHz */
RCC->APB1ENR |= RCC_APB1ENR_PWREN;
PWR->CR |= PWR_CR_VOS;
RCC->CFGR |= AHB_PRESCALER;
RCC->CFGR |= APB2_PRESCALER;
RCC->CFGR |= APB1_PRESCALER;
RCC->CR &= ~(RCC_CR_PLLON); // Disable main PLL
while ((RCC->CR & RCC_CR_PLLRDY) != 0) // Wait until main PLL is ready (disabled)
// Configure main PLL
RCC->PLLCFGR = PLL_M | (PLL_N << 6) | (((PLL_P >> 1) -1) << 16) | (RCC_PLLCFGR_PLLSRC_HSE) | (PLL_Q << 24);
RCC->CR |= RCC_CR_PLLON; // Enable main PLL
while((RCC->CR & RCC_CR_PLLRDY) == 0) // Wait until main PLL is ready
/* Configure Flash prefetch, Instruction cache, Data cache and wait state */
FLASH->ACR = FLASH_ACR_PRFTEN | FLASH_ACR_ICEN | FLASH_ACR_DCEN | WAIT_STATES;
if ((FLASH->ACR & FLASH_ACR_LATENCY) != WAIT_STATES)
{ // Check flash latency
while (1)
; // Error
RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW)); // Select the main PLL as system clock source
RCC->CFGR |= RCC_CFGR_SW_PLL;
while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS ) != RCC_CFGR_SWS_PLL);
; // Wait until main PLL is used as system clock source
else
// If HSE fails to start-up, the application will have wrong clock configuration.
// We could try to enable HSI with the PLL, but we don't want this here. ;-)
while (1)
; // Stop here
* @brief Setup the external memory controller. Called in startup_stm32f4xx.s
* before jump to __main
* @param None
* @retval None
#ifdef DATA_IN_ExtSRAM
* Called in startup_stm32f4xx.s before jump to main.
* This function configures the external SRAM mounted on STM324xG_EVAL/STM324x7I boards
* This SRAM will be used as program data memory (including heap and stack).
* @param None
* @retval None
/*-- GPIOs Configuration -----------------------------------------------------*/
+ SRAM pins assignment +
| PD0 <-> FMC_D2 | PE0 <-> FMC_NBL0 | PF0 <-> FMC_A0 | PG0 <-> FMC_A10 |
| PD1 <-> FMC_D3 | PE1 <-> FMC_NBL1 | PF1 <-> FMC_A1 | PG1 <-> FMC_A11 |
| PD4 <-> FMC_NOE | PE3 <-> FMC_A19 | PF2 <-> FMC_A2 | PG2 <-> FMC_A12 |
| PD5 <-> FMC_NWE | PE4 <-> FMC_A20 | PF3 <-> FMC_A3 | PG3 <-> FMC_A13 |
| PD8 <-> FMC_D13 | PE7 <-> FMC_D4 | PF4 <-> FMC_A4 | PG4 <-> FMC_A14 |
| PD9 <-> FMC_D14 | PE8 <-> FMC_D5 | PF5 <-> FMC_A5 | PG5 <-> FMC_A15 |
| PD10 <-> FMC_D15 | PE9 <-> FMC_D6 | PF12 <-> FMC_A6 | PG9 <-> FMC_NE2 |
| PD11 <-> FMC_A16 | PE10 <-> FMC_D7 | PF13 <-> FMC_A7 |-----------------+
| PD12 <-> FMC_A17 | PE11 <-> FMC_D8 | PF14 <-> FMC_A8 |
| PD13 <-> FMC_A18 | PE12 <-> FMC_D9 | PF15 <-> FMC_A9 |
| PD14 <-> FMC_D0 | PE13 <-> FMC_D10 |-----------------+
| PD15 <-> FMC_D1 | PE14 <-> FMC_D11 |
| | PE15 <-> FMC_D12 |
/* Enable GPIOD, GPIOE, GPIOF and GPIOG interface clock */
RCC->AHB1ENR |= 0x00000078;
/* Connect PDx pins to FMC Alternate function */
GPIOD->AFR[0] = 0x00cc00cc;
GPIOD->AFR[1] = 0xcccccccc;
/* Configure PDx pins in Alternate function mode */
GPIOD->MODER = 0xaaaa0a0a;
/* Configure PDx pins speed to 100 MHz */
GPIOD->OSPEEDR = 0xffff0f0f;
/* Configure PDx pins Output type to push-pull */
GPIOD->OTYPER = 0x00000000;
/* No pull-up, pull-down for PDx pins */
GPIOD->PUPDR = 0x00000000;
/* Connect PEx pins to FMC Alternate function */
GPIOE->AFR[0] = 0xcccccccc;
GPIOE->AFR[1] = 0xcccccccc;
/* Configure PEx pins in Alternate function mode */
GPIOE->MODER = 0xaaaaaaaa;
/* Configure PEx pins speed to 100 MHz */
GPIOE->OSPEEDR = 0xffffffff;
/* Configure PEx pins Output type to push-pull */
GPIOE->OTYPER = 0x00000000;
/* No pull-up, pull-down for PEx pins */
GPIOE->PUPDR = 0x00000000;
/* Connect PFx pins to FMC Alternate function */
GPIOF->AFR[0] = 0x00cccccc;
GPIOF->AFR[1] = 0xcccc0000;
/* Configure PFx pins in Alternate function mode */
GPIOF->MODER = 0xaa000aaa;
/* Configure PFx pins speed to 100 MHz */
GPIOF->OSPEEDR = 0xff000fff;
/* Configure PFx pins Output type to push-pull */
GPIOF->OTYPER = 0x00000000;
/* No pull-up, pull-down for PFx pins */
GPIOF->PUPDR = 0x00000000;
/* Connect PGx pins to FMC Alternate function */
GPIOG->AFR[0] = 0x00cccccc;
GPIOG->AFR[1] = 0x000000c0;
/* Configure PGx pins in Alternate function mode */
GPIOG->MODER = 0x00080aaa;
/* Configure PGx pins speed to 100 MHz */
GPIOG->OSPEEDR = 0x000c0fff;
/* Configure PGx pins Output type to push-pull */
GPIOG->OTYPER = 0x00000000;
/* No pull-up, pull-down for PGx pins */
GPIOG->PUPDR = 0x00000000;
/*-- FMC Configuration ------------------------------------------------------*/
/* Enable the FMC interface clock */
RCC->AHB3ENR |= 0x00000001;
/* Configure and enable Bank1_SRAM2 */
FMC_Bank1->BTCR[2] = 0x00001011;
FMC_Bank1->BTCR[3] = 0x00000201;
FMC_Bank1E->BWTR[2] = 0x0fffffff;
Bank1_SRAM2 is configured as follow:
NORSRAMTimingStructure.FMC_AddressSetupTime = 1;
NORSRAMTimingStructure.FMC_AddressHoldTime = 0;
NORSRAMTimingStructure.FMC_DataSetupTime = 2;
NORSRAMTimingStructure.FMC_BusTurnAroundDuration = 0;
NORSRAMTimingStructure.FMC_CLKDivision = 0;
NORSRAMTimingStructure.FMC_DataLatency = 0;
NORSRAMTimingStructure.FMC_AccessMode = FMC_AccessMode_A;
FMC_NORSRAMInitStructure.FMC_Bank = FMC_Bank1_NORSRAM2;
FMC_NORSRAMInitStructure.FMC_DataAddressMux = FMC_DataAddressMux_Disable;
FMC_NORSRAMInitStructure.FMC_MemoryType = FMC_MemoryType_SRAM;
FMC_NORSRAMInitStructure.FMC_MemoryDataWidth = FMC_MemoryDataWidth_16b;
FMC_NORSRAMInitStructure.FMC_BurstAccessMode = FMC_BurstAccessMode_Disable;
FMC_NORSRAMInitStructure.FMC_AsynchronousWait = FMC_AsynchronousWait_Disable;
FMC_NORSRAMInitStructure.FMC_WaitSignalPolarity = FMC_WaitSignalPolarity_Low;
FMC_NORSRAMInitStructure.FMC_WrapMode = FMC_WrapMode_Disable;
FMC_NORSRAMInitStructure.FMC_WaitSignalActive = FMC_WaitSignalActive_BeforeWaitState;
FMC_NORSRAMInitStructure.FMC_WriteOperation = FMC_WriteOperation_Enable;
FMC_NORSRAMInitStructure.FMC_WaitSignal = FMC_WaitSignal_Disable;
FMC_NORSRAMInitStructure.FMC_ExtendedMode = FMC_ExtendedMode_Disable;
FMC_NORSRAMInitStructure.FMC_WriteBurst = FMC_WriteBurst_Disable;
FMC_NORSRAMInitStructure.FMC_ContinousClock = FMC_CClock_SyncOnly;
FMC_NORSRAMInitStructure.FMC_ReadWriteTimingStruct = &NORSRAMTimingStructure;
FMC_NORSRAMInitStructure.FMC_WriteTimingStruct = &NORSRAMTimingStructure;
#endif /* DATA_IN_ExtSRAM */
#ifdef DATA_IN_ExtSDRAM
* This function configures the external SDRAM mounted on STM324x9I_EVAL board
* This SDRAM will be used as program data memory (including heap and stack).
* @param None
* @retval None
register uint32_t tmpreg = 0, timeout = 0xFFFF;
register uint32_t index;
/* Enable GPIOC, GPIOD, GPIOE, GPIOF, GPIOG, GPIOH and GPIOI interface
clock */
RCC->AHB1ENR |= 0x000001FC;
/* Connect PCx pins to FMC Alternate function */
GPIOC->AFR[0] = 0x0000000c;
GPIOC->AFR[1] = 0x00007700;
/* Configure PCx pins in Alternate function mode */
GPIOC->MODER = 0x00a00002;
/* Configure PCx pins speed to 50 MHz */
GPIOC->OSPEEDR = 0x00a00002;
/* Configure PCx pins Output type to push-pull */
GPIOC->OTYPER = 0x00000000;
/* No pull-up, pull-down for PCx pins */
GPIOC->PUPDR = 0x00500000;
GPIOD->AFR[0] = 0x000000CC;
GPIOD->AFR[1] = 0xCC000CCC;
GPIOD->MODER = 0xA02A000A;
/* Configure PDx pins speed to 50 MHz */
GPIOD->OSPEEDR = 0xA02A000A;
GPIOE->AFR[0] = 0xC00000CC;
GPIOE->AFR[1] = 0xCCCCCCCC;
GPIOE->MODER = 0xAAAA800A;
/* Configure PEx pins speed to 50 MHz */
GPIOE->OSPEEDR = 0xAAAA800A;
GPIOF->AFR[0] = 0xcccccccc;
GPIOF->AFR[1] = 0xcccccccc;
GPIOF->MODER = 0xAA800AAA;
/* Configure PFx pins speed to 50 MHz */
GPIOF->OSPEEDR = 0xAA800AAA;
GPIOG->AFR[0] = 0xcccccccc;
GPIOG->AFR[1] = 0xcccccccc;
GPIOG->MODER = 0xaaaaaaaa;
/* Configure PGx pins speed to 50 MHz */
GPIOG->OSPEEDR = 0xaaaaaaaa;
/* Connect PHx pins to FMC Alternate function */
GPIOH->AFR[0] = 0x00C0CC00;
GPIOH->AFR[1] = 0xCCCCCCCC;
/* Configure PHx pins in Alternate function mode */
GPIOH->MODER = 0xAAAA08A0;
/* Configure PHx pins speed to 50 MHz */
GPIOH->OSPEEDR = 0xAAAA08A0;
/* Configure PHx pins Output type to push-pull */
GPIOH->OTYPER = 0x00000000;
/* No pull-up, pull-down for PHx pins */
GPIOH->PUPDR = 0x00000000;
/* Connect PIx pins to FMC Alternate function */
GPIOI->AFR[0] = 0xCCCCCCCC;
GPIOI->AFR[1] = 0x00000CC0;
/* Configure PIx pins in Alternate function mode */
GPIOI->MODER = 0x0028AAAA;
/* Configure PIx pins speed to 50 MHz */
GPIOI->OSPEEDR = 0x0028AAAA;
/* Configure PIx pins Output type to push-pull */
GPIOI->OTYPER = 0x00000000;
/* No pull-up, pull-down for PIx pins */
GPIOI->PUPDR = 0x00000000;
/* Configure and enable SDRAM bank1 */
FMC_Bank5_6->SDCR[0] = 0x000029D0;
FMC_Bank5_6->SDTR[0] = 0x01115351;
/* SDRAM initialization sequence */
/* Clock enable command */
FMC_Bank5_6->SDCMR = 0x00000011;
tmpreg = FMC_Bank5_6->SDSR & 0x00000020;
while((tmpreg != 0) & (timeout-- > 0))
/* Delay */
for (index = 0; index<1000; index++);
/* PALL command */
FMC_Bank5_6->SDCMR = 0x00000012;
timeout = 0xFFFF;
/* Auto refresh command */
FMC_Bank5_6->SDCMR = 0x00000073;
timeout = 0xFFFF;
/* MRD register program */
FMC_Bank5_6->SDCMR = 0x00046014;
timeout = 0xFFFF;
/* Set refresh count */
tmpreg = FMC_Bank5_6->SDRTR;
FMC_Bank5_6->SDRTR = (tmpreg | (0x0000027C<<1));
/* Disable write protection */
tmpreg = FMC_Bank5_6->SDCR[0];
FMC_Bank5_6->SDCR[0] = (tmpreg & 0xFFFFFDFF);
Bank1_SDRAM is configured as follow:
FMC_SDRAMTimingInitStructure.FMC_LoadToActiveDelay = 2;
FMC_SDRAMTimingInitStructure.FMC_ExitSelfRefreshDelay = 6;
FMC_SDRAMTimingInitStructure.FMC_SelfRefreshTime = 4;
FMC_SDRAMTimingInitStructure.FMC_RowCycleDelay = 6;
FMC_SDRAMTimingInitStructure.FMC_WriteRecoveryTime = 2;
FMC_SDRAMTimingInitStructure.FMC_RPDelay = 2;
FMC_SDRAMTimingInitStructure.FMC_RCDDelay = 2;
FMC_SDRAMInitStructure.FMC_Bank = SDRAM_BANK;
FMC_SDRAMInitStructure.FMC_ColumnBitsNumber = FMC_ColumnBits_Number_8b;
FMC_SDRAMInitStructure.FMC_RowBitsNumber = FMC_RowBits_Number_11b;
FMC_SDRAMInitStructure.FMC_SDMemoryDataWidth = FMC_SDMemory_Width_16b;
FMC_SDRAMInitStructure.FMC_InternalBankNumber = FMC_InternalBank_Number_4;
FMC_SDRAMInitStructure.FMC_CASLatency = FMC_CAS_Latency_3;
FMC_SDRAMInitStructure.FMC_WriteProtection = FMC_Write_Protection_Disable;
FMC_SDRAMInitStructure.FMC_SDClockPeriod = FMC_SDClock_Period_2;
FMC_SDRAMInitStructure.FMC_ReadBurst = FMC_Read_Burst_disable;
FMC_SDRAMInitStructure.FMC_ReadPipeDelay = FMC_ReadPipe_Delay_1;
FMC_SDRAMInitStructure.FMC_SDRAMTimingStruct = &FMC_SDRAMTimingInitStructure;
#endif /* DATA_IN_ExtSDRAM */
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
