library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity cart_to_polar_tb is end entity cart_to_polar_tb; architecture testbench of cart_to_polar_tb is constant order : natural := 4; constant clk_frequency : natural := 100000000; constant clk_period : time := 1 sec / clk_frequency; signal simulation_run : boolean := true; signal tb_clk : std_ulogic := '1'; -- signal tb_en : std_ulogic := '0'; signal tb_y : signed( 7 downto 0) := to_signed( 0, 8); signal tb_x : signed( 7 downto 0) := to_signed( 0, 8); -- signal tb_sum : unsigned( 7 downto 0); signal tb_phase : signed( 8 downto 0); signal tb_result_en : std_ulogic; begin tb_clk <= not tb_clk after clk_period / 2 when simulation_run; dut: entity work.cart_to_polar port map ( clk => tb_clk, -- : in std_ulogic; -- in_enable => tb_en, -- : in std_ulogic; y_in => tb_y, -- : in signed( 7 downto 0); x_in => tb_x, -- : in signed( 7 downto 0); -- radius_out => tb_sum, -- : out unsigned( 7 downto 0); angle_out => tb_phase, -- : out signed( 8 downto 0); out_enable => tb_result_en -- : out std_ulogic ); main: process variable result_sum : natural; variable result_phase : integer; variable x : integer := 100; variable y : integer := 0; begin wait for 10 * clk_period; for fy in -order to order loop report "outer loop: " & integer'image( fy); for fx in -order to order loop x := fx * 31; y := fy * 31; wait until rising_edge( tb_clk); tb_y <= to_signed( y, tb_y'length); tb_x <= to_signed( x, tb_x'length); tb_en <= '1'; wait until rising_edge( tb_clk); tb_en <= '0'; wait until tb_result_en = '1'; result_sum := to_integer( tb_sum); result_phase := to_integer( tb_phase); wait until rising_edge( tb_clk); report "x: " & integer'image( x) & ", y: " & integer'image( y) & " --> radius: " & integer'image( result_sum) & ", angle: " & integer'image( result_phase); wait for 5 * clk_period; end loop; end loop; simulation_run <= false; report "ready. done."; wait; -- forever end process; end architecture testbench;
