//  MSP430F54x Demo - XT2 sources MCLK & SMCLK
//  Description: This program demonstrates using XT2 to source MCLK. XT1 is not
//  connected in this case.
//  By default, LFXT1 is requested by the following modules:
//     - FLL
//     - ACLK
//  If LFXT1 is NOT used and if the user does not change the source modules,
//  it causes the XT1xxOFIFG flag to be set because it is constantly looking
//  for LFXT1. OFIFG, global oscillator fault flag, will always be set if LFXT1
//  is set. Hence, it is important to ensure LFXT1 is no longer being sourced
//  if LFXT1 is NOT used.
//  MCLK = XT2
//               MSP430F5438
//         ---|RST              |
//            |            XT2IN|-
//            |                 | HF XTAL (455kHz - 16MHz)
//            |           XT2OUT|-
//            |            P11.1|--> MCLK = XT2
//            |            P11.2|--> SMCLK = XT2
//   W. Goh
//   Texas Instruments Inc.
//   February 2009
//   Built with CCE Version: 3.2.2 and IAR Embedded Workbench Version: 4.11B
#include "msp430x54x.h"
void main(void)
  WDTCTL = WDTPW + WDTHOLD;                 // Stop watchdog timer
  P11DIR = BIT1+BIT2;                       // P11.1-2 to output direction
  P11SEL |= BIT1+BIT2;                      // P11.1-2 to output SMCLK,MCLK
  P5SEL |= 0x0C;                            // Port select XT2
  UCSCTL6 &= ~XT2OFF;                       // Enable XT2
  UCSCTL3 |= SELREF_2;                      // FLLref = REFO
                                            // Since LFXT1 is not used,
                                            // sourcing FLL with LFXT1 can cause
                                            // XT1OFFG flag to set
  UCSCTL4 |= SELA_2;                        // ACLK=REFO,SMCLK=DCO,MCLK=DCO
  // Loop until XT1,XT2 & DCO stabilizes
  do
    UCSCTL7 &= ~(XT2OFFG + XT1LFOFFG + XT1HFOFFG + DCOFFG);
                                            // Clear XT2,XT1,DCO fault flags
    SFRIFG1 &= ~OFIFG;                      // Clear fault flags
  }while (SFRIFG1&OFIFG);                   // Test oscillator fault flag
  UCSCTL6 &= ~XT2DRIVE0;                    // Decrease XT2 Drive according to
                                            // expected frequency
  UCSCTL4 |= SELS_5 + SELM_5;               // SMCLK=MCLK=XT2
  while(1);                                 // Loop in place
