********************************************** BlueFlash firmware starting! ********************************************** - Hardware initialization - done - Display initialization - done - Starting up - done ---------------------------------------------- Version : 1.2.BF.8.6 Hardware: 8C7.0L Serial : 04090511C8 Model : W2024A / OPA656 Mod / 4 Channels ---------------------------------------------- Ready - press h for help ********************************************** AMDFlash::WriteCalibration() calibration data written to flash write calibration set = 2 Channel 0 start calibrating ADC offsets ADC 1 Offset = 2 ADC 2 Offset = 1 ADC 3 Offset = 0 ADC 4 Offset = 1 Channel 1 start calibrating ADC offsets ADC 1 Offset = 2 ADC 2 Offset = 2 ADC 3 Offset = 2 ADC 4 Offset = 0 Channel 2 start calibrating ADC offsets ADC 1 Offset = 2 ADC 2 Offset = 1 ADC 3 Offset = 1 ADC 4 Offset = 0 Channel 3 start calibrating ADC offsets ADC 1 Offset = 1 ADC 2 Offset = 1 ADC 3 Offset = 0 ADC 4 Offset = 0 **************** Voltage Range 9 ******************** Calibration run 1 Channel 0: ADC average value = 127 Diff = -1 Channel 1: ADC average value = 131 Diff = 3 Channel 2: ADC average value = 121 Diff = -7 Channel 3: ADC average value = 127 Diff = -1 Calibration run 2 Channel 0: ADC average value = 127 Diff = -1 Channel 1: ADC average value = 128 Diff = 0 Channel 2: ADC average value = 127 Diff = -1 Channel 3: ADC average value = 128 Diff = 0 Calibration run 3 Channel 0: ADC average value = 130 Diff = 2 Channel 2: ADC average value = 129 Diff = 1 Calibration run 4 Channel 0: ADC average value = 127 Diff = -1 Channel 2: ADC average value = 128 Diff = 0 Calibration run 5 Channel 0: ADC average value = 127 Diff = -1 Calibration run 6 Channel 0: ADC average value = 128 Diff = 0 Range 9 calibration complete **************** Voltage Range 10 ******************** Calibration run 1 Channel 0: ADC average value = 136 Diff = 8 Channel 1: ADC average value = 137 Diff = 9 Channel 2: ADC average value = 132 Diff = 4 Channel 3: ADC average value = 135 Diff = 7 Calibration run 2 Channel 0: ADC average value = 127 Diff = -1 Channel 1: ADC average value = 128 Diff = 0 Channel 2: ADC average value = 128 Diff = 0 Channel 3: ADC average value = 128 Diff = 0 Calibration run 3 Channel 0: ADC average value = 128 Diff = 0 Range 10 calibration complete **************** Voltage Range 11 ******************** Calibration run 1 Channel 0: ADC average value = 127 Diff = -1 Channel 1: ADC average value = 128 Diff = 0 Channel 2: ADC average value = 126 Diff = -2 Channel 3: ADC average value = 127 Diff = -1 Calibration run 2 Channel 0: ADC average value = 128 Diff = 0 Channel 2: ADC average value = 128 Diff = 0 Channel 3: ADC average value = 128 Diff = 0 Range 11 calibration complete AMDFlash::WriteCalibration() calibration data written to flash write calibration set = 2 AMDFlash::WriteCalibration() calibration data written to flash write calibration set = 0 ***************************************************************************** * Variables and Registers * ***************************************************************************** * tc_hw_version : 8c7 * Flash ID : c293 * * ------------------------------------*-------------------------------------* * Channel[eCh1].active : 1 * Channel[eCh2].active : 1 * * Channel[eCh3].active : 1 * Channel[eCh4].active : 1 * * ChannelStatusOld[eCh1] : 1 * ChannelStatusOld[eCh2] : 0 * * ChannelStatusOld[eCh3] : 0 * ChannelStatusOld[eCh4] : 0 * * Gain Index : 1 * Debug Mode : 0 * * Channels_Active : 4 * ADC Debug Mode : 0 * * Active_Menu : 6 * New_Menu : 6 * * Zoom Factor (table) : 5.000 * Zoom factor delayed : 1.000 * * SingleShot : 0 * Run : 1 * * ADC_DataAvailable : 1 * : * * KeyboardChanged : 0 * ZoomFactor : 5.000 * * S1Ptr : 91cc00 * S2Ptr : 920c00 * * S3Ptr : 924c00 * S4Ptr : 928c00 * * ------------------------------------*-------------------------------------* * FPGA 1 * FPGA 2 * * _regADC[F1].ctrl : 47 * _regADC[F2].ctrl : 46 * * _regADC[F1].adc_ctrl : 8101 * _regADC[F2].adc_ctrl : 8101 * * _regADC[F1].channel_Adr : 5f0a * _regADC[F2].channel_Adr : 5f5f * * _regADC[F1].trg_val[0] : 85 * _regADC[F2].trg_val[0] : 0 * * _regADC[F1].trg_val[1] : 0 * _regADC[F2].trg_val[1] : a0 * * _regADC[F1].trig_width : 1 * _regADC[F2].trig_width : 1 * * _regADC[F1].trig_range : 0 * _regADC[F2].trig_range : 0 * * _regADC[F1].adc_change : 2020f00 * _regADC[F2].adc_change : 200000a * * _regADC[F1].timebase : fffffffb * _regADC[F2].timebase : fffffffb * * _regADC[].trig_holdoff : ffffffff * _regADC[].pre : 145 * * _regADC[F1].grid_color : 60 * * * ------------------------------------*-------------------------------------* * SwitchesCH1 : fc9 * SwitchesCH3 : 1a * * SwitchesCH2 : 1a * SwitchesCH4 : 1a * * _regExtTrgSetup : 20000000 * _regExtTrgLvl : 7d * * ------------------------------------*-------------------------------------* * MainTimebase : 11 * TB Register Value : fffffffb * * DelayedTimebase : 1 * Frame Count : 2770 * * VirtualTimebase : 0 * Timebase_Ratio : 0.000 * * Cursor_Delayed_1 : 180 * * * Cursor_Delayed_2 : 420 * Cursor_Delayed_Size : 240 * * dmode_Window_Offset_Pos : 0 * * * draw_start : 60 * draw_dm_ixstart : 0 * * draw_factor : 5 * draw_dm_ixfactor : 0 * * MemStartOffs : 25 * MemoryEnd : 4059 * * MemWinStart : 60 * SignalMemSize : 3000 * * USTB EOSignal : 0 * USTB Index : 0 * * Trig_Pos_Mem : 310 * Trig_Pos_Display : 50 * * Trig_Pos_Mem_old : 300 * Trig_Pos_Display_old : 70 * * TrigPosMax : 4000 * : 0 * * ------------------------------------*-------------------------------------* * _TriggerSource : 0 * Average : 0 * * TriggerWay : 1 * * * Trigger_Pos_CH1 : 200 * Trigger_Pos_CH3 : 199 * * Trigger_Pos_CH2 : 450 * Trigger_Pos_CH4 : 201 * * Trigger_Pos_CHE : 61 * PreTrigComp : 0 * * HoldOff_Value : 0 * HoldOff : 0 * * ------------------------------------*-------------------------------------* * Selected_Voltage_CH1 : 8 * CH1_DAC_Offset : 33188 * * Selected_Voltage_CH2 : 11 * CH2_DAC_Offset : 33168 * * Selected_Voltage_CH3 : 8 * CH3_DAC_Offset : 33208 * * Selected_Voltage_CH4 : 8 * CH4_DAC_Offset : 33188 * * CH1 DAC correction 1 : 405 * CH3 DAC correction 1 : 445 * * CH1 DAC correction 2 : 460 * CH3 DAC correction 2 : 490 * * CH1 DAC correction 3 : 420 * CH3 DAC correction 3 : 440 * * CH2 DAC correction 1 : 385 * CH4 DAC correction 1 : 415 * * CH2 DAC correction 2 : 440 * CH4 DAC correction 2 : 460 * * CH2 DAC correction 3 : 400 * CH4 DAC correction 3 : 420 * * CH1 ADC 1 Offset : 2 * CH3 ADC 1 Offset : 2 * * CH1 ADC 2 Offset : 1 * CH3 ADC 2 Offset : 1 * * CH1 ADC 3 Offset : 0 * CH3 ADC 3 Offset : 1 * * CH1 ADC 4 Offset : 1 * CH3 ADC 4 Offset : 0 * * CH2 ADC 1 Offset : 2 * CH4 ADC 1 Offset : 1 * * CH2 ADC 2 Offset : 2 * CH4 ADC 2 Offset : 1 * * CH2 ADC 3 Offset : 2 * CH4 ADC 3 Offset : 0 * * CH2 ADC 4 Offset : 0 * CH4 ADC 4 Offset : 0 * * : 0 * ADC ReadoutLength : 4100 * * ------------------------------------*-------------------------------------* * ADC_VirtualZero_CH1 : 128 * ADC_VirtualZero_CH3 : 128 * * ADC_VirtualZero_CH2 : 128 * ADC_VirtualZero_CH4 : 128 * * Virtual_ZeroLevelCH1 : 0 * Virtual_ZeroLevelCH3 : 0 * * Virtual_ZeroLevelCH2 : 0 * Virtual_ZeroLevelCH4 : 0 * * ZeroLevelCH1 : 200 * ZeroLevelCH3 : 200 * * ZeroLevelCH2 : 200 * ZeroLevelCH4 : 200 * * CursVertPos_TY_1 : 100 * CursVertPos_TY_2 : 400 * * CursVertPos_XY_1 : 100 * CursVertPos_XY_2 : 300 * * CursVertPos_FFT_1 : 60 * CursVertPos_FFT_2 : 475 * * CursHorPos Real1 : 66 * CursHorPos Real2 : 247 * ***************************************************************************** ***************************************************************************** * Variables and Registers * ***************************************************************************** * tc_hw_version : 8c7 * Flash ID : c293 * * ------------------------------------*-------------------------------------* * Channel[eCh1].active : 1 * Channel[eCh2].active : 1 * * Channel[eCh3].active : 1 * Channel[eCh4].active : 1 * * ChannelStatusOld[eCh1] : 1 * ChannelStatusOld[eCh2] : 0 * * ChannelStatusOld[eCh3] : 0 * ChannelStatusOld[eCh4] : 0 * * Gain Index : 1 * Debug Mode : 0 * * Channels_Active : 4 * ADC Debug Mode : 0 * * Active_Menu : 6 * New_Menu : 6 * * Zoom Factor (table) : 5.000 * Zoom factor delayed : 1.000 * * SingleShot : 0 * Run : 1 * * ADC_DataAvailable : 1 * : * * KeyboardChanged : 0 * ZoomFactor : 5.000 * * S1Ptr : 91cc00 * S2Ptr : 920c00 * * S3Ptr : 924c00 * S4Ptr : 928c00 * * ------------------------------------*-------------------------------------* * FPGA 1 * FPGA 2 * * _regADC[F1].ctrl : 47 * _regADC[F2].ctrl : 46 * * _regADC[F1].adc_ctrl : 8101 * _regADC[F2].adc_ctrl : 8101 * * _regADC[F1].channel_Adr : 5f0a * _regADC[F2].channel_Adr : 5f5f * * _regADC[F1].trg_val[0] : 85 * _regADC[F2].trg_val[0] : 0 * * _regADC[F1].trg_val[1] : 0 * _regADC[F2].trg_val[1] : a0 * * _regADC[F1].trig_width : 1 * _regADC[F2].trig_width : 1 * * _regADC[F1].trig_range : 0 * _regADC[F2].trig_range : 0 * * _regADC[F1].adc_change : 2020f00 * _regADC[F2].adc_change : 200000a * * _regADC[F1].timebase : fffffffb * _regADC[F2].timebase : fffffffb * * _regADC[].trig_holdoff : ffffffff * _regADC[].pre : 145 * * _regADC[F1].grid_color : 60 * * * ------------------------------------*-------------------------------------* * SwitchesCH1 : fc9 * SwitchesCH3 : 1a * * SwitchesCH2 : 1a * SwitchesCH4 : 1a * * _regExtTrgSetup : 20000000 * _regExtTrgLvl : 7d * * ------------------------------------*-------------------------------------* * MainTimebase : 11 * TB Register Value : fffffffb * * DelayedTimebase : 1 * Frame Count : 2771 * * VirtualTimebase : 0 * Timebase_Ratio : 0.000 * * Cursor_Delayed_1 : 180 * * * Cursor_Delayed_2 : 420 * Cursor_Delayed_Size : 240 * * dmode_Window_Offset_Pos : 0 * * * draw_start : 60 * draw_dm_ixstart : 0 * * draw_factor : 5 * draw_dm_ixfactor : 0 * * MemStartOffs : 25 * MemoryEnd : 4059 * * MemWinStart : 60 * SignalMemSize : 3000 * * USTB EOSignal : 0 * USTB Index : 0 * * Trig_Pos_Mem : 310 * Trig_Pos_Display : 50 * * Trig_Pos_Mem_old : 300 * Trig_Pos_Display_old : 70 * * TrigPosMax : 4000 * : 0 * * ------------------------------------*-------------------------------------* * _TriggerSource : 0 * Average : 0 * * TriggerWay : 1 * * * Trigger_Pos_CH1 : 200 * Trigger_Pos_CH3 : 199 * * Trigger_Pos_CH2 : 450 * Trigger_Pos_CH4 : 201 * * Trigger_Pos_CHE : 61 * PreTrigComp : 0 * * HoldOff_Value : 0 * HoldOff : 0 * * ------------------------------------*-------------------------------------* * Selected_Voltage_CH1 : 8 * CH1_DAC_Offset : 33188 * * Selected_Voltage_CH2 : 11 * CH2_DAC_Offset : 33168 * * Selected_Voltage_CH3 : 8 * CH3_DAC_Offset : 33208 * * Selected_Voltage_CH4 : 8 * CH4_DAC_Offset : 33188 * * CH1 DAC correction 1 : 405 * CH3 DAC correction 1 : 445 * * CH1 DAC correction 2 : 460 * CH3 DAC correction 2 : 490 * * CH1 DAC correction 3 : 420 * CH3 DAC correction 3 : 440 * * CH2 DAC correction 1 : 385 * CH4 DAC correction 1 : 415 * * CH2 DAC correction 2 : 440 * CH4 DAC correction 2 : 460 * * CH2 DAC correction 3 : 400 * CH4 DAC correction 3 : 420 * * CH1 ADC 1 Offset : 2 * CH3 ADC 1 Offset : 2 * * CH1 ADC 2 Offset : 1 * CH3 ADC 2 Offset : 1 * * CH1 ADC 3 Offset : 0 * CH3 ADC 3 Offset : 1 * * CH1 ADC 4 Offset : 1 * CH3 ADC 4 Offset : 0 * * CH2 ADC 1 Offset : 2 * CH4 ADC 1 Offset : 1 * * CH2 ADC 2 Offset : 2 * CH4 ADC 2 Offset : 1 * * CH2 ADC 3 Offset : 2 * CH4 ADC 3 Offset : 0 * * CH2 ADC 4 Offset : 0 * CH4 ADC 4 Offset : 0 * * : 0 * ADC ReadoutLength : 4100 * * ------------------------------------*-------------------------------------* * ADC_VirtualZero_CH1 : 128 * ADC_VirtualZero_CH3 : 128 * * ADC_VirtualZero_CH2 : 128 * ADC_VirtualZero_CH4 : 128 * * Virtual_ZeroLevelCH1 : 0 * Virtual_ZeroLevelCH3 : 0 * * Virtual_ZeroLevelCH2 : 0 * Virtual_ZeroLevelCH4 : 0 * * ZeroLevelCH1 : 200 * ZeroLevelCH3 : 200 * * ZeroLevelCH2 : 200 * ZeroLevelCH4 : 200 * * CursVertPos_TY_1 : 100 * CursVertPos_TY_2 : 400 * * CursVertPos_XY_1 : 100 * CursVertPos_XY_2 : 300 * * CursVertPos_FFT_1 : 60 * CursVertPos_FFT_2 : 475 * * CursHorPos Real1 : 66 * CursHorPos Real2 : 247 * *****************************************************************************
