/* Version 3.1 Last update: 11-02-2020 This code will control the Left and right of the protogen helmet matrices. The library for controlling the matrices has to be added to the Arduino IDE before the code can work. The library that comes with this code has been modified so that you can link up to 14 matrices instead of 10. If you ever need help or something doesn't work, send me an e-mail to feronium128@gmail.com or contact me on twitter @Feronium Below are the pieces of code listed to show the icons. A '0' means the LED is turned off, a '1' means the LED will be turned on. I'd recommend using the website linked below to make custom icons if you want and then copy the code below here, replacing the icons that are already listed. https://xantorohara.github.io/led-matrix-editor you can also easily turn the icons 90 or 180 degrees on this website if the matrix does not show the right orientation. Also please contact me if you something isn't working properly so it can be fixed in the next update. Have fun! */ #include /* If you would like to use a hall effect sensor (magnet sensor) to turn off the LED-matrices when the visor is taken off, you can uncomment the line below by deleting the 2 slashes. */ //#define visorSensor //Right side of the helmet char noseRight[] = {8, 8, B00000000, B00000000, B10000000, B11000000, B11000000, B11111100, B01111110, B00000000}; char icon01[] = {8, 8, B00100000,B01111000,B11011110,B11000111,B11111111,B00000000,B00000000,B00000000}; char icon02[] = {8, 8, B00000000,B00000000,B00000000,B10000000,B11100000,B01111000,B00011110,B00000111}; char icon03[] = {8, 8, B00000000,B00000000,B00000000,B00000000,B00000111,B00011110,B01111000,B11100000}; char icon04[] = {8, 8, B00000000,B00000000,B00000000,B11100000,B11111000,B00011110,B00000111,B00000001}; char Glitch01[] = {8, 8, B00001100, B00000000, B11010100, B10001001, B00010100, B01000111, B11010001, B10100101}; char Glitch011[] = {8, 8, B00000000, B00000000, B00000000, B11010101, B10000101, B11101010, B00010111, B00000100}; char Glitch02[] = {8, 8, B01110100, B00000000, B01001011, B10010110, B00010010, B00000000, B00000000, B00000000}; char Glitch022[] = {8, 8, B10100010, B01010100, B10000110, B00010010, B00000101, B00000000, B00000000, B00000000}; char Glitch03[] = {8, 8, B00101001, B10101001, B01001011, B00101100, B01110100, B00000000, B00000000, B00000000}; char Glitch033[] = {8, 8, B01001101, B10011010, B01101001, B10100000, B00001000, B00000000, B00000000, B00000000}; char Glitch04[] = {8, 8, B00000000, B00000000, B10010101, B10011010, B10010111, B11101010, B10111010, B11010000}; char Glitch044[] = {8, 8, B00000000, B00000000, B10001000, B10101010, B00011011, B10010101, B00000001, B00000000}; char Eye02[] = {8, 8, B00000000, B00000000, B00000110, B00001111, B11111111, B11111110, B11111100, B11110000}; char Eye01[] = {8, 8, B00000000, B00000000, B10000000, B11100000, B01111111, B00011111, B00000111, B00000000}; char Angry1[] = {8, 8, B00000000, B11000000, B11110000, B11111000, B11111100, B11111100, B11111000, B00000000}; char Angry2[] = {8, 8, B00000000, B00000001, B00000111, B00011111, B00111111, B01111111, B00111111, B00000000}; char Spooked1[] = {8, 8, B00000001, B00000111, B00000111, B00001111, B00001111, B00000111, B00000111, B00000001}; char Spooked2[] = {8, 8, B10000000, B11100000, B11100000, B11110000, B11110000, B11100000, B11100000, B10000000}; //Left side of the helmet char noseLeft[] = {8, 8, B00000000, B00000000, B00000001, B00000011, B00000011, B00111111, B01111110, B00000000}; char icon01L[] = {8, 8, B00001000, B00011110, B01111011, B11100011, B11111111, B00000000, B00000000, B00000000}; char icon02L[] = {8, 8, B00000000, B00000000, B00000000, B00000001, B00000111, B00011110, B01111000, B11100000}; char icon03L[] = {8, 8, B00000000, B00000000, B00000000, B00000000, B11100000, B01111000, B00011110, B00000111}; char icon04L[] = {8, 8, B00000000, B00000000, B00000000, B00000111, B00011111, B01111000, B11100000, B10000000}; char Glitch01L[] = {8, 8, B10100101, B11010001, B01000111, B00001010, B10001001, B11010100, B00001100, B00000000}; char Glitch011L[] = {8, 8, B00000000, B00000000, B00000000, B10101011, B10100001, B01010111, B11101000, B00100000}; char Glitch02L[] = {8, 8, B00000000, B00000000, B00000000, B00000000, B00010010, B10010110, B01001011, B01110100}; char Glitch022L[] = {8, 8, B00000000, B00000000, B00000000, B00000101, B00010010, B10000110, B01010100, B10100010}; char Glitch03L[] = {8, 8, B00000000, B00000000, B00000000, B01110100, B00101100, B01001011, B10101001, B00101001}; char Glitch033L[] = {8, 8, B00000000, B00000000, B00000000, B00001000, B10100000, B01101001, B10011010, B01001101}; char Glitch04L[] = {8, 8, B00000000, B00000000, B10101001, B01011001, B11101001, B01010111, B01011101, B00001011}; char Glitch044L[] = {8, 8, B00000000, B00000000, B00010001, B00000110, B01010101, B11011000, B10101001, B10000000}; char Eye02L[] = {8, 8, B00000000, B00000000, B01100000, B11110000, B11111111, B01111111, B00111111, B00001111}; char Eye01L[] = {8, 8, B00000000, B00000000, B00000001, B00000111, B11111110, B11111000, B11100000, B00000000}; char Angry2L[] = {8, 8, B00000000, B00000011, B00001111, B00011111, B00111111, B00111111, B00011111, B00000000}; char Angry1L[] = {8, 8, B00000000, B10000000, B11100000, B11111000, B11111100, B11111110, B11111100, B00000000}; char Spooked1L[] = {8, 8, B00000001, B00000111, B00000111, B00001111, B00001111, B00000111, B00000111, B00000001}; char Spooked2L[] = {8, 8, B10000000, B11100000, B11100000, B11110000, B11110000, B11100000, B11100000, B10000000}; const int interruptPin = 2; const int interruptPin2 = 3; volatile long debounceTime = 0; volatile long currentTime = 0; int redPin = 5; //These pins are used for the expression indicating rgb LED. int greenPin = 11; int bluePin = 9; //The terms DIN, CLK and CS state where you should connect the the cables from the matrix to the Arduino, //so DIN is connected to digital pin 6 on the arduino and the CLK on digital pin 7 int DIN = 6; // DIN pin of MAX7219 module int CLK = 7; // CLK pin of MAX7219 module int CS = 8; // CS pin of MAX7219 module int maxInUse = 14; //Change this number to the amount of matrixes you linked together byte counter = 0; byte counter2 = 0; int column1L = 104; int column2L = 112; int column3L = 95; int column4L = 103; int column1 = 8; int column2 = 16; int column3 = -1; int column4 = 7; int state = 0; int state2; int stateSerial; MaxMatrix m(DIN, CS, CLK, maxInUse); void setup() { //starting up sequence pinMode(redPin, OUTPUT); pinMode(greenPin, OUTPUT); pinMode(bluePin, OUTPUT); Serial.begin(9600); randomSeed(analogRead(0)); m.init(); m.setIntensity(0); // You can change the brightness of the matrices within a range of 0-15 m.clear(); pinMode(interruptPin, OUTPUT); digitalWrite(2, HIGH); attachInterrupt(digitalPinToInterrupt(2), ISR_button, FALLING); #ifndef visorSensor state2 = 1; #endif #ifdef visorSensor pinMode(interruptPin2, INPUT); attachInterrupt(digitalPinToInterrupt(3), hallSensor, CHANGE); if (digitalRead(3) == 0) { state2 = 1; } #endif } void loop() { //This is where the program loop starts. Serial.println(state2); if (state2 == 1) { //The Hall sensor Detects wheter the visor is attached, only then will the leds turn on if (Serial.available() > 0) { //Used for input through bluetooth or serial monitor instead of button. stateSerial = Serial.read(); //Mainly for testing purposes } if (stateSerial == '0') { state = 0; } if (stateSerial == '1') { state = 1; } if (stateSerial == '2') { state = 2; } m.writeSprite(88, 0, icon01L); //Icons for the mouth and nose are being turned on here m.writeSprite(80, 0, icon02L); m.writeSprite(72, 0, icon03L); m.writeSprite(64, 0, icon04L); m.writeSprite(56, 0, noseLeft); m.writeSprite(48, 0, noseRight); m.writeSprite(40, 0, icon04); m.writeSprite(32, 0, icon03); m.writeSprite(24, 0, icon02); m.writeSprite(16, 0, icon01); if (counter2 > 17) { //The blinking animation begins here for (int i = 0; i < 5; i++) { column1L = column1L - 1; column2L = column2L - 1; column1 = column1 - 1; column2 = column2 - 1; column3L = column3L + 1; column4L = column4L + 1; column3 = column3 + 1; column4 = column4 + 1; m.setColumn(column1L, 00000000); m.setColumn(column2L, 00000000); m.setColumn(column3L, 00000000); m.setColumn(column4L, 00000000); m.setColumn(column1, 00000000); m.setColumn(column2, 00000000); m.setColumn(column3, 00000000); m.setColumn(column4, 00000000); delay(15); counter2++; } column1L = 104; column2L = 112; column3L = 95; column4L = 103; column1 = 8; column2 = 16; column3 = -1; column4 = 7; counter2 = 0; } counter2++; Serial.print(("Expression #")); Serial.println(state); switch (state) { //First button press: Happy expression case 0: m.writeSprite(104, 0, Eye01L); m.writeSprite(96, 0, Eye02L); m.writeSprite(8, 0, Eye02); m.writeSprite(0, 0, Eye01); setColor(0, 32, 0); //Makes the colour of the rgb LED green //You can enter any number between 0 and 255 to make any colour combination. //255,255,255 for example would show a white colour and a lower number would dimm the LED. //(the 16,8 million colours were not a lie :P) break; case 1: //Second button press: Surprised m.writeSprite(104, 0, Spooked1L); m.writeSprite(96, 0, Spooked2L); m.writeSprite(8, 0, Spooked1); m.writeSprite(0, 0, Spooked2); setColor(0, 0, 8); //Makes the colour of the LED blue break; case 2: //Third button press: Angry expression m.writeSprite(104, 0, Angry2L); m.writeSprite(96, 0, Angry1L); m.writeSprite(8, 0, Angry2); m.writeSprite(0, 0, Angry1); setColor(16, 0, 0); //Makes the colour of the LED red counter++; if (counter == 16) { m.writeSprite(64, 0, Glitch044L); m.writeSprite(72, 0, Glitch033L); m.writeSprite(80, 0, Glitch022L); m.writeSprite(88, 0, Glitch011L); m.writeSprite(16, 0, Glitch011); m.writeSprite(24, 0, Glitch022); m.writeSprite(32, 0, Glitch033); m.writeSprite(40, 0, Glitch044); delay(75); counter++; } if ((counter >= 17) && (counter < 18)) { m.writeSprite(88, 0, icon01L); m.writeSprite(80, 0, icon02L); m.writeSprite(72, 0, icon03L); m.writeSprite(64, 0, icon04L); m.writeSprite(40, 0, icon04); m.writeSprite(32, 0, icon03); m.writeSprite(24, 0, icon02); m.writeSprite(16, 0, icon01); delay(200); counter++; } if (counter >= 18) { m.writeSprite(64, 0, Glitch04L); m.writeSprite(72, 0, Glitch03L); m.writeSprite(80, 0, Glitch02L); m.writeSprite(88, 0, Glitch01L); m.writeSprite(16, 0, Glitch01); m.writeSprite(24, 0, Glitch02); m.writeSprite(32, 0, Glitch03); m.writeSprite(40, 0, Glitch04); delay(75); counter = 0; } break; } } else { m.clear(); } } void ISR_button() { //Stuff you shouldn't touch :P currentTime = millis(); if ((currentTime - debounceTime) > 250) { if (state < 2) { state++; } else { state = 0; } } debounceTime = currentTime; } void hallSensor() { //Stuff you shouldn't touch :P currentTime = millis(); if ((currentTime - debounceTime) > 25) { if (digitalRead(3) == 0) { state2 = 1; } else { state2 = 0; } } debounceTime = currentTime; } void setColor(int redValue, int greenValue, int blueValue) { analogWrite(redPin, redValue); analogWrite(greenPin, greenValue); analogWrite(bluePin, blueValue); }
