---------------------------------------------------------------------------------- -- Company: www.Circuit-Break.de -- Engineer: Jens Weiss -- -- Create Date: 00:50:20 06/06/2021 -- Design Name: -- Module Name: SRAM_Bus_Interface - Behavioral -- Project Name: -- Target Devices: -- Tool versions: -- Description: -- -- Dependencies: -- -- Revision: -- Revision 0.01 - File Created -- Additional Comments: -- ---------------------------------------------------------------------------------- library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.NUMERIC_STD.ALL; entity SRAM_Bus_Interface is Generic( DATA_WIDTH : integer := 8; ADRESS_WIDTH : integer := 19); Port(-- Signale to external SRAM CEn : in std_logic; OEn : in std_logic; WEn : in std_logic; SRAM_CEn : out std_logic; SRAM_OEn : out std_logic; SRAM_WEn : out std_logic; SRAM_Addr : out std_logic_vector(ADRESS_WIDTH-1 downto 0); SRAM_Data : inout std_logic_vector(DATA_WIDTH-1 downto 0); uC_Adress : in std_logic_vector(ADRESS_WIDTH-1 downto 0); uC_Data_in : in std_ulogic_vector(DATA_WIDTH-1 downto 0); uC_Data_out : out std_ulogic_vector(DATA_WIDTH-1 downto 0); FPGA_Adress : in std_logic_vector(ADRESS_WIDTH-1 downto 0); FPGA_Data_in : in std_ulogic_vector(DATA_WIDTH-1 downto 0); FPGA_Data_out : out std_ulogic_vector(DATA_WIDTH-1 downto 0); Data_Select : in std_logic; Data_Direction : in std_logic); end SRAM_Bus_Interface; architecture Behavioral of SRAM_Bus_Interface is begin process(Data_Select, Data_Direction, uC_Data_in, FPGA_Data_in, uC_Adress, FPGA_Adress) begin if(Data_Select = '0') and (Data_Direction = '1') then SRAM_Data <= to_stdlogicvector(uC_Data_in); SRAM_Addr <= uC_Adress; elsif (Data_Select = '1') and (Data_Direction = '1') then SRAM_Data <= to_stdlogicvector(FPGA_Data_in); SRAM_Addr <= FPGA_Adress; elsif (Data_Select <= '0') and (Data_Direction <= '0') then SRAM_Data <= (others => 'Z'); SRAM_Addr <= uC_Adress; elsif (Data_Select <= '1') and (Data_Direction <= '0') then SRAM_Data <= (others => 'Z'); SRAM_Addr <= FPGA_Adress; else SRAM_Data <= (others => 'Z'); SRAM_Addr <= (others => 'Z'); end if; end process; SRAM_CEn <= CEn; SRAM_OEn <= OEn; SRAM_WEn <= WEn; uC_Data_out <= to_stdulogicvector(SRAM_Data); FPGA_Data_out <= to_stdulogicvector(SRAM_Data); end Behavioral;
