-------------------------------------------------------------------------------- -- Company: -- Engineer: -- -- Create Date: 11:32:11 12/02/2020 -- Design Name: -- Module Name: D:/Xilinx_Projekts/Dual_Port_SRAM/Mem_Controller_tb.vhd -- Project Name: Dual_Port_SRAM -- Target Device: -- Tool versions: -- Description: -- -- VHDL Test Bench Created by ISE for module: Memory_Controller -- -- Dependencies: -- -- Revision: -- Revision 0.01 - File Created -- Additional Comments: -- -- Notes: -- This testbench has been automatically generated using types std_logic and -- std_logic_vector for the ports of the unit under test. Xilinx recommends -- that these types always be used for the top-level I/O of a design in order -- to guarantee that the testbench will bind correctly to the post-implementation -- simulation model. -------------------------------------------------------------------------------- LIBRARY ieee; USE ieee.std_logic_1164.ALL; USE ieee.numeric_std.ALL; -- Uncomment the following library declaration if using -- arithmetic functions with Signed or Unsigned values --USE ieee.numeric_std.ALL; ENTITY Mem_Controller_tb IS END Mem_Controller_tb; ARCHITECTURE behavior OF Mem_Controller_tb IS -- Component Declaration for the Unit Under Test (UUT) COMPONENT Memory_Controller PORT( clk : IN std_logic; reset : IN std_logic; RAM_uC_Adress : out std_logic_vector(18 downto 0); RAM_uC_Data_in : in std_ulogic_vector(7 downto 0); RAM_uC_Data_out : out std_ulogic_vector(7 downto 0); RAM_FPGA_Adress : out std_logic_vector(18 downto 0); RAM_FPGA_Data_in : in std_ulogic_vector(7 downto 0); RAM_FPGA_Data_out : out std_ulogic_vector(7 downto 0); RAM_Data_Select : out std_logic; RAM_Data_Direction : out std_logic; RAM_CEn : out std_logic; RAM_OEn : out std_logic; RAM_WEn : out std_logic; uC_Data_Addr : INOUT std_logic_vector(7 downto 0); uC_AD16 : IN std_logic; uC_AD17 : IN std_logic; uC_AD18 : IN std_logic; uC_ALE0 : IN std_logic; uC_ALE1 : IN std_logic; uC_CEn : IN std_logic; uC_OEn : IN std_logic; uC_WEn : IN std_logic; Ram_busy : OUT std_logic; Ram_error : OUT std_logic; RAM_done : out std_logic; FPGA_Addr : IN std_logic_vector(18 downto 0); FPGA_Data_in : IN std_ulogic_vector(7 downto 0); FPGA_Data_out : OUT std_ulogic_vector(7 downto 0); FPGA_CEn : IN std_logic; FPGA_rw : IN std_logic; FPGA_start : IN std_logic ); END COMPONENT; --Inputs signal clk : std_logic := '0'; signal reset : std_logic := '0'; signal uC_AD16 : std_logic := '0'; signal uC_AD17 : std_logic := '0'; signal uC_AD18 : std_logic := '0'; signal uC_ALE0 : std_logic := '0'; signal uC_ALE1 : std_logic := '0'; signal uC_CEn : std_logic := '1'; signal uC_OEn : std_logic := '1'; signal uC_WEn : std_logic := '1'; signal FPGA_Addr : std_logic_vector(18 downto 0) := (others => '0'); signal FPGA_Data_in : std_ulogic_vector(7 downto 0) := (others => '0'); signal FPGA_CEn : std_logic := '1'; signal FPGA_rw : std_logic := '0'; signal FPGA_start : std_logic := '0'; signal RAM_uC_Data_in : std_ulogic_vector(7 downto 0); signal RAM_FPGA_Data_in : std_ulogic_vector(7 downto 0); --BiDirs signal uC_Data_Addr : std_logic_vector(7 downto 0); --Outputs signal RAM_uC_Adress : std_logic_vector(18 downto 0); signal RAM_uC_Data_out : std_ulogic_vector(7 downto 0); signal RAM_FPGA_Adress : std_logic_vector(18 downto 0); signal RAM_FPGA_Data_out : std_ulogic_vector(7 downto 0); signal RAM_Data_Select : std_logic := '0'; signal RAM_Data_Direction : std_logic := '0'; signal RAM_CEn : std_logic := '1'; signal RAM_OEn : std_logic := '1'; signal RAM_WEn : std_logic := '1'; signal Ram_busy : std_logic; signal Ram_error : std_logic; signal RAM_done : std_logic; signal FPGA_Data_out : std_ulogic_vector(7 downto 0); -- Clock period definitions constant clk_period : time := 10.42 ns; -- Steuerleitung für SRAM signal file_download : boolean := FALSE; signal file_dump : boolean := FALSE; BEGIN -- Instantiate the Unit Under Test (UUT) uut: Memory_Controller PORT MAP ( clk => clk, reset => reset, RAM_uC_Adress => RAM_uC_Adress, RAM_uC_Data_in => RAM_uC_Data_in, RAM_uC_Data_out => RAM_uC_Data_out, RAM_FPGA_Adress => RAM_FPGA_Adress, RAM_FPGA_Data_in => RAM_FPGA_Data_in, RAM_FPGA_Data_out => RAM_FPGA_Data_out, RAM_Data_Select => RAM_Data_Select, RAM_Data_Direction => RAM_Data_Direction, RAM_CEn => RAM_CEn, RAM_OEn => RAM_OEn, RAM_WEn => RAM_WEn, uC_Data_Addr => uC_Data_Addr, uC_AD16 => uC_AD16, uC_AD17 => uC_AD17, uC_AD18 => uC_AD18, uC_ALE0 => uC_ALE0, uC_ALE1 => uC_ALE1, uC_CEn => uC_CEn, uC_OEn => uC_OEn, uC_WEn => uC_WEn, Ram_busy => Ram_busy, Ram_error => Ram_error, RAM_done => RAM_done, FPGA_Addr => FPGA_Addr, FPGA_Data_in => FPGA_Data_in, FPGA_Data_out => FPGA_Data_out, FPGA_CEn => FPGA_CEn, FPGA_rw => FPGA_rw, FPGA_start => FPGA_start ); -- sram: entity work.sram -- PORT MAP( -- nCE => SRAM_CEn, -- nOE => SRAM_OEn, -- nWE => SRAM_WEn, -- download => file_download, -- dump => file_dump, -- A => SRAM_Addr, -- D => SRAM_Data -- ); -- Clock process definitions clk_process :process begin clk <= '0'; wait for clk_period/2; clk <= '1'; wait for clk_period/2; end process; -- Stimulus process stim_proc: process begin -- hold reset state for 100 ns. wait for 100 ns; --reset operation reset <= '1'; wait for 35ns; reset <= '0'; wait for 35ns; --uC read operation uC_CEn <= '0'; wait for 32ns; uC_AD16 <= '0'; uC_AD17 <= '0'; uC_AD18 <= '0'; uC_Data_Addr <= std_logic_vector(to_unsigned(0, 8)); uC_ALE1 <= '1'; wait for 32ns; uC_ALE1 <= '0'; wait for 32ns; uC_Data_Addr <= std_logic_vector(to_unsigned(0, 8)); uC_ALE0 <= '1'; wait for 32ns; uC_ALE0 <= '0'; wait for 32ns; uC_Data_Addr <= (others => 'Z'); uC_OEn <= '0'; wait for 32ns; uC_OEn <= '1'; wait for 32ns; uC_CEn <= '1'; wait for 200ns; --uC write operation uC_CEn <= '0'; wait for 32ns; uC_AD16 <= '0'; uC_AD17 <= '0'; uC_AD18 <= '0'; uC_Data_Addr <= std_logic_vector(to_unsigned(0, 8)); uC_ALE1 <= '1'; wait for 32ns; uC_ALE1 <= '0'; wait for 32ns; uC_Data_Addr <= std_logic_vector(to_unsigned(1, 8)); uC_ALE0 <= '1'; wait for 32ns; uC_ALE0 <= '0'; wait for 32ns; uC_Data_Addr <= std_logic_vector(to_unsigned(30, 8)); uC_WEn <= '0'; wait for 32ns; uC_WEn <= '1'; wait for 32ns; uC_Data_Addr <= (others => 'Z'); uC_CEn <= '1'; wait for 200ns; --uC read operation uC_CEn <= '0'; wait for 32ns; uC_AD16 <= '0'; uC_AD17 <= '0'; uC_AD18 <= '0'; uC_Data_Addr <= std_logic_vector(to_unsigned(0, 8)); uC_ALE1 <= '1'; wait for 32ns; uC_ALE1 <= '0'; wait for 32ns; uC_Data_Addr <= std_logic_vector(to_unsigned(1, 8)); uC_ALE0 <= '1'; wait for 32ns; uC_ALE0 <= '0'; wait for 32ns; uC_Data_Addr <= (others => 'Z'); uC_OEn <= '0'; wait for 32ns; uC_OEn <= '1'; wait for 32ns; uC_CEn <= '1'; wait for 200ns; --FPGA read operation FPGA_CEn <= '0'; wait for 35ns; RAM_FPGA_Data_in <= "11001111"; FPGA_Addr <= "0000000000000000000"; FPGA_rw <= '0'; FPGA_start <= '1'; wait for 15ns; FPGA_start <= '0'; wait for 135ns; --FPGA write operation FPGA_CEn <= '0'; wait for 35ns; FPGA_Data_in <= "00001111"; FPGA_Addr <= "0000000000000000000"; FPGA_rw <= '1'; FPGA_start <= '1'; wait for 15ns; FPGA_start <= '0'; wait for 135ns; FPGA_CEn <= '1'; wait for 200ns; --write results to file file_dump <= TRUE; wait for 100ns; file_dump <= FALSE; wait for 100ns; wait; end process; END;
