-- Vhdl test bench created from schematic D:\Xilinx_Projekts\Dual_Port_SRAM\Memory_Interface.sch - Mon Jun 07 08:34:44 2021 -- -- Notes: -- 1) This testbench template has been automatically generated using types -- std_logic and std_logic_vector for the ports of the unit under test. -- Xilinx recommends that these types always be used for the top-level -- I/O of a design in order to guarantee that the testbench will bind -- correctly to the timing (post-route) simulation model. -- 2) To use this template as your testbench, change the filename to any -- name of your choice with the extension .vhd, and use the "Source->Add" -- menu in Project Navigator to import the testbench. Then -- edit the user defined section below, adding code to generate the -- stimulus for your design. -- LIBRARY ieee; USE ieee.std_logic_1164.ALL; USE ieee.numeric_std.ALL; ENTITY Memory_Interface_Memory_Interface_sch_tb IS END Memory_Interface_Memory_Interface_sch_tb; ARCHITECTURE behavioral OF Memory_Interface_Memory_Interface_sch_tb IS COMPONENT Memory_Interface PORT( uC_Data_Addr : INOUT STD_LOGIC_VECTOR (7 DOWNTO 0); uC_AD16 : IN STD_LOGIC; uC_AD17 : IN STD_LOGIC; uC_AD18 : IN STD_LOGIC; uC_ALE0 : IN STD_LOGIC; uC_ALE1 : IN STD_LOGIC; uC_CEn : IN STD_LOGIC; uC_OEn : IN STD_LOGIC; uC_WEn : IN STD_LOGIC; uC_clk : IN STD_LOGIC; uC_Execution : IN STD_LOGIC; uC_busy : OUT STD_LOGIC; uC_error : OUT STD_LOGIC; CEn : OUT STD_LOGIC; OEn : OUT STD_LOGIC; WEn : OUT STD_LOGIC; error : OUT STD_LOGIC; uC_reset : IN STD_LOGIC; SRAM_Data : INOUT STD_LOGIC_VECTOR (7 DOWNTO 0); SRAM_Addr : OUT STD_LOGIC_VECTOR (18 DOWNTO 0); SRAM_CEn : OUT STD_LOGIC; SRAM_OEn : OUT STD_LOGIC; SRAM_WEn : OUT STD_LOGIC); END COMPONENT; --inputs signal uC_clk : STD_LOGIC := '0'; signal uC_reset : STD_LOGIC := '0'; signal uC_AD16 : STD_LOGIC := '0'; signal uC_AD17 : STD_LOGIC := '0'; signal uC_AD18 : STD_LOGIC := '0'; signal uC_ALE0 : STD_LOGIC := '0'; signal uC_ALE1 : STD_LOGIC := '0'; signal uC_CEn : STD_LOGIC := '1'; signal uC_OEn : STD_LOGIC := '1'; signal uC_WEn : STD_LOGIC := '1'; signal uC_Execution : STD_LOGIC := '0'; --outputs signal uC_busy : STD_LOGIC; signal uC_error : STD_LOGIC; signal CEn : STD_LOGIC := '1'; signal OEn : STD_LOGIC := '1'; signal WEn : STD_LOGIC := '1'; signal error : STD_LOGIC; signal SRAM_Addr : STD_LOGIC_VECTOR (18 DOWNTO 0); signal SRAM_CEn : STD_LOGIC := '1'; signal SRAM_OEn : STD_LOGIC := '1'; signal SRAM_WEn : STD_LOGIC := '1'; --Bidirectional signal uC_Data_Addr : STD_LOGIC_VECTOR (7 DOWNTO 0); signal SRAM_Data : STD_LOGIC_VECTOR (7 DOWNTO 0); -- Clock period definitions constant uC_clk_period : time := 31.25 ns; -- Steuerleitung für SRAM signal file_download : boolean := FALSE; signal file_dump : boolean := FALSE; BEGIN UUT: Memory_Interface PORT MAP( uC_Data_Addr => uC_Data_Addr, uC_AD16 => uC_AD16, uC_AD17 => uC_AD17, uC_AD18 => uC_AD18, uC_ALE0 => uC_ALE0, uC_ALE1 => uC_ALE1, uC_CEn => uC_CEn, uC_OEn => uC_OEn, uC_WEn => uC_WEn, uC_clk => uC_clk, uC_Execution => uC_Execution, uC_busy => uC_busy, uC_error => uC_error, CEn => CEn, OEn => OEn, WEn => WEn, error => error, uC_reset => uC_reset, SRAM_Data => SRAM_Data, SRAM_Addr => SRAM_Addr, SRAM_CEn => SRAM_CEn, SRAM_OEn => SRAM_OEn, SRAM_WEn => SRAM_WEn ); Sram: entity work.Sram PORT MAP( nCE => SRAM_CEn, nOE => SRAM_OEn, nWE => SRAM_WEn, download => file_download, dump => file_dump, A => SRAM_Addr, D => SRAM_Data ); -- Clock process definitions uC_clk_process :process begin uC_clk <= '0'; wait for uC_clk_period/2; uC_clk <= '1'; wait for uC_clk_period/2; end process; -- Stimulus process stim_proc: process begin -- hold reset state for 100 ns. wait for 500 ns; -- insert stimulus here uC_reset <= '1'; wait for 50ns; uC_reset <= '0'; wait for 500ns; uC_Execution <= '1'; wait for 50ns; uC_Execution <= '0'; wait for 50ns; wait for 6us; file_dump <= TRUE; wait; end process; END;
