-- ====================================================================================== -- A generic VHDL entity for a typical SRAM with complete timing parameters -- -- Static memory, version 1.3 9. August 1996 -- -- ====================================================================================== -- -- (C) Andre' Klindworth, Dept. of Computer Science -- University of Hamburg -- Vogt-Koelln-Str. 30 -- 22527 Hamburg -- klindwor@informatik.uni-hamburg.de -- -- This VHDL code may be freely copied as long as the copyright note isn't removed from -- its header. Full affiliation of anybody modifying this file shall be added to the -- header prior to further distribution. -- The download procedure originates from DLX memory-behaviour.vhdl: -- Copyright (C) 1993, Peter J. Ashenden -- Mail: Dept. Computer Science -- University of Adelaide, SA 5005, Australia -- e-mail: petera@cs.adelaide.edu.au -- -- -- -- Features: -- -- o generic memory size, width and timing parameters -- -- o 18 typical SRAM timing parameters supported -- -- o clear-on-power-up and/or download-on-power-up if requested by generic -- -- o RAM dump into or download from an ASCII-file at any time possible -- (requested by signal) -- -- o pair of active-low and active-high Chip-Enable signals -- -- o nWE-only memory access control -- -- o many (but not all) timing and access control violations reported by assertions -- -- -- -- RAM data file format: -- -- The format of the ASCII-files for RAM download or dump is very simple: -- Each line of the file consists of the memory address (given as a decimal number). -- and the corresponding RAM data at this address (given as a binary number). -- Any text in a line following the width-th digit of the binary number is ignored. -- Please notice that address and data have to be seperated by a SINGLE blank, -- that the binary number must have as many digits as specified by the generic width, -- and that no additional blanks or blank lines are tolerated. Example: -- -- 0 0111011010111101 This text is interpreted as a comment -- 1 1011101010110010 -- 17 0010001001000100 -- -- -- Hints & traps: -- -- If you have problems using this model, please feel free to to send me an e-mail. -- Here are some potential problems which have been reported to me: -- -- o There's a potential problem with passing the filenames for RAM download or -- dump via port signals of type string. E.g. for Synopsys VSS, the string -- assigned to a filename-port should have the same length as its default value. -- If you are sure that you need a download or dump only once during a single -- simulation run, you may remove the filename-ports from the interface list -- and replace the constant string in the corresponding file declarations. -- -- o Some simulators do not implement all of the standard TEXTIO-functions as -- specified by the IEEE Std 1076-87 and IEEE Std 1076-93. Check it out. -- If any of the (multiple overloaded) writeline, write, readline or -- read functions that are used in this model is missing, you have to -- write your own version and you should complain at your simulator tool -- vendor for this deviation from the standard. -- -- o If you are about to simulate a large RAM e.g. 4M * 32 Bit, representing -- the RAM with a static array variable of 4 * 32 std_logic values uses a large -- amount of memory and may result in an out-of-memory error. A potential remedy -- for this is to use a dynamic data type, allocating memory for small blocks of -- RAM data (e.g. a single word) only if they are actually referenced during a -- simulation run. A version of the SRAM model with dynamic memory allocation -- shall be available at the same WWW-site were you obtained this file or at: -- http://tech-www.informatik.uni-hamburg.de/vhdl/models/sram/sram.html -- -- -- Bugs: -- -- No severe bugs have been found so far. Please report any bugs: -- e-mail: klindwor@informatik.uni-hamburg.de -- USE std.textio.all; LIBRARY IEEE; USE IEEE.std_logic_1164.all; USE IEEE.std_logic_unsigned.all; USE IEEE.std_logic_textio.all; ENTITY sram IS GENERIC ( clear_on_power_up: boolean := TRUE; -- if TRUE, RAM is initialized with zeroes at start of simulation -- Clearing of RAM is carried out before download takes place download_on_power_up: boolean := TRUE; -- if TRUE, RAM is downloaded at start of simulation trace_ram_load: boolean := FALSE; -- Echoes the data downloaded to the RAM on the screen -- (included for debugging purposes) enable_nWE_only_control: boolean := FALSE; -- Read-/write access controlled by nWE only -- nOE may be kept active all the time -- Configuring RAM size size: INTEGER := 524288; -- number of memory words adr_width: INTEGER := 19; -- number of address bits width: INTEGER := 8; -- number of bits per memory word -- READ-cycle timing parameters tAA_max: TIME := 10 NS; -- Address Access Time tOHA_min: TIME := 3 NS; -- Output Hold Time tACE_max: TIME := 10 NS; -- nCE/CE2 Access Time tDOE_max: TIME := 5 NS; -- nOE Access Time tLZOE_min: TIME := 0 NS; -- nOE to Low-Z Output tHZOE_max: TIME := 5 NS; -- OE to High-Z Output tLZCE_min: TIME := 3 NS; -- nCE/CE2 to Low-Z Output tHZCE_max: TIME := 5 NS; -- CE/nCE2 to High Z Output -- WRITE-cycle timing parameters tWC_min: TIME := 10 NS; -- Write Cycle Time tSCE_min: TIME := 7 NS; -- nCE/CE2 to Write End tAW_min: TIME := 7 NS; -- tAW Address Set-up Time to Write End tHA_min: TIME := 0 NS; -- tHA Address Hold from Write End tSA_min: TIME := 0 NS; -- Address Set-up Time tPWE_min: TIME := 7 NS; -- nWE Pulse Width tSD_min: TIME := 5 NS; -- Data Set-up to Write End tHD_min: TIME := 5 NS; -- Data Hold from Write End tHZWE_max: TIME := 5 NS; -- nWE Low to High-Z Output tLZWE_min: TIME := 3 NS -- nWE High to Low-Z Output ); PORT ( nCE: IN std_logic := '1'; -- low-active Chip-Enable of the SRAM device; defaults to '1' (inactive) nOE: IN std_logic := '1'; -- low-active Output-Enable of the SRAM device; defaults to '1' (inactive) nWE: IN std_logic := '1'; -- low-active Write-Enable of the SRAM device; defaults to '1' (inactive) A: IN std_logic_vector(adr_width-1 downto 0); -- address bus of the SRAM device D: INOUT std_logic_vector(width-1 downto 0); -- bidirectional data bus to/from the SRAM device CE2: IN std_logic := '1'; -- high-active Chip-Enable of the SRAM device; defaults to '1' (active) download: IN boolean := FALSE; -- A FALSE-to-TRUE transition on this signal downloads the data -- in file specified by download_filename to the RAM download_filename: IN string := "sram_load.dat"; -- name of the download source file -- Passing the filename via a port of type -- ********** string may cause a problem with some -- WATCH OUT! simulators. The string signal assigned -- ********** to the port at least should have the -- same length as the default value. dump: IN boolean := FALSE; -- A FALSE-to-TRUE transition on this signal dumps -- the current content of the memory to the file -- specified by dump_filename. dump_start: IN natural := 0; -- Written to the dump-file are the memory words from memory address dump_end: IN natural := size-1; -- dump_start to address dump_end (default: all addresses) dump_filename: IN string := "sram_dump.dat" -- name of the dump destination file -- (See note at port download_filename) ); END sram; ARCHITECTURE behavior OF sram IS FUNCTION Check_For_Valid_Data (a: std_logic_vector) RETURN BOOLEAN IS VARIABLE result: BOOLEAN; BEGIN result := TRUE; FOR i IN a'RANGE LOOP result := (a(i) = '0') OR (a(i) = '1'); IF NOT result THEN EXIT; END IF; END LOOP; RETURN result; END Check_For_Valid_Data; FUNCTION Check_For_Tristate (a: std_logic_vector) RETURN BOOLEAN IS VARIABLE result: BOOLEAN; BEGIN result := TRUE; FOR i IN a'RANGE LOOP result := (a(i) = 'Z'); IF NOT result THEN EXIT; END IF; END LOOP; RETURN result; END Check_For_Tristate; SIGNAL tristate_vec: std_logic_vector(D'RANGE); -- constant all-Z vector for data bus D SIGNAL undef_vec: std_logic_vector(D'RANGE); -- constant all-X vector for data bus D SIGNAL undef_adr_vec: std_logic_vector(A'RANGE); -- constant all-X vector for address bus SIGNAL read_active: BOOLEAN := FALSE; -- Indicates whether the SRAM is sending on the D bus SIGNAL read_valid: BOOLEAN := FALSE; -- If TRUE, the data output by the RAM is valid SIGNAL read_data: std_logic_vector(D'RANGE); -- content of the memory location addressed by A SIGNAL do_write: std_logic := '0'; -- A '0'->'1' transition on this signal marks -- the moment when the data on D is stored in the -- addressed memory location SIGNAL adr_setup: std_logic_vector(A'RANGE); -- delayed value of A to model the Address Setup Time SIGNAL adr_hold: std_logic_vector(A'RANGE); -- delayed value of A to model the Address Hold Time SIGNAL valid_adr: std_logic_vector(A'RANGE); -- valid memory address derived from A after -- considering Address Setup and Hold Times BEGIN PROCESS BEGIN -- static assignments to the variable length busses' -- all-X and all-Z signal vectors FOR i IN D'RANGE LOOP tristate_vec(i) <= 'Z'; undef_vec(i) <= 'X'; END LOOP; FOR i IN A'RANGE LOOP undef_adr_vec(i) <= 'X'; END LOOP; WAIT; END PROCESS; memory: PROCESS CONSTANT low_address: natural := 0; CONSTANT high_address: natural := size -1; TYPE memory_array IS ARRAY (natural RANGE low_address TO high_address) OF std_logic_vector(width-1 DOWNTO 0); VARIABLE mem: memory_array; VARIABLE address : natural; VARIABLE write_data: std_logic_vector(width-1 DOWNTO 0); PROCEDURE power_up (mem: inout memory_array; clear: boolean) IS VARIABLE init_value: std_logic; BEGIN IF clear THEN init_value := '0'; write(output, string'("Initializing SRAM with zero ...") ); ELSE init_value := 'X'; END IF; FOR add IN low_address TO high_address LOOP FOR j IN (width-1) DOWNTO 0 LOOP mem(add)(j) := init_value; END LOOP; END LOOP; END power_up; PROCEDURE load (mem: INOUT memory_array; download_filename: IN string) IS FILE source : text IS IN download_filename; VARIABLE inline, outline : line; VARIABLE add: natural; VARIABLE c : character; VARIABLE source_line_nr: integer := 1; VARIABLE init_value: std_logic := 'U'; BEGIN write(output, string'("Loading SRAM from file ") & download_filename & string'(" ... ") ); WHILE NOT endfile(source) LOOP readline(source, inline); read(inline, add); read(inline, c); IF (c /= ' ') THEN write(outline, string'("Syntax error in file '")); write(outline, download_filename); write(outline, string'("', line ")); write(outline, source_line_nr); writeline(output, outline); ASSERT FALSE REPORT "RAM loader aborted." SEVERITY FAILURE; END IF; FOR i IN (width -1) DOWNTO 0 LOOP read(inline, c); IF (c = '1') THEN mem(add)(i) := '1'; ELSE IF (c /= '0') THEN write(outline, string'("-W- Invalid character '")); write(outline, c); write(outline, string'("' in Bitstring in '")); write(outline, download_filename); write(outline, '('); write(outline, source_line_nr); write(outline, string'(") is set to '0'")); writeline(output, outline); END IF; mem(add)(i) := '0'; END IF; END LOOP; IF (trace_ram_load) THEN write(outline, string'("RAM[")); write(outline, add); write(outline, string'("] := ")); write(outline, mem(add)); writeline(output, outline ); END IF; source_line_nr := source_line_nr +1; END LOOP; -- WHILE END load; -- PROCEDURE PROCEDURE do_dump (mem: INOUT memory_array; dump_start, dump_end: IN natural; dump_filename: IN string) IS FILE dest : text IS OUT dump_filename; VARIABLE l : line; VARIABLE c : character; BEGIN IF (dump_start > dump_end) OR (dump_end >= size) THEN ASSERT FALSE REPORT "Invalid addresses for memory dump. Cancelled." SEVERITY ERROR; ELSE FOR add IN dump_start TO dump_end LOOP write(l, add); write(l, ' '); FOR i IN (width-1) downto 0 LOOP write(l, mem(add)(i)); END LOOP; writeline(dest, l); END LOOP; END IF; END do_dump; -- PROCEDURE BEGIN power_up(mem, clear_on_power_up); IF download_on_power_up THEN load(mem, download_filename); END IF; LOOP IF do_write'EVENT and (do_write = '1') then IF NOT Check_For_Valid_Data(D) THEN IF D'EVENT AND Check_For_Valid_Data(D'DELAYED) THEN write(output, "-W- Data changes exactly at end-of-write to SRAM."); write_data := D'delayed; ELSE write(output, "-E- Data not valid at end-of-write to SRAM."); write_data := undef_vec; END IF; ELSIF NOT D'DELAYED(tHD_min)'STABLE(tSD_min) THEN write(output, "-E- tSD violation: Data input changes within setup-time at end-of-write to SRAM."); write_data := undef_vec; ELSIF NOT D'STABLE(tHD_min) THEN write(output, "-E- tHD violation: Data input changes within hold-time at end-of-write to SRAM."); write_data := undef_vec; ELSIF nWE'DELAYED(tHD_min)'STABLE(tPWE_min) THEN write(output, "-E- tPWE violation: Pulse width of nWE too short at SRAM."); write_data := undef_vec; ELSE write_data := D; END IF; mem(CONV_INTEGER(valid_adr)) := write_data; END IF; IF Check_For_Valid_Data(valid_adr) THEN read_data <= mem(CONV_INTEGER(valid_adr)); ELSE read_data <= undef_vec; END IF; IF dump AND dump'EVENT THEN do_dump(mem, dump_start, dump_end, dump_filename); END IF; IF download AND download'EVENT THEN load(mem, download_filename); END IF; WAIT ON do_write, valid_adr, dump, download; END LOOP; END PROCESS memory; adr_setup <= TRANSPORT A AFTER tAA_max; adr_hold <= TRANSPORT A AFTER tOHA_min; valid_adr <= adr_setup WHEN Check_For_Valid_Data(adr_setup) AND (adr_setup = adr_hold) AND adr_hold'STABLE(tAA_max - tOHA_min) ELSE undef_adr_vec; read_active <= ( (nOE = '0') AND (nOE'DELAYED(tLZOE_min) = '0') AND nOE'STABLE(tLZOE_min) AND ((nWE = '1') OR (nWE'DELAYED(tHZWE_max) = '0')) AND (nCE = '0') AND (CE2 = '1') AND nCE'STABLE(tLZCE_min) AND CE2'STABLE(tLZCE_min)) OR (read_active AND (nOE'DELAYED(tHZOE_max) = '0') AND (nWE'DELAYED(tHZWE_max) = '1') AND (nCE'DELAYED(tHZCE_max) = '0') AND (CE2'DELAYED(tHZCE_max) = '1')); read_valid <= ( (nOE = '0') AND nOE'STABLE(tDOE_max) AND (nWE = '1') AND (nWE'DELAYED(tHZWE_max) = '1') AND (nCE = '0') AND (CE2 = '1') AND nCE'STABLE(tACE_max) AND CE2'STABLE(tACE_max)) OR (read_valid AND read_active); D <= read_data WHEN read_valid and read_active ELSE undef_vec WHEN not read_valid and read_active ELSE tristate_vec; PROCESS (nWE, nCE, CE2) BEGIN IF ((nCE = '1') OR (nWE = '1') OR (CE2 = '0')) AND (nCE'DELAYED = '0') AND (CE2'DELAYED = '1') AND (nWE'DELAYED = '0') -- End of Write THEN do_write <= '1' AFTER tHD_min; ELSE IF (Now > 10 NS) AND (nCE = '0') AND (CE2 = '1') AND (nWE = '0') -- Start of Write THEN ASSERT Check_For_Valid_Data(A) REPORT "Address not valid at start-of-write to RAM." SEVERITY FAILURE; ASSERT A'STABLE(tSA_min) REPORT "tSA violation: Address changed within setup-time at start-of-write to SRAM." SEVERITY ERROR; ASSERT enable_nWE_only_control OR ((nOE = '1') AND nOE'STABLE(tSA_min)) REPORT "tSA violation: nOE not inactive at start-of-write to RAM." SEVERITY ERROR; END IF; do_write <= '0'; END IF; END PROCESS; -- The following processes check for validity of the control signals at the -- SRAM interface. Removing them to speed up simulation will not affect the -- functionality of the SRAM model. PROCESS (A) -- Checks that an address change is allowed BEGIN IF (Now > 0 NS) THEN -- suppress obsolete error message at time 0 ASSERT (nCE = '1') OR (CE2 = '0') OR (nWE = '1') REPORT "Address not stable while write-to-SRAM active" SEVERITY FAILURE; ASSERT (nCE = '1') OR (CE2 = '0') OR (nWE = '1') OR (nCE'DELAYED(tHA_min) = '1') OR (CE2'DELAYED(tHA_min) = '0') OR (nWE'DELAYED(tHA_min) = '1') REPORT "tHA violation: Address changed within hold-time at end-of-write to SRAM." SEVERITY FAILURE; END IF; END PROCESS; PROCESS (nOE, nWE, nCE, CE2) -- Checks that control signals at RAM are valid all the time BEGIN IF (Now > 0 NS) AND (nCE /= '1') AND (CE2 /= '0') THEN IF (nCE = '0') AND (CE2 = '1') THEN ASSERT (nWE = '0') OR (nWE = '1') REPORT "Invalid nWE-signal at SRAM while nCE is active" SEVERITY WARNING; ELSE IF (nCE /= '0') THEN ASSERT (nOE = '1') REPORT "Invalid nCE-signal at SRAM while nOE not inactive" SEVERITY WARNING; ASSERT (nWE = '1') REPORT "Invalid nCE-signal at SRAM while nWE not inactive" SEVERITY ERROR; END IF; IF (CE2 /= '1') THEN ASSERT (nOE = '1') REPORT "Invalid CE2-signal at SRAM while nOE not inactive" SEVERITY WARNING; ASSERT (nWE = '1') REPORT "Invalid CE2-signal at SRAM while nWE not inactive" SEVERITY ERROR; END IF; END IF; END IF; END PROCESS; END behavior;
