---------------------------------------------------------------------------------- -- Company: www.Circuit-Break.de -- Engineer: Jens Weiss -- -- Create Date: 13:29:13 12/17/2020 -- Design Name: -- Module Name: Memory_Interface - Behavioral -- Project Name: -- Target Devices: -- Tool versions: -- Description: -- -- Dependencies: -- -- Revision: -- Revision 0.01 - File Created -- Additional Comments: -- ---------------------------------------------------------------------------------- library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.NUMERIC_STD.ALL; entity Memory_Interface is Port ( uC_clk : in std_logic; uC_reset : in std_logic; uc_error : out std_logic; uC_busy : out std_logic; uC_Data_Addr : inout std_logic_vector (7 downto 0); uC_AD16 : in std_logic; uC_AD17 : in std_logic; uC_AD18 : in std_logic; uC_ALE0 : in std_logic; uC_ALE1 : in std_logic; uC_CEn : in std_logic; uC_OEn : in std_logic; uC_WEn : in std_logic; uC_Execution : in std_logic; SRAM_Data : inout std_logic_vector (7 downto 0); SRAM_Addr : out std_logic_vector (18 downto 0); SRAM_CEn : out std_logic; SRAM_OEn : out std_logic; SRAM_WEn : out std_logic; FPGA_IO_out : out std_logic_vector(3 downto 0)); end Memory_Interface; architecture Behavioral of Memory_Interface is signal clk_160 : std_logic; signal clk_locked : std_logic; signal internal_ram_error : std_logic; signal internal_ram_busy : std_logic; signal internal_RAM_done : std_logic; signal internal_FPGA_Addr : std_logic_vector (18 downto 0); signal internal_FPGA_Data_out : std_logic_vector (7 downto 0); signal internal_FPGA_Data_in : std_logic_vector (7 downto 0); signal internal_FPGA_CEn : std_logic; signal internal_FPGA_rw : std_logic; signal internal_FPGA_start : std_logic; begin my_memory_controller: entity work.Memory_Controller port map(-- clock signal clk => clk_160, reset => uC_reset, SRAM_CEn => SRAM_CEn, SRAM_OEn => SRAM_OEn, SRAM_WEn => SRAM_WEn, SRAM_Addr => SRAM_Addr, SRAM_Data => SRAM_Data, uC_Data_Addr => uC_Data_Addr, uC_AD16 => uC_AD16, uC_AD17 => uC_AD17, uC_AD18 => uC_AD18, uC_ALE0 => uC_ALE0, uC_ALE1 => uC_ALE1, uC_CEn => uC_CEn, uC_OEn => uC_OEn, uC_WEn => uC_WEn, Ram_busy => internal_ram_busy, Ram_error => internal_ram_error, RAM_done => internal_RAM_done, FPGA_Addr => internal_FPGA_Addr, FPGA_Data_in => internal_FPGA_Data_in, FPGA_Data_out => internal_FPGA_Data_out, FPGA_CEn => internal_FPGA_CEn, FPGA_rw => internal_FPGA_rw, FPGA_start => internal_FPGA_start); my_sram_operation: entity work.SRAM_Operation port map(clk => clk_160, reset => uC_reset, SRAM_Addr => internal_FPGA_Addr, SRAM_Data_in => internal_FPGA_Data_out, SRAM_Data_out => internal_FPGA_Data_in, SRAM_CSn => internal_FPGA_CEn, SRAM_rw => internal_FPGA_rw, SRAM_exe => internal_FPGA_start, SRAM_done => internal_RAM_done, Execution => uC_Execution); my_clk_manager: entity work.clk_manager port map(clk_in => uC_clk, clk_160 => clk_160, reset => uC_reset, locked => clk_locked); uC_error <= (not clk_locked) or internal_ram_error; uC_busy <= internal_ram_busy; FPGA_IO_out(3) <= uC_Execution; FPGA_IO_out(2) <= internal_ram_busy; FPGA_IO_out(1) <= internal_ram_error; FPGA_IO_out(0) <= uC_reset; end Behavioral;
