>>>: avrdude -u -c avr910 -P COM2 -p m8 Detected 1e950f = ATmega328P ampel_neu.hex: 7.808 / 65.536 Bytes (11,91%) >>>: avrdude -u -c avr910 -P COM2 -p m8 Detected 1e950f = ATmega328P ampel_neu.hex: 7.808 / 32.768 Bytes (23,83%) ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ >>>: avrdude -u -c avr910 -p m328p -P COM2 -U flash:w:"D:\cyg_test\GDI_C_CYGWIN\AUFGABEN\aufgabe_4\ampel_neu\default\ampel_neu.hex":a Found programmer: Id = "AVR ISP"; type = S Software Version = 2.5; Hardware Version = 2.0 Programmer supports auto addr increment. Programmer supports buffered memory access with buffersize = 512 bytes. Programmer supports the following devices: Device code: 0x01 = (unknown) Device code: 0x02 = (unknown) Device code: 0x03 = (unknown) Device code: 0x04 = (unknown) Device code: 0x05 = (unknown) Device code: 0x06 = (unknown) Device code: 0x07 = (unknown) Device code: 0x08 = (unknown) Device code: 0x09 = (unknown) Device code: 0x0a = (unknown) Device code: 0x0b = (unknown) Device code: 0x0c = (unknown) Device code: 0x0d = (unknown) Device code: 0x0e = (unknown) Device code: 0x0f = (unknown) Device code: 0x10 = (unknown) Device code: 0x11 = (unknown) Device code: 0x12 = (unknown) Device code: 0x13 = AT90S1200 Device code: 0x14 = (unknown) Device code: 0x15 = (unknown) Device code: 0x16 = (unknown) Device code: 0x17 = (unknown) Device code: 0x18 = (unknown) Device code: 0x19 = (unknown) Device code: 0x1a = (unknown) Device code: 0x1b = (unknown) Device code: 0x1c = (unknown) Device code: 0x1d = (unknown) Device code: 0x1e = (unknown) Device code: 0x1f = (unknown) Device code: 0x20 = ATtiny43u Device code: 0x21 = (unknown) Device code: 0x22 = (unknown) Device code: 0x23 = (unknown) Device code: 0x24 = (unknown) Device code: 0x25 = (unknown) Device code: 0x26 = (unknown) Device code: 0x27 = (unknown) Device code: 0x28 = AT90S4414 Device code: 0x29 = (unknown) Device code: 0x2a = (unknown) Device code: 0x2b = (unknown) Device code: 0x2c = (unknown) Device code: 0x2d = (unknown) Device code: 0x2e = (unknown) Device code: 0x2f = (unknown) Device code: 0x30 = AT90S4433 Device code: 0x31 = (unknown) Device code: 0x32 = (unknown) Device code: 0x33 = (unknown) Device code: 0x34 = AT90S2333 Device code: 0x35 = (unknown) Device code: 0x36 = (unknown) Device code: 0x37 = (unknown) Device code: 0x38 = AT90S8515 Device code: 0x39 = (unknown) Device code: 0x3a = ATmega8515 Device code: 0x3b = (unknown) Device code: 0x3c = (unknown) Device code: 0x3d = (unknown) Device code: 0x3e = (unknown) Device code: 0x3f = (unknown) Device code: 0x40 = (unknown) Device code: 0x41 = ATmega103 Device code: 0x42 = (unknown) Device code: 0x43 = ATmega128 Device code: 0x44 = (unknown) Device code: 0x45 = ATmega64 Device code: 0x46 = (unknown) Device code: 0x47 = (unknown) Device code: 0x48 = (unknown) Device code: 0x49 = (unknown) Device code: 0x4a = (unknown) Device code: 0x4b = (unknown) Device code: 0x4c = AT90S2343 Device code: 0x4d = (unknown) Device code: 0x4e = (unknown) Device code: 0x4f = (unknown) Device code: 0x50 = (unknown) Device code: 0x51 = (unknown) Device code: 0x52 = (unknown) Device code: 0x53 = (unknown) Device code: 0x54 = (unknown) Device code: 0x55 = ATtiny12 Device code: 0x56 = ATtiny15 Device code: 0x57 = (unknown) Device code: 0x58 = (unknown) Device code: 0x59 = (unknown) Device code: 0x5a = (unknown) Device code: 0x5b = (unknown) Device code: 0x5c = ATtiny28 Device code: 0x5d = (unknown) Device code: 0x5e = ATtiny4313 Device code: 0x5f = (unknown) Device code: 0x60 = ATmega161 Device code: 0x61 = (unknown) Device code: 0x62 = (unknown) Device code: 0x63 = ATmega162 Device code: 0x64 = ATmega163 Device code: 0x65 = (unknown) Device code: 0x66 = (unknown) Device code: 0x67 = (unknown) Device code: 0x68 = AT90S8535 Device code: 0x69 = ATmega8535 Device code: 0x6a = (unknown) Device code: 0x6b = (unknown) Device code: 0x6c = AT90S4434 Device code: 0x6d = (unknown) Device code: 0x6e = (unknown) Device code: 0x6f = (unknown) Device code: 0x70 = (unknown) Device code: 0x71 = (unknown) Device code: 0x72 = ATmega32 Device code: 0x73 = (unknown) Device code: 0x74 = ATmega6450 Device code: 0x75 = ATmega6490 Device code: 0x76 = ATmega8 Device code: 0x77 = (unknown) Device code: 0x78 = ATmega169 Device code: 0x79 = (unknown) Device code: 0x7a = (unknown) Device code: 0x7b = (unknown) Device code: 0x7c = (unknown) Device code: 0x7d = (unknown) Device code: 0x7e = (unknown) Device code: 0x7f = (unknown) avrdude.exe: error: selected device is not supported by programmer: m328p avrdude.exe: initialization failed, rc=-1 Double check connections and try again, or use -F to override this check. avrdude.exe done. Thank you.
