/* client.c */ #include #include #include #include #include //#include #ifdef _WIN32 /* Headerfiles für Windows */ #include #include #include //#include #else /* Headerfiles für UNIX/Linux */ #include #include #include #include #include #include #include #include #include #endif #ifdef _WIN32 #else typedef int SOCKET; void Sleep(long); int getch(void); int kbhit(void); void pos(int, char*); #endif SOCKET connect_server(char *ip_addr, unsigned int port); void communication_server(void); void disconnect_server(SOCKET sock); int main( int argc, char *argv[]) { communication_server(); //printf("Status: %i\r\n\r\n", flash("ATmega4809_Uart_Treiber.hex")); return 0; } void communication_server(void) { //Adressen char ip_addr[] = "10.9.21.216"; //char ip_addr[] = "localhost"; //char ip_addr[] = "192.168.137.123"; unsigned int port = 1234; SOCKET sock = connect_server(ip_addr, port); char rec; int connection_status = 0; unsigned int connection_try = 0; long int menue = 0; printf("[SYSTEM]: Kommunikationsmodul >client<\r\n[!] Menue\r\n[#] Verlassen\r\n\r\n"); while(1) { Sleep(1); //if(connection_try++ > 2000) { connection_try = 0; rec = '&'; if(send(sock, &rec, 1, 0) < 0) {connection_status = 1; }} if(recv(sock, &rec, 1, 0) > 0) printf("%c", rec); if(kbhit()) { rec = getch(); if(rec == '#') { disconnect_server(sock); return; } if(rec == '!') { printf("[SYSTEM]: Menue\r\n[f] flash\r\n[#] Verlassen\r\n"); rec = getch(); switch(rec) { case 'f': break; default: printf("[SYSTEM]: Menue Verlassen\r\n"); break; } } if(send(sock, &rec, 1, 0) < 0) {connection_status = 1; } } if(connection_status) //Erneuter Verbindungsaufbau { printf("[SYSTEM]: Verbindung Verloren, Wiederherstellung\r\n"); disconnect_server(sock); sock = connect_server(ip_addr, port); connection_status = 0; } } } void disconnect_server(SOCKET sock) { #ifdef _WIN32 closesocket(sock); //Cleanup Winsock WSACleanup(); #else close(sock); #endif } SOCKET connect_server(char *ip_addr, unsigned int port) { struct sockaddr_in server; struct hostent *host_info; unsigned long addr = 0; unsigned long blocking_mode = 0; unsigned long connection_trys = 0; const int y = 1; SOCKET sock; #ifdef _WIN32 // Initialisiere TCP für Windows ("winsock") WORD wVersionRequested; WSADATA wsaData; wVersionRequested = MAKEWORD (1, 1); if (WSAStartup (wVersionRequested, &wsaData) != 0) { printf("[SYSTEM]: Error Winsock\r\n"); return 0; } #else //sock = socket( AF_INET, SOCK_STREAM | SOCK_NONBLOCK, 0 ); #endif sock = socket( AF_INET, SOCK_STREAM, 0 ); #ifdef _WIN32 #else setsockopt(sock, SOL_SOCKET, SO_REUSEADDR, &y, sizeof(int)); #endif if (sock < 0) { printf("[SYSTEM]: Error Socket\r\n"); return 0; } //Erzeuge die Socketadresse des Servers. Sie besteht aus Typ, IP-Adresse und Portnummer. memset( &server, 0, sizeof (server)); //ip_addr ist eine numerische IP-Adresse. if ((addr = inet_addr(ip_addr)) != INADDR_NONE) memcpy( (char *)&server.sin_addr, &addr, sizeof(addr)); else { // Für den Fall der Fälle: Wandle den Servernamen bspw. "localhost" in eine IP-Adresse um. host_info = gethostbyname(ip_addr); if (NULL == host_info) { printf("[SYSTEM]: Unbekannter Server\r\n"); return 0; } // Server-IP-Adresse memcpy( (char *)&server.sin_addr, host_info->h_addr, host_info->h_length ); } // IPv4-Verbindung server.sin_family = AF_INET; // Portnummer server.sin_port = htons( port ); //Baue die Verbindung zum Server auf. #ifdef _WIN32 while(1) { if(kbhit()) if(getch() == '#') return 0; if(connect(sock,(struct sockaddr*)&server,sizeof(server)) <0) { printf("[SYSTEM]: Verbinden... #%lu\r", connection_trys); connection_trys++; } else { printf("\r\n[SYSTEM]: Verbunden.\r\n"); connection_trys = 0; break; } } #else printf("[SYSTEM]: Verbinden... #%lu\r", connection_trys); while(1) { if(kbhit()) if(getch() == '#') return 0; if((connect(sock,(struct sockaddr*)&server,sizeof(server)) <0)) { printf("[SYSTEM]: Verbinden... #%lu\r", connection_trys); connection_trys++; } else { printf("\r\n[SYSTEM]: Verbunden.\r\n"); connection_trys = 0; break; } } #endif //Non-blocking Modus fuer Eingehende Verbindungen (recv) blocking_mode = 1; //1=enable(nonblock active) 0=disable #ifdef _WIN32 ioctlsocket(sock, FIONBIO, &blocking_mode); #else //ioctl(sock, O_NONBLOCK, &blocking_mode); fcntl(sock, F_SETFL, fcntl(sock, F_GETFL, 0) | O_NONBLOCK); #endif return sock; } #ifdef _WIN32 #else /* msleep(): Sleep for the requested number of milliseconds. */ void Sleep(long msec) { struct timespec ts; int res; if (msec < 0) { errno = EINVAL; return; } ts.tv_sec = msec / 1000; ts.tv_nsec = (msec % 1000) * 1000000; do { res = nanosleep(&ts, &ts); } while (res && errno == EINTR); return; } int kbhit(void) { struct termios oldt, newt; int ch; int oldf; tcgetattr(STDIN_FILENO, &oldt); newt = oldt; newt.c_lflag &= ~(ICANON|ECHO); tcsetattr(STDIN_FILENO, TCSANOW, &newt); oldf = fcntl(STDIN_FILENO, F_GETFL, 0); fcntl(STDIN_FILENO, F_SETFL, oldf | O_NONBLOCK); ch = getchar(); tcsetattr(STDIN_FILENO, TCSANOW, &oldt); fcntl(STDIN_FILENO, F_SETFL, oldf); if(ch != EOF) { ungetc(ch, stdin); return 1; } return 0; } int getch() { static int ch = -1, fd = 0; struct termios neu, alt; fd = fileno(stdin); tcgetattr(fd, &alt); neu = alt; neu.c_lflag &= ~(ICANON|ECHO); tcsetattr(fd, TCSANOW, &neu); ch = getchar(); tcsetattr(fd, TCSANOW, &alt); return ch; } #endif
