** TagInfo scan (version 4.24.7) 2021-07-27 00:26:14 ** Report Type: External -- IC INFO ------------------------------ # IC manufacturer: NXP Semiconductors # IC type: MIFARE DESFire (MF3ICD40) -- NDEF ------------------------------ # No NDEF data storage present: Maximum NDEF storage size after format: 3806 bytes -- EXTRA ------------------------------ # Memory size: 4 kB # IC detailed information: Capacitance: 17 pF # Version information: Vendor ID: NXP (0x04) Hardware info: * Type/subtype: 0x01/0x01 * Version: 0.2 * Storage size: 4096 bytes (0x18) * Protocol: ISO/IEC 14443-4 (0x05) Software info: * Type/subtype: 0x01/0x01 * Version: 0.6 * Storage size: 4096 bytes (0x18) * Protocol: ISO/IEC 14443-4 (0x05) Batch no: 0x8FB6125900 Production date: week 17, 2008 (0x1708) # Authentication information: Default PICC master key -- FULL SCAN ------------------------------ # Technologies supported: ISO/IEC 7816-4 compatible Native DESFire APDU framing ISO/IEC 14443-4 (Type A) compatible ISO/IEC 14443-3 (Type A) compatible ISO/IEC 14443-2 (Type A) compatible # Android technology information: Tag description: * TAG: Tech [android.nfc.tech.IsoDep, android.nfc.tech.NfcA, android.nfc.tech.NdefFormatable] * Maximum transceive length: 65279 bytes * Default maximum transceive time-out: 618 ms * Extended length APDUs supported * Maximum transceive length: 253 bytes * Default maximum transceive time-out: 618 ms MIFARE Classic support present in Android # Detailed protocol information: ID: 04:6B:43:81:36:1E:80 ATQA: 0x4403 SAK: 0x20 ATS: 0x06757781028000 * Max. accepted frame size: 64 bytes (FSCI: 5) * Supported receive rates: - 106, 212, 424, 848 kbit/s (DR: 1, 2, 4, 8) * Supported send rates: - 106, 212, 424, 848 kbit/s (DS: 1, 2, 4, 8) * Different send and receive rates supported * SFGT: 604.1 us (SFGI: 1) * FWT: 77.33 ms (FWI: 8) * NAD not supported * CID supported * Historical bytes: 0x80 |.| # Memory content: Application ID 0x000000 (PICC) * Default master key * Key configuration: (0x0F01) - 1 (3)DES key - Master key changeable - Master key required for: ~ directory list access: no ~ create/delete files: no - Configuration changeable --------------------------------------
