beignet-opencl-icd: no supported GPU found, this is probably the wrong opencl-icd package for this hardware (If you have multiple ICDs installed and OpenCL works, you can ignore this message) beignet-opencl-icd: no supported GPU found, this is probably the wrong opencl-icd package for this hardware (If you have multiple ICDs installed and OpenCL works, you can ignore this message) Number of platforms 2 Platform Name Clover Platform Vendor Mesa Platform Version OpenCL 1.1 Mesa 21.0.3 Platform Profile FULL_PROFILE Platform Extensions cl_khr_icd Platform Extensions function suffix MESA Platform Name Intel Gen OCL Driver Platform Vendor Intel Platform Version OpenCL 2.0 beignet 1.3 Platform Profile FULL_PROFILE Platform Extensions cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_byte_addressable_store cl_khr_3d_image_writes cl_khr_image2d_from_buffer cl_khr_depth_images cl_khr_spir cl_khr_icd cl_intel_accelerator cl_intel_subgroups cl_intel_subgroups_short Platform Extensions function suffix Intel beignet-opencl-icd: no supported GPU found, this is probably the wrong opencl-icd package for this hardware (If you have multiple ICDs installed and OpenCL works, you can ignore this message) Platform Name Clover Number of devices 1 Device Name Radeon RX 550 Series (POLARIS11, DRM 3.40.0, 5.11.0-31-generic, LLVM 12.0.0) Device Vendor AMD Device Vendor ID 0x1002 Device Version OpenCL 1.1 Mesa 21.0.3 Device Numeric Version 0x401000 (1.1.0) Driver Version 21.0.3 Device OpenCL C Version OpenCL C 1.1 Device Type GPU Device Profile FULL_PROFILE Device Available Yes Compiler Available Yes Max compute units 10 Max clock frequency 1071MHz Max work item dimensions 3 Max work item sizes 256x256x256 Max work group size 256 === CL_PROGRAM_BUILD_LOG === fatal error: cannot open file '/usr/local//usr/lib/clc/polaris11-amdgcn-mesa-mesa3d.bc': No such file or directory Preferred work group size multiple (kernel) Preferred / native vector sizes char 16 / 16 short 8 / 8 int 4 / 4 long 2 / 2 half 0 / 0 (n/a) float 4 / 4 double 2 / 2 (cl_khr_fp64) Half-precision Floating-point support (n/a) Single-precision Floating-point support (core) Denormals No Infinity and NANs Yes Round to nearest Yes Round to zero No Round to infinity No IEEE754-2008 fused multiply-add No Support is emulated in software No Correctly-rounded divide and sqrt operations No Double-precision Floating-point support (cl_khr_fp64) Denormals Yes Infinity and NANs Yes Round to nearest Yes Round to zero Yes Round to infinity Yes IEEE754-2008 fused multiply-add Yes Support is emulated in software No Address bits 64, Little-Endian Global memory size 3221225472 (3GiB) Error Correction support No Max memory allocation 1717986918 (1.6GiB) Unified memory for Host and Device No Minimum alignment for any data type 128 bytes Alignment of base address 32768 bits (4096 bytes) Global Memory cache type None Image support No Local memory type Local Local memory size 32768 (32KiB) Max number of constant args 16 Max constant buffer size 67108864 (64MiB) Max size of kernel argument 1024 Queue properties Out-of-order execution No Profiling Yes Profiling timer resolution 0ns Execution capabilities Run OpenCL kernels Yes Run native kernels No ILs with version (n/a) Built-in kernels with version (n/a) Device Extensions cl_khr_byte_addressable_store cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_fp64 cl_khr_extended_versioning Device Extensions with Version cl_khr_byte_addressable_store 0x400000 (1.0.0) cl_khr_global_int32_base_atomics 0x400000 (1.0.0) cl_khr_global_int32_extended_atomics 0x400000 (1.0.0) cl_khr_local_int32_base_atomics 0x400000 (1.0.0) cl_khr_local_int32_extended_atomics 0x400000 (1.0.0) cl_khr_int64_base_atomics 0x400000 (1.0.0) cl_khr_int64_extended_atomics 0x400000 (1.0.0) cl_khr_fp64 0x400000 (1.0.0) cl_khr_extended_versioning 0x400000 (1.0.0) Platform Name Intel Gen OCL Driver Number of devices 0 NULL platform behavior clGetPlatformInfo(NULL, CL_PLATFORM_NAME, ...) Clover clGetDeviceIDs(NULL, CL_DEVICE_TYPE_ALL, ...) Success [MESA] clCreateContext(NULL, ...) [default] Success [MESA] clCreateContext(NULL, ...) [other] clCreateContextFromType(NULL, CL_DEVICE_TYPE_DEFAULT) Success (1) Platform Name Clover Device Name Radeon RX 550 Series (POLARIS11, DRM 3.40.0, 5.11.0-31-generic, LLVM 12.0.0) clCreateContextFromType(NULL, CL_DEVICE_TYPE_CPU) No devices found in platform clCreateContextFromType(NULL, CL_DEVICE_TYPE_GPU) Success (1) Platform Name Clover Device Name Radeon RX 550 Series (POLARIS11, DRM 3.40.0, 5.11.0-31-generic, LLVM 12.0.0) clCreateContextFromType(NULL, CL_DEVICE_TYPE_ACCELERATOR) No devices found in platform clCreateContextFromType(NULL, CL_DEVICE_TYPE_CUSTOM) No devices found in platform clCreateContextFromType(NULL, CL_DEVICE_TYPE_ALL) Success (1) Platform Name Clover Device Name Radeon RX 550 Series (POLARIS11, DRM 3.40.0, 5.11.0-31-generic, LLVM 12.0.0) ICD loader properties ICD loader Name OpenCL ICD Loader ICD loader Vendor OCL Icd free software ICD loader Version 2.2.14 ICD loader Profile OpenCL 3.0
