library ieee; use ieee.std_logic_1164.all; use IEEE.NUMERIC_STD.all; entity Seg7_Comp is port ( S_1 : in std_logic; led_o : out std_logic_vector(6 downto 0); reset : in std_logic; areset : in std_logic; inclk0 : in std_logic; y : out std_logic; locked : out std_logic ); end Seg7_Comp; architecture arch of Seg7_Comp is component count is port ( clk : in std_logic; reset : in std_logic; S_1 : in std_logic; --sensor signal q : out integer range 0 to 2147483647; --32bit -- 16 bit 65535 y : out std_logic ); end component; component INT_TO_BCD is port ( q : in integer range 0 to 2147483647; BCD_OUT : out STD_LOGIC_VECTOR (3 downto 0) ); end component; component BCD_TO_7SEG is port ( BCD_IN : in std_logic_vector(3 downto 0); -- nur fuer simmulation stdlogic ueberall a : out std_logic; b : out std_logic; c : out std_logic; d : out std_logic; e : out std_logic; f : out std_logic; g : out std_logic ); end component; signal c0 : std_logic := '0'; signal q : integer range 0 to 2147483647 := 0; signal BCD : std_logic_vector(3 downto 0) := (others => '0'); begin -- DUMMY clock component c0 <= inclk0; locked <= '1'; inst_count : count port map ( clk => c0, reset => reset, S_1 => S_1, q => q, y => y ); inst_INT_TO_BCD : INT_TO_BCD port map ( q => q, BCD_OUT => BCD ); inst_BCD_TO_7SEG : BCD_TO_7SEG port map ( BCD_IN => BCD, a => led_o(6), b => led_o(5), c => led_o(4), d => led_o(3), e => led_o(2), f => led_o(1), g => led_o(0) ); end;
