library IEEE; use IEEE.STD_LOGIC_1164.all; use IEEE.NUMERIC_STD.all; entity split_digits is port ( i_clk : in std_logic; i_start : in std_logic; i_number : in std_logic_vector(9 downto 0); o_digits : out std_logic_vector(11 downto 0); o_busy : out std_logic ); end split_digits; architecture rtl of split_digits is signal s_counter : unsigned(9 downto 0) := (others => '0'); signal s_digits : std_logic_vector(11 downto 0) := (others => '0'); begin o_busy <= '1' when i_start = '1' or s_counter > 0 else '0'; o_digits <= s_digits; process begin wait until rising_edge(i_clk); if s_counter > 0 then s_counter <= s_counter - 1; else if i_start = '1' then s_counter <= unsigned(i_number); end if; end if; if s_counter > 0 then if unsigned(s_digits(3 downto 0)) < 9 then s_digits(3 downto 0) <= std_logic_vector(unsigned(s_digits(3 downto 0)) + 1); else s_digits(3 downto 0) <= (others => '0'); if unsigned(s_digits(7 downto 4)) < 9 then s_digits(7 downto 4) <= std_logic_vector(unsigned(s_digits(7 downto 4)) + 1); else s_digits(7 downto 4) <= (others => '0'); if unsigned(s_digits(11 downto 8)) < 9 then s_digits(11 downto 8) <= std_logic_vector(unsigned(s_digits(11 downto 8)) + 1); else s_digits(11 downto 8) <= (others => '0'); end if; end if; end if; end if; end process; end;
