# # Example python script to generate a BOM from a KiCad generic netlist # # Example: Ungrouped (One component per row) CSV output # """ @package Output: CSV (comma-separated) Grouped By: ungrouped, one component per line Sorted By: Ref Fields: Ref, Value, Part, Footprint, Datasheet, Manufacturer, Vendor Command line: python "pathToFile/bom_csv_sorted_by_ref.py" "%I" "%O.csv" """ from __future__ import print_function # Import the KiCad python helper module import kicad_netlist_reader import kicad_utils import csv import sys # A helper function to convert a UTF8/Unicode/locale string read in netlist # for python2 or python3 def fromNetlistText( aText ): if sys.platform.startswith('win32'): try: return aText.encode('utf-8').decode('cp1252') except UnicodeDecodeError: return aText else: return aText # Generate an instance of a generic netlist, and load the netlist tree from # the command line option. If the file doesn't exist, execution will stop net = kicad_netlist_reader.netlist(sys.argv[1]) # Open a file to write to, if the file cannot be opened output to stdout # instead try: f = kicad_utils.open_file_write(sys.argv[2], 'w') except IOError: e = "Can't open output file for writing: " + sys.argv[2] print( __file__, ":", e, sys.stderr ) f = sys.stdout # Create a new csv writer object to use as the output formatter out = csv.writer(f, lineterminator='\n', delimiter=',', quotechar="\"", quoting=csv.QUOTE_ALL) # override csv.writer's writerow() to support utf8 encoding: def writerow( acsvwriter, columns ): utf8row = [] for col in columns: utf8row.append( fromNetlistText( str(col) ) ) acsvwriter.writerow( utf8row ) components = net.getInterestingComponents() # Output a field delimited header line writerow( out, ['Source:', net.getSource()] ) writerow( out, ['Date:', net.getDate()] ) writerow( out, ['Tool:', net.getTool()] ) writerow( out, ['Component Count:', len(components)] ) writerow( out, ['Ref', 'Value', 'Footprint', 'Datasheet', 'Manufacturer', 'Vendor'] ) # Output all of the component information (One component per row) for c in components: writerow( out, [c.getRef(), c.getValue(), c.getFootprint(), c.getDatasheet(), c.getField("Manufacturer"), c.getField("Vendor")])
