--- hi this is my free tutorial for all people how need to configure fpga: -- --counter: https://startingelectronics.org/software/VHDL-CPL... library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; entity top_lvl is Port ( sysclk : in std_logic; button1 : in std_logic; led0_b : out std_logic; -- rgb led blue output1 : out std_logic; -- led onboard output2 : out std_logic -- led onboard ); end top_lvl; architecture Behavioral of top_lvl is --- signal count : STD_LOGIC_VECTOR (23 downto 0) := X"000000"; signal toggle : std_logic:='0'; signal button_internal : STD_LOGIC_VECTOR(1 DOWNTO 0); signal debug_leds : STD_LOGIC_VECTOR(1 DOWNTO 0); COMPONENT ila_0 PORT ( clk : IN STD_LOGIC; probe0 : IN STD_LOGIC_VECTOR(1 DOWNTO 0); probe1 : IN STD_LOGIC_VECTOR(1 DOWNTO 0) ); END COMPONENT ; ------------------------------------------------------ ---- ARCHITECTURE BEGIN begin myFirstILACore : ila_0 PORT MAP ( clk => sysclk, probe0 => button_internal, probe1 => debug_leds ); ---------- led0_b <=button1; -- connect input to output.. --- connect button to debug ILA core: button_internal(0)<=button1; button_internal(1)<=button1; p_led_blink : process (sysclk, count) variable toggle_var : std_logic := '0'; begin if rising_edge (sysclk) then count <= count + '1'; -- counting up if count = X"B71B00" then toggle <= '1'; -- set for toggling..... count <= X"000000"; end if; if toggle = '1' then output1 <= not toggle_var; output2 <= toggle_var; toggle <= '0'; -- reset toggle debug_leds(0) <= toggle_var; debug_leds(1) <= not toggle_var; toggle_var := not toggle_var; end if; end if; end process p_led_blink ; end Behavioral;
