20:32:29.572 -> -- Hoymiles test -- 20:32:29.572 -> Starting WiFi scan... 20:32:31.732 -> 2 networks found: 20:32:31.732 -> 00: [CH XX] [XXX] -86dBm * V XXX1 20:32:31.772 -> 01: [CH XX] [XXX] -44dBm * V XXX2 20:32:31.772 -> try connect to XXX2 20:32:32.932 -> 19 18 17 16 15 14 20:32:38.212 -> [WiFi]Connected 20:32:38.212 -> IP:11.22.33.44 20:32:38.212 -> XXX2 20:32:38.212 -> isDayofDaylightChange=0 20:32:38.212 -> isDayofDaylightChange=0 20:32:38.212 -> [NTP] get time from NTP server 11.22.33.66: got 2022-04-11+20:32:37 20:32:38.252 -> [HTTP] installed 20:32:38.252 -> [OTA] installed 20:32:38.252 -> SPI Frequency = 10 Mhz 20:32:38.252 -> Channel = 3 (~ 2403 MHz) 20:32:38.252 -> RF Data Rate = 250 KBPS 20:32:38.252 -> RF Power Amplifier = PA_MAX 20:32:38.252 -> RF Low Noise Amplifier = Enabled 20:32:38.252 -> CRC Length = Disabled 20:32:38.252 -> Address Length = 5 bytes 20:32:38.252 -> Static Payload Length = 32 bytes 20:32:38.252 -> Auto Retry Delay = 250 microseconds 20:32:38.252 -> Auto Retry Attempts = 0 maximum 20:32:38.252 -> Packets lost on 20:32:38.252 -> current channel = 0 20:32:38.252 -> Retry attempts made for 20:32:38.252 -> last transmission = 15 20:32:38.292 -> Multicast = Disabled 20:32:38.292 -> Custom ACK Payload = Disabled 20:32:38.292 -> Dynamic Payloads = Disabled 20:32:38.292 -> Auto Acknowledgment = Disabled 20:32:38.292 -> Primary Mode = RX 20:32:38.292 -> TX address = 0xdeadbeef01 20:32:38.292 -> pipe 0 (closed) bound = 0xdeadbeef01 20:32:38.292 -> pipe 1 ( open ) bound = 0x1234567801 20:32:38.292 -> pipe 2 (closed) bound = 0xc3 20:32:38.292 -> pipe 3 (closed) bound = 0xc4 20:32:38.292 -> pipe 4 (closed) bound = 0xc5 20:32:38.292 -> pipe 5 (closed) bound = 0xc6
