library IEEE; use IEEE.STD_LOGIC_1164.ALL; -- Uncomment the following library declaration if using -- arithmetic functions with Signed or Unsigned values use IEEE.NUMERIC_STD.ALL; -- Uncomment the following library declaration if instantiating -- any Xilinx leaf cells in this code. --library UNISIM; --use UNISIM.VComponents.all; entity crc_tb is -- Port ( ); end crc_tb; architecture Behavioral of crc_tb is signal clk_tb : std_logic; signal data_tb : std_logic_vector(7 downto 0); signal LOAD_INIT_tb: std_logic:='1'; signal calc_tb: std_logic:='0'; signal d_valid_tb: std_logic := '0'; signal reset_tb : std_logic; signal byte_crc_cnt : unsigned (15 downto 0):= X"0000"; signal enable_test : std_logic:= '0'; signal CRC_REG_tb : std_logic_vector(31 downto 0); -- component CRC is Port ( CLOCK : in std_logic; RESET : in std_logic; DATA : in std_logic_vector(7 downto 0); LOAD_INIT : in std_logic; CALC : in std_logic; D_VALID : in std_logic; CRC : out std_logic_vector(7 downto 0); CRC_REG : out std_logic_vector(31 downto 0); CRC_VALID : out std_logic ); end component; begin -- clk_p : process begin clk_tb <= '1'; wait for 10 ns; clk_tb <= '0'; wait for 10 ns; end process; --- reset_p : process begin LOAD_INIT_tb <= '1'; reset_tb <= '1'; wait for 100 ns; reset_tb <= '0'; wait for 100 ns; LOAD_INIT_tb <= '0'; while CRC_REG_tb < X"FFFFFFFF" loop wait for 10 ns; end loop; wait for 100 ns; enable_test <= '1'; wait; end process; -- CRC_tb : CRC port map( CLOCK => clk_tb, RESET => reset_tb, DATA => data_tb, LOAD_INIt => LOAD_INIT_tb, CALC => calc_tb, D_VALID =>d_valid_tb, CRC => open, CRC_REG => CRC_REG_tb, CRC_VALID => open ); crc_test : process ( clk_tb, reset_tb,byte_crc_cnt,d_valid_tb,enable_test) begin if ( enable_test = '1') then if (rising_edge(clk_tb) and reset_tb = '0' and to_integer(byte_crc_cnt) < 4) then -- d_valid_tb <= '1'; calc_tb <= '1'; data_tb <= X"FF"; byte_crc_cnt <= byte_crc_cnt +1; else if to_integer(byte_crc_cnt) >= 4 then d_valid_tb <= '0'; calc_tb <= '0'; else end if; end if; else --d_valid_tb <= '1'; end if; end process; end Behavioral;
