LIBRARY IEEE; USE IEEE.std_logic_1164.ALL; ENTITY uart_rx IS GENERIC ( -- frequency clk / frequency Uart -- Example: 10 MHz Clock, 115200 baud rate Uart -- 10_000_000 / 115_200 = 87 clk_cycles_per_bit : INTEGER ); PORT ( -- System clock. clk : IN STD_LOGIC; rst : IN STD_LOGIC; -- Incoming data bits (serial stream). rx_port : IN STD_LOGIC; -- 'High' if rx_data containts a valid received byte. -- 'Low' when less than 8 bits or nothing was received. rx_rdy : OUT STD_LOGIC := '0'; -- Receiver handshake. rx_ack : IN STD_LOGIC; -- Received data byte. rx_data : OUT STD_LOGIC_VECTOR(7 DOWNTO 0) ); END uart_rx; ARCHITECTURE uart_rx_arch OF uart_rx IS -- Finite machine states. TYPE state_type IS (S_Idle, S_Rx_Start_Bit, S_Rx_Data_Bits, S_Rx_Stop_Bit, S_Cleanup); SIGNAL state : state_type := S_Idle; -- Data sampling shift register. SIGNAL s_shiftreg : STD_LOGIC_VECTOR(1 DOWNTO 0) := (OTHERS => '0'); -- Internal counters. SIGNAL s_clk_count : INTEGER RANGE 0 TO (clk_cycles_per_bit - 1) := 0; SIGNAL s_bit_index : INTEGER RANGE 0 TO 7 := 0; -- 8 bits total -- Initialize outputs with standard values. SIGNAL s_rx_data : STD_LOGIC_VECTOR(7 DOWNTO 0) := (OTHERS => '0'); SIGNAL s_rx_rdy : STD_LOGIC := '0'; BEGIN -- Drive outputs. rx_rdy <= s_rx_rdy; rx_data <= s_rx_data; -- Samples incoming data bits into shift register to avoid metastability issues. Data_Sampling : PROCESS (clk, rst) BEGIN IF rising_edge(clk) THEN IF rst = '1' THEN -- Synchronous reset. s_shiftreg(0) <= '1'; s_shiftreg(1) <= '1'; ELSE s_shiftreg(0) <= rx_port; s_shiftreg(1) <= s_shiftreg(0); END IF; END IF; END PROCESS; -- Finite state machine of receiver. fsm_recv : PROCESS (clk, rst) BEGIN IF rising_edge(clk) THEN IF rst = '1' THEN -- Synchronous reset. s_clk_count <= 0; s_bit_index <= 0; s_rx_data <= (OTHERS => '0'); s_rx_rdy <= '0'; state <= S_Idle; ELSE CASE state IS WHEN S_Idle => IF (s_shiftreg(1) <= '0') THEN -- Start bit detected. state <= S_Rx_Start_Bit; s_rx_rdy <= '0'; ELSE state <= S_Idle; END IF; -- Check middle of start bit to make sure its still low. WHEN S_Rx_Start_Bit => IF s_clk_count = ((clk_cycles_per_bit - 1) / 2) THEN IF (s_shiftreg(1) = '0') THEN s_clk_count <= 0; -- reset counter since we found the middle. state <= s_Rx_Data_Bits; ELSE state <= S_Idle; END IF; ELSE s_clk_count <= (s_clk_count + 1); state <= S_Rx_Start_Bit; END IF; -- Wait (clk_cycles_per_bit - 1) clock cycles to sample serial data. WHEN S_Rx_Data_Bits => IF (s_clk_count < clk_cycles_per_bit - 1) THEN s_clk_count <= (s_clk_count + 1); state <= s_Rx_Data_Bits; ELSE s_clk_count <= 0; s_rx_data(s_bit_index) <= s_shiftreg(1); -- Check if we have send out all bits. IF (s_bit_index < 7) THEN s_bit_index <= (s_bit_index + 1); state <= S_Rx_Data_Bits; ELSE s_bit_index <= 0; state <= S_Rx_Stop_Bit; END IF; END IF; -- Receive Stop bit. Stop bit = 1 WHEN S_Rx_Stop_Bit => -- Wait (clk_cycles_per_bit - 1) clock cycles for Stop bit to finish. IF (s_clk_count < (clk_cycles_per_bit - 1)) THEN s_clk_count <= (s_clk_count + 1); state <= S_Rx_Stop_Bit; ELSE s_rx_rdy <= '1'; s_clk_count <= 0; state <= S_Cleanup; END IF; -- Stay here for one clock cycle. WHEN S_Cleanup => IF rx_ack = '1' THEN s_rx_rdy <= '0'; state <= S_Idle; END IF; END CASE; END IF; END IF; END PROCESS; END uart_rx_arch;
