LIBRARY IEEE; USE IEEE.std_logic_1164.ALL; ENTITY uart_tx IS GENERIC ( -- frequency clk / frequency Uart -- Example: 10 MHz Clock, 115200 baud rate Uart -- 10_000_000 / 115_200 = 87 clk_cycles_per_bit : INTEGER ); PORT ( -- System clock. clk : IN STD_LOGIC; -- Reset. rst : IN STD_LOGIC; -- 'High' if transmitter shall start to send tx_byte. -- 'Low' when nothing should be send. tx_ack : IN STD_LOGIC; -- Data byte to be send. tx_data : IN STD_LOGIC_VECTOR(7 DOWNTO 0); -- 'High' if transmitting process has started. -- 'Low' when system is in idle mode. tx_rdy : OUT STD_LOGIC := '1'; -- Outgoing serial data stream. tx_port : OUT STD_LOGIC := '1' ); END uart_tx; ARCHITECTURE uart_tx_arch OF uart_tx IS -- Finite machine states. TYPE state_type IS (S_Idle, S_Tx_Start_Bit, S_Tx_Data_Bits, S_Tx_Stop_Bit, S_Cleanup); SIGNAL state : state_type := S_Idle; -- Internal counters. SIGNAL s_clk_count : INTEGER RANGE 0 TO (clk_cycles_per_bit - 1) := 0; SIGNAL s_bit_index : INTEGER RANGE 0 TO 7 := 0; -- 8 Bits total -- Initialize outputs with standard values. SIGNAL s_tx_data : STD_LOGIC_VECTOR(7 DOWNTO 0) := (OTHERS => '0'); BEGIN PROCESS (clk, rst) BEGIN IF rising_edge(clk) THEN IF rst = '1' THEN -- Synchronous reset. s_clk_count <= 0; s_bit_index <= 0; s_tx_data <= (OTHERS => '0'); --s_txdone <= '0'; -- wird mE nicht benötigt state <= S_Idle; ELSE CASE state IS WHEN S_Idle => -- Alles unnötig --tx_rdy <= '1'; --tx_port <= '1'; -- Drive line 'High' for Idle. --s_txdone <= '0'; --s_clk_count <= 0; --s_bit_index <= 0; IF (tx_ack = '1') THEN tx_rdy <= '0'; s_tx_data <= tx_data; state <= S_Tx_Start_Bit; ELSE state <= S_Idle; END IF; -- Send out Start Bit. Start bit = 0 WHEN S_Tx_Start_Bit => --tx_rdy <= '0'; -- ist glaub bei s_Idle (if) besser tx_port <= '0'; -- Wait (clk_cycles_per_bit - 1) clock cycles for start bit to finish. IF (s_clk_count < (clk_cycles_per_bit - 1)) THEN s_clk_count <= (s_clk_count + 1); state <= S_Tx_Start_Bit; ELSE s_clk_count <= 0; state <= S_Tx_Data_Bits; END IF; -- Wait (clk_cycles_per_bit - 1) clock cycles for data bits to finish. WHEN S_Tx_Data_Bits => tx_port <= s_tx_data(s_bit_index); IF (s_clk_count < clk_cycles_per_bit - 1) THEN s_clk_count <= (s_clk_count + 1); state <= S_Tx_Data_Bits; ELSE s_clk_count <= 0; -- Check if we have sent out all bits. IF (s_bit_index < 7) THEN s_bit_index <= (s_bit_index + 1); state <= S_Tx_Data_Bits; ELSE s_bit_index <= 0; state <= S_Tx_Stop_Bit; END IF; END IF; -- Send out Stop bit. Stop bit = 1 WHEN S_Tx_Stop_Bit => tx_port <= '1'; -- Wait (clk_cycles_per_bit - 1) clock cycles for Stop bit to finish. IF (s_clk_count < (clk_cycles_per_bit - 1)) THEN s_clk_count <= (s_clk_count + 1); state <= S_Tx_Stop_Bit; ELSE --s_txdone <= '1'; s_clk_count <= 0; state <= S_Cleanup; END IF; -- Stay here for one clk cycle. WHEN S_Cleanup => tx_rdy <= '1'; --s_txdone <= '1'; -- Signal wird nicht benötigt state <= S_Idle; END CASE; END IF; END IF; END PROCESS; END uart_tx_arch;
