# Modbus sensors for EPever Charge Controller 4 (2210 AN) - platform: modbus scan_interval: 60 registers: - name: "Battery Array Capacity 4" hub: epever4 unit_of_measurement: '%' slave: 1 register: 12570 register_type: input - name: "Solar Power Watts 4" hub: epever4 unit_of_measurement: W slave: 1 register: 12546 register_type: input scale: .01 count: 2 precision: 2 reverse_order: true - name: "Solar Amps 4" hub: epever4 unit_of_measurement: A slave: 1 register: 12545 register_type: input scale: 0.01 precision: 2 - name: "Solar Voltage 4" hub: epever4 unit_of_measurement: V slave: 1 register: 12544 register_type: input scale: 0.01 precision: 2 - name: "Battery Charging Watts 4" hub: epever4 unit_of_measurement: W slave: 1 register: 12546 register_type: input scale: .01 count: 2 precision: 2 reverse_order: true - name: "Battery Charging Amps 4" hub: epever4 unit_of_measurement: A slave: 1 register: 13083 register_type: input scale: 0.01 precision: 2 count: 1 reverse_order: true - name: "Battery Voltage 4" hub: epever4 unit_of_measurement: V slave: 1 register: 13082 register_type: input scale: 0.01 precision: 2 - name: Load Watts 4 hub: epever4 unit_of_measurement: W slave: 1 register: 12558 # low 12550 high 12551 #12558 register_type: input scale: 0.01 precision: 2 - name: Load Amps 4 hub: epever4 unit_of_measurement: A slave: 1 register: 12549 register_type: input scale: 0.001 precision: 2 - name: Load Volts 4 hub: epever4 unit_of_measurement: V slave: 1 register: 12548 register_type: input scale: 0.01 precision: 2 - name: "Battery Temperature 4" hub: epever4 unit_of_measurement: °C slave: 1 register: 12560 register_type: input scale: 0.01 precision: 2 - name: "Controller Temperature 4" hub: epever4 unit_of_measurement: °C slave: 1 register: 12561 register_type: input scale: 0.01 precision: 2 - name: Energy Generated Today 4 hub: epever4 unit_of_measurement: KWh slave: 1 register: 13068 register_type: input scale: 0.01 precision: 2 count: 2 reverse_order: true - name: Energy Generated this Month 4 hub: epever4 unit_of_measurement: KWh slave: 1 register: 13070 register_type: input scale: 0.01 precision: 2 count: 2 reverse_order: true - name: Energy Generated this Year 4 hub: epever4 unit_of_measurement: KWh slave: 1 register: 13072 register_type: input scale: 0.01 precision: 2 count: 2 reverse_order: true - name: Total Energy Generated 4 hub: epever4 unit_of_measurement: KWh slave: 1 register: 13074 register_type: input scale: 0.01 precision: 2 count: 2 reverse_order: true modbus: - type: tcp host: 192.168.1.154 port: 8088 name: epever4 timeout: 2 - type: rtuovertcp host: 192.168.1.154 port: 8088 name: epever4
