import socket, sys from struct import * s = socket.socket(socket.AF_INET, socket.SOCK_RAW, socket.IPPROTO_TCP) serverPort = 50000 s.bind(('', serverPort)) print ("socket binded to %s" %(serverPort)) while True: packet = s.recvfrom(65565) #packet string from tuple packet = packet[0] #take first 20 characters for the ip header ip_header = packet[0:20] #now unpack them :) iph = unpack('!BBHHHBBH4s4s' , ip_header) version_ihl = iph[0] version = version_ihl >> 4 ihl = version_ihl & 0xF iph_length = ihl * 4 ttl = iph[5] protocol = iph[6] s_addr = socket.inet_ntoa(iph[8]); d_addr = socket.inet_ntoa(iph[9]); print("Version : " + str(version) + " IP Header Length : " + str(ihl) + " TTL : " + str(ttl) + " Protocol : " + str(protocol) + " $ tcp_header = packet[iph_length:iph_length+20] #now unpack them :) tcph = unpack('!HHLLBBHHH' , tcp_header) source_port = tcph[0] dest_port = tcph[1] sequence = tcph[2] acknowledgement = tcph[3] doff_reserved = tcph[4] tcph_length = doff_reserved >> 4 print("Source Port : " + str(source_port) + " Dest Port : " + str(dest_port) + " Sequence Number : " + str(sequence) + " Acknowled$ h_size = iph_length + tcph_length * 4 data_size = len(packet) - h_size #get data from the packet data = packet[h_size:] if data_size > 0: print(data)
