............................... .................................................................................................... I: add inverter: HM600, SN: 11418040xxxx I: RF24 Amp Pwr: RF24_PA_MIN I: Radio Config: SPI Frequency = 1 Mhz Channel = 3 (~ 2403 MHz) RF Data Rate = 250 KBPS RF Power Amplifier = PA_MIN RF Low Noise Amplifier = Enabled CRC Length = 16 bits Address Length = 5 bytes Static Payload Length = 32 bytes Auto Retry Delay = 250 microseconds Auto Retry Attempts = 0 maximum Packets lost on current channel = 0 Retry attempts made for last transmission = 0 Multicast = Disabled Custom ACK Payload = Disabled Dynamic Payloads = Enabled Auto Acknowledgment = Disabled Primary Mode = RX TX address = 0xe7e7e7e7e7 pipe 0 (closed) bound = 0xe7e7e7e7e7 pipe 1 ( open ) bound = 0x1234567801 pipe 2 (closed) bound = 0xc3 pipe 3 (closed) bound = 0xc4 pipe 4 (closed) bound = 0xc5 pipe 5 (closed) bound = 0xc6 I: ---------------------------------------- I: Welcome to AHOY! I: point your browser to http://(IP unset) I: to configure your device I: ---------------------------------------- I: connect to network 'HWW-WLAN-2-5G1581' ... ............................... .................................................................................................... I: --------- AP MODE SSID: AHOY-DTU PWD: esp_8266 Active for: 60 seconds --------- I: AP will be closed in 42 seconds I: 1 clients connected, resetting AP timeout I: AP will be closed in 60 seconds I: 1 clients connected, resetting AP timeout I: AP will be closed in 60 seconds I: Serial debug is I: off ets Jan 8 2013,rst cause:2, boot mode:(3,6) load 0x4010f000, len 3460, room 16 tail 4 chksum 0xcc load 0x3fff20b8, len 40, room 4 tail 4 chksum 0xc9 csum 0xc9 v0005af00 ~ld I: connect to network 'HWW-WLAN-2-5G1581' ... ........... I: add inverter: HM600, SN: 11418040xxxx I: RF24 Amp Pwr: RF24_PA_MIN I: Radio Config: SPI Frequency = 1 Mhz Channel = 3 (~ 2403 MHz) RF Data Rate = 250 KBPS RF Power Amplifier = PA_MIN RF Low Noise Amplifier = Enabled CRC Length = 16 bits Address Length = 5 bytes Static Payload Length = 32 bytes Auto Retry Delay = 250 microseconds Auto Retry Attempts = 0 maximum Packets lost on current channel = 0 Retry attempts made for last transmission = 0 Multicast = Disabled Custom ACK Payload = Disabled Dynamic Payloads = Enabled Auto Acknowledgment = Disabled Primary Mode = RX TX address = 0xe7e7e7e7e7 pipe 0 (closed) bound = 0xe7e7e7e7e7 pipe 1 ( open ) bound = 0x1234567801 pipe 2 (closed) bound = 0xc3 pipe 3 (closed) bound = 0xc4 pipe 4 (closed) bound = 0xc5 pipe 5 (closed) bound = 0xc6 I: ---------------------------------------- I: Welcome to AHOY! I: point your browser to http://192.168.178.22 I: to configure your device I: ---------------------------------------- I: [NTP]: 2022-06-17 16:31:08
