LIBRARY ieee; USE ieee.std_logic_1164.ALL; ENTITY tb_pwm2 IS END tb_pwm2; ARCHITECTURE behavior OF tb_pwm2 IS -- Component Declaration for the Unit Under Test (UUT) COMPONENT pwm2 PORT( CLK : IN std_logic; SW : IN std_logic_vector (5 downto 0); PWM_Value : IN std_logic_vector (7 downto 0); PWM : OUT std_logic; Out2 : OUT std_logic ); END COMPONENT; --Inputs signal CLK : std_logic := '0'; signal SW : std_logic_vector (5 downto 0) := "000000"; signal PWM_Value : std_logic_vector (7 downto 0) := "10000000"; --Outputs signal PWM : std_logic; signal Out2 : std_logic; BEGIN -- Instantiate the Unit Under Test (UUT) uut: pwm2 PORT MAP ( CLK => CLK, SW => SW, PWM_Value => PWM_Value, PWM => PWM, Out2 => Out2 ); CLK <= not CLK after 1 us; sw(0) <= not sw(0) after 222 ms; sw(1) <= not sw(1) after 333 ms; -- Stimulus process stim_proc: process begin wait for 10 ms; sw(5 downto 2) <= "0001"; wait for 10 ms; sw(5 downto 2) <= "0010"; wait for 10 ms; sw(5 downto 2) <= "0100"; wait for 10 ms; sw(5 downto 2) <= "1000"; wait for 10 ms; sw(5 downto 2) <= "0101"; wait for 10 ms; sw(5 downto 2) <= "1010"; wait; end process; END;
