LIBRARY ieee; USE ieee.std_logic_1164.ALL; -- Uncomment the following library declaration if using -- arithmetic functions with Signed or Unsigned values --USE ieee.numeric_std.ALL; ENTITY tb_watch IS END tb_watch; ARCHITECTURE behavior OF tb_watch IS -- Component Declaration for the Unit Under Test (UUT) COMPONENT watch PORT( CLK : IN std_logic; Reset : IN std_logic; sec : OUT std_logic; Min0 : OUT std_logic_vector(6 downto 0); Min1 : OUT std_logic_vector(6 downto 0); Hr0 : OUT std_logic_vector(6 downto 0); Hr1 : OUT std_logic_vector(6 downto 0) ); END COMPONENT; --Inputs signal CLK : std_logic := '0'; signal Reset : std_logic := '1'; --Outputs signal sec : std_logic; signal Min0 : std_logic_vector(6 downto 0); signal Min1 : std_logic_vector(6 downto 0); signal Hr0 : std_logic_vector(6 downto 0); signal Hr1 : std_logic_vector(6 downto 0); BEGIN -- Instantiate the Unit Under Test (UUT) uut: watch PORT MAP ( CLK => CLK, Reset => Reset, sec => sec, Min0 => Min0, Min1 => Min1, Hr0 => Hr0, Hr1 => Hr1 ); CLK <= not CLK after 10 us; -- Simulation schneller mit 50kHz Takt Reset <= '0' after 10 ms; END;
