/* This file has been prepared for Doxygen automatic documentation generation.*/ /*! \file ********************************************************************* * * \brief This file implements some macros that makes the IAR C-compiler and * avr-gcc work with the same code base for the AVR architecture. * * \par Documentation * For comprehensive code documentation, supported compilers, compiler * settings and supported devices see readme.html * * \author * Atmel Corporation: http://www.atmel.com \n * Support email: avr@atmel.com * * $Revision: 613 $ * $Date: 2006-04-07 14:40:07 +0200 (fr, 07 apr 2006) $ \n * * Copyright (c) 2008, Atmel Corporation All rights reserved. * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions are met: * * 1. Redistributions of source code must retain the above copyright notice, * this list of conditions and the following disclaimer. * * 2. Redistributions in binary form must reproduce the above copyright notice, * this list of conditions and the following disclaimer in the documentation * and/or other materials provided with the distribution. * * 3. The name of ATMEL may not be used to endorse or promote products derived * from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR IMPLIED * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE EXPRESSLY AND * SPECIFICALLY DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, * INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF * THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. ******************************************************************************/ #ifndef COMPILER_AVR_H #define COMPILER_AVR_H #ifndef F_CPU /*! \brief Define default CPU frequency, if this is not already defined. */ #define F_CPU 2000000UL #endif #include #include #include /*! \brief This macro will protect the following code from interrupts. */ #define AVR_ENTER_CRITICAL_REGION( ) uint8_t volatile saved_sreg = SREG; \ cli(); /*! \brief This macro must always be used in conjunction with AVR_ENTER_CRITICAL_REGION * so the interrupts are enabled again. */ #define AVR_LEAVE_CRITICAL_REGION( ) SREG = saved_sreg; #if defined( __ICCAVR__ ) #include #include #include #include #ifndef __HAS_ELPM__ #define _MEMATTR __flash #else /* __HAS_ELPM__ */ #define _MEMATTR __farflash #endif /* __HAS_ELPM__ */ /*! \brief Perform a delay of \c us microseconds. * * The macro F_CPU is supposed to be defined to a constant defining the CPU * clock frequency (in Hertz). * * The maximal possible delay is 262.14 ms / F_CPU in MHz. * * \note For the IAR compiler, currently F_CPU must be a * multiple of 1000000UL (1 MHz). */ #define delay_us( us ) ( __delay_cycles( ( F_CPU / 1000000UL ) * ( us ) ) ) /*! \brief Preprocessor magic. * * Some preprocessor magic to allow for a header file abstraction of * interrupt service routine declarations for the IAR compiler. This * requires the use of the C99 _Pragma() directive (rather than the * old #pragma one that could not be used as a macro replacement), as * well as two different levels of preprocessor concetanations in * order to do both, assign the correct interrupt vector name, as well * as construct a unique function name for the ISR. * * \note Do *NOT* try to reorder the macros below, as this will only * work in the given order. */ #define PRAGMA(x) _Pragma( #x ) #define ISR(vec) PRAGMA( vector=vec ) __interrupt void handler_##vec(void) #define sei( ) (__enable_interrupt( )) #define cli( ) (__disable_interrupt( )) /*! \brief Define the no operation macro. */ #define nop( ) (__no_operation()) /*! \brief Define the watchdog reset macro. */ #define watchdog_reset( ) (__watchdog_reset( )) #define INLINE PRAGMA( inline=forced ) static #define FLASH_DECLARE(x) _MEMATTR x #define FLASH_STRING(x) ((_MEMATTR const char *)(x)) #define FLASH_STRING_T char const _MEMATTR * #define FLASH_BYTE_ARRAY_T uint8_t const _MEMATTR * #define PGM_READ_BYTE(x) *(x) #define PGM_READ_WORD(x) *(x) #define SHORTENUM /**/ #elif defined( __GNUC__ ) #include #include #include #include /*! \brief Define the delay_us macro for GCC. */ #define delay_us( us ) (_delay_us( us )) #define INLINE static inline /*! \brief Define the no operation macro. */ #define nop() do { __asm__ __volatile__ ("nop"); } while (0) #define MAIN_TASK_PROLOGUE int #define MAIN_TASK_EPILOGUE() return -1; #define SHORTENUM __attribute__ ((packed)) #else #error Compiler not supported. #endif #endif
