Programm: [code] print("buzzer = machine.Pin(17, machine.Pin.OUT, machine.Pin.PULL_DOWN") file.write("buzzer = machine.Pin(17, machine.Pin.OUT, machine.Pin.PULL_DOWN") file.write ("\n") file.flush() buzzer = machine.Pin(17, machine.Pin.OUT, machine.Pin.PULL_DOWN) #GPIO17 = Pin22 print("led_onboard = machine.Pin(25, machine.Pin.OUT, machine.Pin.PULL_DOWN)") file.write("led_onboard = machine.Pin(25, machine.Pin.OUT, machine.Pin.PULL_DOWN)") file.write("\n") file.flush() led_onboard = machine.Pin(25, machine.Pin.OUT, machine.Pin.PULL_DOWN) print("\n","start","\n" ) file.write("\n","start","\n" ) file.flush [\code] in tty wird bei der Ausführunge obogen Codes angezeigt: [code] File 0024_IRQ.log opened for writing buzzer = machine.Pin(17, machine.Pin.OUT, machine.Pin.PULL_DOWN led_onboard = machine.Pin(25, machine.Pin.OUT, machine.Pin.PULL_DOWN) start Traceback (most recent call last): File "", line 84, in TypeError: can't convert str to int [\code] line 84 ist: file.write("\n","start","\n" ) im file steht: [code] buzzer = machine.Pin(17, machine.Pin.OUT, machine.Pin.PULL_DOWN led_onboard = machine.Pin(25, machine.Pin.OUT, machine.Pin.PULL_DOWN) [\code]
